All Things Mk5 => Modifications & Technical Area => Sat Nav and Car Audio => Topic started by: MaverickFSI on July 10, 2011, 02:43:01 pm
Title: RNS510
Post by: MaverickFSI on July 10, 2011, 02:43:01 pm
What is the difference between the version B & C of this head unit? I've currently got the version C in the Scirocco and have never used the unit in the Mk5 Golf. There seems to a difference in price, is that because version C is LED?
Found some on eBay;
http://cgi.ebay.co.uk/VW-VOLKSWAGEN-RNS-510-SAT-NAV-RNS510-Version-C-LED-/200627193732?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item2eb6500784 - Version C
http://cgi.ebay.co.uk/VW-SAT-NAV-DVD-RNS-510-MFD3-B-VERSION-/220810122178?pt=UK_Audio_TV_Electronics_In_Car_Entertainment_GPS_In_Car_Audio_Players_PP&hash=item33694f13c2 - Version B
Cheers.
Title: Re: RNS510
Post by: sam on July 10, 2011, 02:48:38 pm
Yes correct!!!! :happy2:
Title: Re: RNS510
Post by: MaverickFSI on July 10, 2011, 03:50:13 pm
Thanks for the confirmation bud  :wink:
Title: Re: RNS510
Post by: Leonard on July 10, 2011, 04:39:31 pm
For info if your MK5 is pre March 2007 you may get battery drain problems with the version C...
Matt
Title: Re: RNS510
Post by: MaverickFSI on July 10, 2011, 04:52:38 pm
Matt
Hi Matt, yes I have just read that in a monster thread regarding the definitions of the A, B & C variants of the RNS510.
At this stage I couldn't tell you the exact month of production as I haven't picked my Ed30 up from VW yet, this Thursday  :party: :jumpmove: :pomppomp: :happy2:. It's a 57 plate.
Are there any people on here who can fit them? Once I purchase one, I'd be very interested to watch and be the on site tea boy  :signLOL: I've never pulled one out nor have the correct tools to do so, so for the first time I'd rather seek the guidance of someone who knows what they are doing.
I've currently got a Scirocco TDI 140PS and that has, it seems, the C version, which I think is wicked. However, am I right in saying that you can get a LCD & LED C version?
Title: Re: RNS510
Post by: LouCyffer on July 10, 2011, 04:56:28 pm
SteveP, MortyGTTDi, vRSCarl.......
Actually, the physical fitting can be done by most folk with a bit of patience. It's straightforward.
Have a look at
http://www.r32oc.com/tutorials-guides/18955-rns-510-mfd-install-how-guide-inc-pin-swap.html
http://www.my-gti.com/2564/upgrading-2nd-generation-headunits-rcd-300-rcd-500-mfd2-to-3rd-generation-headunits-rcd-210-rcd-310-rns-310-rns-510-rcd-510
http://www.my-gti.com/2484/installing-gps-antenna-inside-dash-in-the-volkswagen-golf-and-jetta
to start you off.
You may need an aerial adaptor if you're starting with a second gen head unit. See:
http://www.my-gti.com/1088/upgrading-2nd-generation-radios-rcd-300-rcd-500-to-3rd-generation-rcd-210-rcd-310-rns-310-rns-510-rcd-510-antenna-adapter
The Partnumber is 7L6 051 551 and having asked my local dealer, they catagorically stated no such part existed. Having found the above link I went back and made the parts flunky look stupid (not difficult). :evilgrin:
Title: Re: RNS510
Post by: Leonard on July 10, 2011, 05:31:34 pm
It is really easy to fit, dont be afraid to do it yourself. Probably take 30 mins and Im pretty sure you will need the aerial adaptor.
I just stuck the gps antenna underneath the top climate cover on the dash (plenty of room on left or right hand side) and reception is fine.
Matt
Title: Re: RNS510
Post by: MaverickFSI on July 10, 2011, 06:04:00 pm
Have a look at
to start you off.
Great links mate, nice one  :happy2:
Title: Re: RNS510
Post by: MaverickFSI on July 10, 2011, 06:06:03 pm
Matt
Cheers Matt, I'll bear that in mind  :happy2:
Title: Re: RNS510
Post by: LouCyffer on July 10, 2011, 06:20:54 pm
Your welcome, Mav. Mine was self-fitted, no VCDS coding necessary. And by the way, the aerial adaptor is about £28 for two bits of wire :confused:
Title: Re: RNS510
Post by: MaverickFSI on July 10, 2011, 06:34:12 pm
Cool. So if I buy one off eBay brand new, for example, will it need coding or will it just literally plug 'n' play? Yeah, when I read the installation thread you posted and saw the cost of the two lengths of cable I thought it was abit expensive like, how much is VW tax these days, damn!
Title: Re: RNS510
Post by: stealthwolf on July 10, 2011, 07:05:50 pm
VCDS means you can tell the car it's there, so it comes up on the highline dash and you can use the mfsw. If you don't have those, you can probably get away without the need to code it.
Fitting is easy but trying to do it withouth breaking any dash clips is a bit more challenging. :innocent:
Title: Re: RNS510
Post by: MaverickFSI on July 10, 2011, 10:34:54 pm
Based on that Stealth it will need coding then, as I have the MFSW set up. How do I go about that then? Dealers or does someone possess the software to code the headunit to the car?
Gracias.
Title: Re: RNS510
Post by: stealthwolf on July 10, 2011, 11:13:56 pm
Have a look in the VCDS Register thread. Hopefully there's someone close enough to help out.
Title: Re: RNS510
Post by: LouCyffer on July 11, 2011, 08:17:51 am
I think Eddie-NL is your man for the Nolfolk area
Title: Re: RNS510
Post by: DBR16GTI on August 11, 2011, 01:32:40 pm
Sorry to hijack this thread but I was just wondering, after reading the above, if I bought an RNS510 off ebay would I need a new canbus or have it set up with VCDS?  My gti is a 2005 manual with the midline dash.  Also which version?  Is C the newest therefore better? or does it really matter?
Thanks.
Title: Re: RNS510
Post by: LouCyffer on August 11, 2011, 01:40:12 pm
If your canbus is K or earlier, you'll need a new one. It's highly likely that a car of this age will have this early canbus. C versions have an LCD screen, you can tell them by the 'star' button on the top right of the unit. Earlier versions have a speaker icon on the button.
Title: Re: RNS510
Post by: keano on August 11, 2011, 03:12:00 pm
How do we know what canbus we have?
*this could prove to be a v.expensive reply for me*  :grin:
Title: Re: RNS510
Post by: LouCyffer on August 11, 2011, 04:30:21 pm
It's a VCDS scan, mate.
Early 2007 and earlier usually needs a canbus switch. I think Kalu was talking about being able to flash the software on it rather than physically changing the unit. PM him & ask, he's a top guy, very helpful.
