All Things Mk5 => Modifications & Technical Area => Sat Nav and Car Audio => Topic started by: StephenED30 on July 17, 2011, 03:09:24 pm
Title: MDI
Post by: StephenED30 on July 17, 2011, 03:09:24 pm
Can some one please with this fault,
Sunday,17,July,2011,14:36:27:54527
VCDS Version: Release 10.6.4
Data version: 20110418
                Address 2E: Media Player 3       Labels: 5N0-035-342.lbl
Control Module Part Number: 5N0 035 342 D    HW: 5N0 035 342 D
  Component and/or Version: SG EXT.PLAYER H13 0150
           Software Coding: 010000
            Work Shop Code: WSC 00028 028 00001
                      VCID: 285510EAE263
1 Fault Found:
03138 - Input AUX IN
            009 - Open or Short to Ground
             Freeze Frame:
                    Fault Status: 01101001
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 138
                    Mileage: 42295 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 14:33:58
I know i need to change some wires around on the quadlock but which ones.
Title: Re: MDI
Post by: Eddie-NL on July 17, 2011, 04:11:37 pm
Hi
have you recently fitted this?
If you have does it actually have the Aux-in?
Title: Re: MDI
Post by: StephenED30 on July 17, 2011, 04:54:55 pm
Hi Eddie, I fitted it about 6 weeks ago but have only just got around to sorting this problem out. How do I tell if it has the Aux-in as when I take the √ from the box under 2E: Media Player 3 I still get the problem.
Title: Re: MDI
Post by: Eddie-NL on July 17, 2011, 05:24:35 pm
Go into the coding for the RNS510 and uncheck the aux-in and reboot it
Title: Re: MDI
Post by: StephenED30 on July 17, 2011, 06:14:03 pm
Thanks Eddie, if you mean Byte 0 Bit 2 them it is unticked, if I go into  2E Media Player in Byte 0 Bit 0 Analoger Input (AUX-In) installed and take the √ out it will not accept the code as it is all oooooo, at the moment it is 010000.
Title: Re: MDI
Post by: Eddie-NL on July 17, 2011, 06:21:13 pm
010000 is what I have in my mdi without AUX-in no faults. What loom did you use?
Title: Re: MDI
Post by: StephenED30 on July 17, 2011, 06:23:17 pm
Loom that was supplied with it. All works and do not have any sound problems, just this fault.  :happy2:
Title: Re: MDI
Post by: GLIDN on July 18, 2011, 03:53:31 am
Log into Radio Code 56, And disable IPOD/AUX. I'm pretty sure that is where your problem would be.
Unless you have RNS510, That I would only be guessing i'm afraid that you would have to look in Navigation perhaps?
Will pull up my codes tonight, and post them if you like?
Title: Re: MDI
Post by: StephenED30 on July 18, 2011, 08:04:28 pm
No tick in the CD/IPOD/USB under 56 radio.  I have the RNS 510 and its the same under 37 navigation.  :sad1:
Title: Re: MDI
Post by: GLIDN on July 19, 2011, 09:25:14 am
Even if you use long code helper?
If need be, PM I maybe able to help you remotely if you like? But you need a stable internet connection to your laptop/pc with vag-com plugged into the car.
Title: Re: MDI
Post by: StephenED30 on July 24, 2011, 05:47:37 pm
Well a big thanks to GLIDN for having a look at this, using the remote access software he has and all the way from New Zealand. Nice chatting with you over the internet. Didn’t get to the bottom of it so still under investigation?  :happy2:
Title: Re: MDI
Post by: GLIDN on July 24, 2011, 10:27:25 pm
Yeah sorry we could not get sorted,
All his coding was correct. When I get a chance I will check wiring and let you know, unless I find the answer first. Lol
Title: Re: MDI
Post by: Eddie-NL on July 28, 2011, 06:49:46 am
Strange as I had this problem, when I fitted a D version. Tried to remove the Aux-in from the media player wouldn't accept the coding. yet on my B version it doesn't throw the fault
Title: Re: MDI
Post by: GLIDN on July 28, 2011, 07:04:47 am
Very Interesting what you mentioned here. I compared mine Also B version to his D version. The error is on the MDI specific, nothing in the can-gateway, Radio or NAV.
Wondering if I should upgrade the firmware on my B?
Title: Re: MDI
Post by: alackofspeed on July 28, 2011, 11:45:51 pm
Mine is the same too - won't accept coding to disable the aux in. If it weren't for vcds I'd be unaware as in all operational respects everything is fine.
Title: Re: MDI
Post by: GLIDN on July 29, 2011, 02:59:07 am
is your MDI factory fitted? or did you install the MDI?
Do you have the glovebox version or centre console MDI?
Title: Re: MDI
Post by: Eddie-NL on July 29, 2011, 06:57:38 am
another option is to fit the aux-in socket
fairly cheap and easy to do
Title: Re: MDI
Post by: alackofspeed on July 29, 2011, 07:50:33 am
I have a 2007 MY GTI with RNS510-Cand MDI (can't recall the code, but it was brand new from VW only days ago) behind the dash.
Title: Re: MDI
Post by: GLIDN on October 26, 2011, 04:23:45 am
Finally pulled all my MDI kit out, I have no wires disconnected/unconnected in the Loom.
However we install my whole kit into a passat last week. As soon as the VW Factory bluetooth kit wiring was added to the MDI loom and daisy'd off the MDI Can-gateway wires.
We found funny errors codes in VCDS under the MDI kit.
Hope this helps.
