All Things Mk5 => Mk5 General Area => Topic started by: mrbeck on June 08, 2011, 02:59:36 pm
Title: Key Query
Post by: mrbeck on June 08, 2011, 02:59:36 pm
Okay, so got in the car last night to drive home and no problems, car opened as usual with the unlock button on the key. Got home, tried to lock the car with the lock button and nothing. Red light still flashed on the key, but doors would not lock. Tried the unlock and boot buttons too but still nothing.  I'm thinking its the key battery need replacing but would the red light still flash if it was flat?
If it is the battery, which one do I need to get hold of and how quickly do I need to change it over?
Thanks!
Title: Re: Key Query
Post by: mrbeck on June 09, 2011, 05:23:41 pm
Bump
Post by: bacillus on June 09, 2011, 05:34:54 pm
What happens if you try using the second key (assuming you were supplied with two)?
Post by: mrbeck on June 09, 2011, 07:08:48 pm
Second key works as normal, so I don't think there's a problem there.  Just can't figure out why the light flashes on the first key, but the car won't open.
Post by: bacillus on June 09, 2011, 07:12:04 pm
In that case change the battery...
Post by: mrbeck on June 09, 2011, 07:16:46 pm
Cheers... will try that tomorrow.  Don't suppose you know which battery I need?  And how quickly do I need to swap it over?  I've read things about keys losing their coding if the battery is out for too long.
Post by: bacillus on June 09, 2011, 07:20:21 pm
You need a CR2032 battery.
Here's how to open up the fob, http://www.riskin.org/vwkey/
Post by: mrbeck on June 10, 2011, 05:16:24 pm
Have now changed the battery, but still no joy.  The LED on the key flashes, but the car won't lock/unlock.  Key still works in the ignition though, so I am stumped.
Any other suggestions welcome!
Post by: alexperkins on June 10, 2011, 05:18:45 pm
You may need to repair it to the car.
Instructions are in the Owners Manual
Post by: mrbeck on June 10, 2011, 05:24:37 pm
Cheers! Will give it a go now and see what happens.
Post by: StephenED30 on June 10, 2011, 05:29:32 pm
This is for the Mk 4 but i think it works on the Mk 5 as well.
Post by: mrbeck on June 10, 2011, 05:33:37 pm
All sorted - just needed synchronising as per the Owner's Manual.  Press the unlock button on the fob, then unlock the door within one minute and BINGO, key works properly again!
