All Things Mk5 => Mk5 General Area => Topic started by: swiftlupogti on April 29, 2011, 02:17:11 pm
is there a 'how to' thread on here anywhere?
cant find one on the search.
thanks
K03 or K04?
K03!
Have you tried a search, there are loads of threads on fitting mate which will be more concise but:
It's fairly straight forward, get the front up on axle stands, drop the engine tray. Go under from the front and follow the down pipe up to the turbo, the DV is bolted on the side, carefully unplug the electric cable, then its 3 x T25 bolts iirc, take it off and replace. Refit in reverse. :happy2:
