All Things Mk5 => Mk5 General Area => Topic started by: berg on May 11, 2011, 09:28:42 am
Hi will try scan and post actual print out later but for now -
Left Front -
-1.47 camber
8.36 caster
0.05 toe
Right front - -1.33 camber
8.23 caster
0.05 toe
left rear -1.44 and -1.42 camber
0.05 and 0.06 toe
thrust angle -0.01
I don't understand.. what do you need to know?..
well whether it is set up well, would you be happy with these settings? I dont understand about the geometry aspect at all so it is just gibberish to me.
Thanks.
Unless someone here knows the correct tolerances for a golf it would prob be easier to scan the printout. I'm not sure what the corrects ones are. Does your printout show them being green?..
will try scan printout tonight, ta
Assuming it's a Mk 5 GTI, then Front Camber is OUT of specification. Front Caster is OUT of spec on the left, and only just IN on the right. The Front Toe, however, is safely within spec. The Rear looks all to be within spec. The 'Toe' is generally the 'killer' parameter for uneven tyre wear, so yours looks OK. However, it would be worth a visit to a reliable tyre/alignment outlet to get the front Camber and Caster adjusted back into specification.
thanks
This is worth a read
http://www.nyracer.com/overunder.htm
If you are happy (I'm not) with stock GTi suspension then set up to factory settings. If not you can tweak and go out of 'spec'
