All Things Mk5 => Mk5 General Area => Topic started by: Geoffcarragh on July 01, 2011, 01:54:53 pm
Title: Advice on new brakes
Post by: Geoffcarragh on July 01, 2011, 01:54:53 pm
I see eurocarparts are offering a 30% discount to forum members.
http://www.mk5golfgti.co.uk/forum/index.php/topic,31224.0.html
I am going to replace discs and pads all round. I'm not interested in big brake kits or upgraded drilled/grooved discs so I want the standard set up.
Are these sizes correct?
Front disc = 288mm x 25mm thick (internally vented)
Front pad = 14mm thick with wear indicator
Rear disc = 260mm x 12mm thick
Rear pad = 11mm thick
Would you recommend Pagid or ATE.
Title: Re: Advice on new brakes
Post by: bacillus on July 01, 2011, 02:18:20 pm
If you have a mk5 gti then fronts are 312mm and rear 288mm.  :smiley:
Post by: Geoffcarragh on July 01, 2011, 03:34:52 pm
Cheers, yea I have a Mk5 GTi.
I got those sizes from a google search. they must be for a smaller engine golfs?
What sort of pads do I need to get?
