All Things Mk5 => Modifications & Technical Area => Performance Modifications => Topic started by: lacey123 on June 07, 2011, 11:51:15 pm
Hi guys. I put a set of kw coilovers on the car last week and the front wheels seem too be rubbing but it's at the height o want it.. Is there anything o can do too stop this without adjusting the height?
are they 1,2 or 3 ??
if 2 or 3 stiff it :)
also remove the plastic bit at the inside of the fenders
As mentioned above,remove the torx bolt at the top of the wheel arch lining
