All Things Mk5 => Modifications & Technical Area => Sat Nav and Car Audio => Topic started by: Richn83 on June 01, 2011, 03:58:06 pm
Title: VW plug connectors part numbers and schematics
Post by: Richn83 on June 01, 2011, 03:58:06 pm
Title: Re: VW plug connectors part numbers and schematics
Post by: vRStu on June 01, 2011, 04:03:37 pm
Each plug you want to connect to will have a P/N.  From that number you can normally retrieve the opposite and the appropriate repair wires.
Post up the details you have.
This may also help - http://sites.google.com/site/nsxjraudi/downloads
Post by: alexperkins on June 01, 2011, 04:10:23 pm
Aye as stu says, post up the part numbers and one of us can get the details from ETKA
Post by: Richn83 on June 01, 2011, 04:14:07 pm
Thanks guys,  will have a look at the opposite ends and check the numbers on them and revert back to you just need to dig the old speakers out of the cupboard.  The audi pin connector is a good resource cheers Stu.  :drinking:
Post by: Richn83 on June 01, 2011, 05:15:54 pm
Just found a couple of useful things on my further travels after the part nnumbers on your link stu!
http://www.passatplus.de/umbauteile/stecker/stecker.htm (http://www.passatplus.de/umbauteile/stecker/stecker.htm)
lots of other good part numbers and pictures as well  :happy2:
Post by: Richn83 on June 02, 2011, 10:37:44 am
So I have tracked down the wiring schematic for the drivers door on the car and so the proper part numbers for the connectors, the next part of the puzzle is what size connectors work in the clips:
cross over, 12 pin, 6Q0 972 726
Tweeter, 4 pin, 3B0 972 732
mid range, 3 pin 1T0 972 703
Loud speaker, 4 pin 1J0 972 704
Also 191 972 714 which I believe is the opposite of the 1J0 972 704 part.
The wiring will be like this excuse the rough diagram so the sound intake to the cross over from the original wiring to the main speaker into the cross over and then out to the speakers again. So I think my best bet is to buy the individual connectors and a roll of wire and I will use my car wiring which appears to be colour coded to determine the terminal pin out on the cross over.
(https://lh3.googleusercontent.com/-v6ETGdxUemM/TedZRAC3IYI/AAAAAAAAAmc/ZeQpNBMHngs/s720/layout%2525201.jpg)
If you could let me know the appropriate repair wires that would be excellent  :drinking:
