All Things Mk5 => Mk5 General Area => Topic started by: Ducky76 on May 25, 2011, 09:39:56 pm
Title: Any one running 19s
Post by: Ducky76 on May 25, 2011, 09:39:56 pm
Hi people I've just got hold of some 19 s 8.5 et 48 and my car is on ebach sportline springs any one else running similar set up or any one know if it wil work without problems
cheers. Andy
Title: Re: Any one running 19s
Post by: Hurdy on May 25, 2011, 10:39:24 pm
You'll need to do the arch screw delete mod on the front wheels. Even then you may still rub under compression. :smiley:
I had BBS CH 19"s on 235/35/19 tyres and Eibach coilovers. You may get away with it if you go for a bit of stretch on the rubber and use 225 section rubber. :happy2:
Post by: gazbutS3 on May 25, 2011, 11:15:57 pm
the 8.5 width will stretch a 235 further than the 8" wide CH so will help, 225's a bit narrow for an 8.5" rim IMO
Post by: Dario on May 26, 2011, 02:55:28 am
225 is good on 8.5 i have it,doesnt look streched
Post by: Ducky76 on May 26, 2011, 07:22:06 am
Ok cheers then will just have 2 see then ,they come with 225 35 s so hopefully no probs
