All Things Mk5 => Modifications & Technical Area => Sat Nav and Car Audio => Topic started by: JCMUSCLE on June 06, 2011, 03:36:54 pm
Title: Rns510 canbus upgrade?
Post by: JCMUSCLE on June 06, 2011, 03:36:54 pm
Have a 2007 gti dsg
Comes with standard rcd300 and looking at a 2011 rns510 v c
Read threads about battery drainage issues?
How much would it cost to upgrade the canbus ?
Title: Re: Rns510 canbus upgrade?
Post by: Eddie-NL on June 06, 2011, 05:16:42 pm
Hi
Where are you located?
Post by: alexperkins on June 06, 2011, 05:22:35 pm
Have a 2007 gti dsg
If its a 2007, you may well be ok. What month was it - generally anything after March is fine  :happy2:
Post by: JCMUSCLE on June 06, 2011, 06:13:00 pm
Located in cambridge
Yes was made/registered march 07
Post by: Eddie-NL on June 06, 2011, 06:17:53 pm
Ideally you need to have your car scanned with Vag-com so you can see what you have. As said earlier you may be lucky and don't need to upgrade.
If you buy the gateway from the dealer new then it would cost around £130 or you can buy one from ebay for less
You will need someone with Vag-com to code it
I'm not too far away in Great Yarmouth if you need it fitted and coded
Post by: JCMUSCLE on June 06, 2011, 06:23:03 pm
Ok thanks il keep that in mind
Whats the oldest version gateway that will take the rns510 without battery probs?
What do i ask for exaxtly at the stealers?
Any specific module/canbus, newer the better i presume?
Post by: Eddie-NL on June 06, 2011, 06:50:06 pm
K version and above
I would stick with the newer ones
Post by: N13KKF on June 24, 2011, 12:45:25 am
Its Really Revision L or above some Revision K will be fine but others will not. Vw charge about £150 for a can gateway. i can supply gateways for £100 plus fitting. im near Romford if its any use
Nick
Post by: DaveR77 on June 24, 2011, 08:25:25 am
Mine is Jan 07 (K) and was fine, I'd definitely try it first before buying a new gateway
Post by: N13KKF on June 24, 2011, 08:53:20 am
yeah try it first. you could always run modified fw2760 giving you no battery drain and still having 7 digit postcode
