All Things Mk5 => Mk5 General Area => Topic started by: berg on May 07, 2011, 02:59:11 pm
Got a mate fitting my arb's at mo.
He says the rear one has gone on ok but says he cant see how the oem bracket comes off the front one to put the bush over which comes with the Eibach's?
Can anyone confirm that the oem bracket is definately to be utilised when fitting the Eibach arb's and if so how do you get it off? Does the top and bottom half of the bracket split somehow?
someone on here has had this problem, the original one is not intended to be split, it's one unit, sorry mate :sad1:
Hi Danish, the eibach kit only comes with the 2 bars and 4 poly bushes, so you must use the oem bracket :confused:
been on eibach.com but its all in German - do you need to drill?
as i recall the post the original is U shaped with wings for the bolts and a bridge across to stiffen and hold the bushing. The Bridge then has to go otherwise it won't work. All of this is off course on the top off my head. Any clues in the Eibach manual??
Did the rears easy yesterday with a Polybush bush but when I tried to do the fronts I had the same problem and couldn't get the bracket apart to fit and gave up (I hate doing that) I have asked my mate and Ill let you know.
Its the same on the S3, front subframe needs removing then the brackets need to be split. The flat plate is sort of peened onto the U section, I ground the peening away using a rotary file, split the bracket then re-used it with the new bush :happy2:
Thats some good info, Gaz. I think my ARB bushes are gone so have been looking at the Powerflex replacement :happy2:
Am I right in saying that the OEM ED30 front ARB is 23.6mm?
Golf V GTI: 23,6 x 3,5 / 21,7 x 3,0 both tube
Front first Rear second.
44AD and 44BV from here:
http://www.polybush.co.uk/shop/view/560_Volkswagen_Golf_Mk5_1K_04-09_Including_R32/794_Kit_144
I may be able to get you a discount on the above as my Garage, Browns Motorsport, has just become a dealer.
Let me know if you are interested?
That woud be great buddy, 44AD for the front :happy2:
If you can get them could you drop me a PM please :wink:
