All Things Mk5 => Modifications & Technical Area => Sat Nav and Car Audio => Topic started by: whiteatom on May 02, 2011, 08:07:13 pm
Title: CAN Upgrade
Post by: whiteatom on May 02, 2011, 08:07:13 pm
Hi
Looking into updating CAN in my 05 plate with "F" CAN
Would this http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=180572923211&ssPageName=STRK:MEWAX:IT work with the lastest RNS510 LED ?
Is this http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=170601532805&ssPageName=STRK:MEWAX:IT not as good in some way ?
Many thanks in advance
Title: Re: CAN Upgrade
Post by: MarkMarked on May 02, 2011, 08:40:51 pm
the one in the first link is a newer version than the second, AD v AA, either version will work fine with a C version RNS
Post by: whiteatom on May 02, 2011, 09:16:36 pm
Thanks, do you think it is worth getting the newer one ? Do you know what version they are upto ?
Post by: apples12 on May 02, 2011, 09:36:07 pm
Newer ones are worth it if your going to retrofit other bits and pieces, i've got an AD in mine, and its given a masssive list of options some of which are obviously for other models of car.
what i can say from my experience however is that the can bus controller is a PITA to get to!
Post by: whiteatom on May 02, 2011, 09:53:05 pm
Thanks , what year is your car ? Where was it located ? Mine is a 05 tdi and think I saw it behind ash tray when I fitted tyre pressure monitor.
Post by: Eddie-NL on May 02, 2011, 10:07:07 pm
Yes, mine is there too, but they put them high up in the drivers footwell and near the bulkhead.
