General => Detailing => Topic started by: cossy on March 16, 2009, 07:00:15 pm
Title: Best product to clean the honeycomb front of GTI?
Post by: cossy on March 16, 2009, 07:00:15 pm
Hi,
Apart from wiping around each part of it is there an easier way?
And what product/s best to keep it black?
Cheers :jumping:
Title: Re: Best product to clean the honeycomb front of GTI?
Post by: vwrascal on March 16, 2009, 07:10:16 pm
I wipe each part, that is the only way! time consuming but worth it!!    :happy2:
Post by: Greeners on March 16, 2009, 08:43:37 pm
I was thinking about posting this question after cleaning mine this weekend.
I suppose a 'back to black' type product would do the job. A gel type impregnated on a MF maybe?  :happy2:
Post by: Moschops on March 16, 2009, 08:47:25 pm
Unless it's really clean "back to black" seems to build up in the nooks and crannies and starts to look pants after a while as all the traffic filem seems to stick to it.
Geta good jet wash on it first to give it a real good clean, then as VWRASCAL states, wipe each part, then back to black it.. :happy2:
Post by: Shaun on March 16, 2009, 08:48:45 pm
There is a brilliantly simple solution to this.
Use Autoglym Instant Tyre Dressing. Wash car (and you dont have to wash the honeycomb parts beyond running a sponge / mitt over the front)... rinse off... whilst it's still wet simply spray this on and leave it to dry. Perfect black finish every time and no effort at all!
If you haven't tried it you won't believe me - trust me it really is this simple and the result is perfect every time.
Go on.......
Post by: VWTroy on March 16, 2009, 08:56:39 pm
Go on.......
Now that's one I'm going to try, well done that man :happy2:
Post by: Moschops on March 16, 2009, 09:14:12 pm
Go on.......
Cheers... :happy2:
Post by: stealthwolf on March 16, 2009, 09:38:38 pm
Is there any way you can 'protect' the grille so it's easier to clean the next time? Like PB's wheel sealant for alloys?
Post by: garethmk1 on March 17, 2009, 12:58:14 am
Go on.......
The AG Tyre Dressing works great I prefer using AG Vinyl & Rubber Care - seems to stay a little longer !  :happy2:
Post by: john_o on March 17, 2009, 07:49:45 am
similar thing for me I just use the Megs Tyre Gel + sponge , it is a pain though.....
Post by: Shaun on March 17, 2009, 11:32:38 am
AG Vinyl and Rubber Care is good, Gareth, but you can't just 'spray and go' like you can with the ITD! Agree it lasts longer but I spray the ITD after each wash (at least once a week) so it only has to last a few days!!
Post by: matsu on March 17, 2009, 12:57:31 pm
tried using mine today in just one part-def made a difference. is there a knack of spraying it ? as it laid on there all white for a while? but came good in the end.
cheers
matsu(idiot newbie) :embarrassed:
Post by: Shaun on March 17, 2009, 07:03:18 pm
There's no special technique to spraying it... it will always hang around in white puddles 'till it dries. Obviously this takes less time the warmer the weather is. I have found that the more rinse water you leave on before spraying on the product the better the result, though.
Post by: Greeners on March 17, 2009, 09:38:03 pm
I'll give this a go but won't be spraying as it will get all over the bumper.  :happy2:
Post by: autoperfection.com on March 18, 2009, 11:15:21 am
Hi
There is a product called Black WOW - it works great on this area - althought time consuming it puts a protective barrier on the plastic - water even beads off. makes cleaning much easier - although the autoglym method works great too....
JIM
Post by: Moschops on March 18, 2009, 06:06:07 pm
Hi
JIM
Jim do you sell this stuff? :signLOL:
Post by: autoperfection.com on March 18, 2009, 07:18:39 pm
Hi Wayne
Yep we do sell this - although the first batch is yet to arrive. Will be here very soon Ill keep you posted
JIM :happy2:
Post by: Moschops on March 20, 2009, 05:24:27 pm
^ Ta  :happy2:
Post by: djk112 on March 20, 2009, 07:11:40 pm
Black wow is a winner!!!
I use that stuff, got it off the flea bay a couple of months back  :happy2:
Dan
Post by: keith on March 21, 2009, 10:12:56 pm
Go on.......
Thats what i currently use, OR you could try Silicone spray from halfrauds its in the motorbike section used to be in a yellow tin with grey top, good for all black trim, spray on the cloth wipe over and lasts a fair bit to.
Post by: JPC on March 23, 2009, 02:56:11 pm
black wow or 303 protectant but carefull spraying!
