All Things Mk5 => Mk5 General Area => Topic started by: liver on May 09, 2011, 02:07:58 pm
Title: People with Boost Gauges - Boost Pressure
Post by: liver on May 09, 2011, 02:07:58 pm
im having promblems with my car
it runs fine and very smooth still but is heavily under powered.
It ran 233 bhp and 330 ft/lb or torque on awesome rolling road on saturday. This is a stage 2 golf gti, with bluefin software.
It has a 3" non resonated Milltek TBE and a carbonio induction kit with a piper cross panel filter - (i know this needs upgrading lol)
here is what the car is currently boosting at
1st = -1HG upto 1psi
2nd = 5psi
3rd = 8-10psi
4th = 10-12psi
5th = 15psi
6th = 15-16psi
What sort of boost figures are other people getting.
Heres my graph if this helps, its been suggested to change the PCV system as there are signs of possible leaks around the o-ring
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Ft56%2FLiver89%2FIMG_0204.jpg&hash=8b7c00e44cab0c8b79ddf1227217fc62c26bf91c)
do these figures for boost seem strange?? could it just be the pcv system why im not boosting very high or could it be related to the software
any help is much appreciated
thank you
Title: Re: People with Boost Gauges - Boost Pressure
Post by: bacillus on May 09, 2011, 02:22:26 pm
You really want to log your requested vs actual boost using vcds to see if there is a boost leak or if it's just how the bluefin software is coded.
Post by: vRSAlex on May 09, 2011, 04:22:44 pm
Im on revo stage 2+ and I see 1.7 bar (25psi) through 3rd to 6th.
Post by: RedRobin on May 09, 2011, 06:49:26 pm
I'm on Revo2 and generally my boost gauge shows 22 Hg when engine idling at 7,500 revs and no more than about 22 psi under hard throttle but I need to double check that psi value.
The boost values change rapidly without any lag when driving.
