General => Random Chat => Topic started by: Andy on July 18, 2011, 11:26:15 am
well my turbo looks like it has gone again as its chucking out blue smoke at round abouts and pulling away from junctions,this is the 4th time now :fighting:
SERIOUS!!!! Are these brand new Turbos your fitting or used and refubed? Doesn't sound right :mad:
the turbo had only done 6000 miles since the last time it went so i got it refurbed,they said it was the oil seals in the turbo--it had new oil feed pipes put on
jus go down darrens route then :evilgrin: :evilgrin: :evilgrin: :signLOL:
Remind me... who did the refurb? CR or TD?
Not good andy, but hybrid is the only way now ! :popcornsoda:
Time to sell it perhaps.
The refurb was done by midland turbos ..Not give up on it yet Steve :signLOL:
Good luck Andy, hope it's not of major expense. :happy2:
yh u cant just throw in the towel steve :laugh:
Holy sheeite andy totally gutted for you!!!
i think it may be better for you to go the hybrid route just like darren!!!
scott
Andy sorry to hear about this mate, seemed fine on Saturday :confused: but I guess that's how quick it can change, mine had no symptoms or anything before it went.
If you need any help with contacts mate just let me know. Yours would be ace with the hybrid and miltek :happy2:
Darren
Hybrid time :jumping:
Cant believe it has gone again :confused:
the vw diesel turbo's seem pretty pants 2 me
Thought it was a bit smokey with blue in it when i reversed up to Pdt door to go on the rollers---
Darren pm me the cost of your turbo if you don't mind
the cars are good just the crap turbos vw put on them :signLOL:
^^^^^ ooops thats wot i ment :ashamed:
Sorry to hear this,
Darren Andy :sad1:
Maybe you need a oil restricter in the turbo? Just a thought..
it was me Damo not Darren :signLOL:
Was reading Darrens reply just before I posted and thought I'd put you name down, Andy :doh: :ashamed:
When you've had turbo's replaced have you had the oil pump etc checked??
Common issue with TDi's that have been on variable servicing.
had it checked a week before it was done :happy2:
http://www.ebay.co.uk/itm/Audi-VW-Seat-Skoda-k04-Hybrid-Turbo-Direct-fit-Look-/230648453242#ht_500wt_922
Don't know if that will fit, it's only £180
Thats a K04 for the older 1.8t so no good for the diesel
Darren
Oh well :signLOL:
update 2/08/2011
well my turbo is on its way back and been told its fine--so the next step is to check the breather on top of the rocker cover
Good news mate, check all the boost pipes? I had damage on the rubber 90 degree pipe that comes from the turbo and quite a bit of smoke, also check and clean the EGR valve they get really gunked up.
Darren
cheers Darron will check them,cleaned the egr valve out 2 months ago,also going to change the rocker cover breather
update again :signLOL:
the turbo came back with a report to say check
There is oil evidence of oil leakage into the turbine housing volute.This is because the oil entering the turbocharger bearing housing is not draining back into the sump at the currect flow rate using the turbo chargeras a secondary breather..The most common cause of this is a restricted engine breather/excess crank case compression.Restricted drain back...
I have replaced the rocker cover with the breather in as you can't buy it seperate..i was told of vw this is the only breather on the pd engine
Have they done a cylinder compression test?
They did one and they said it was ok
