All Things Mk5 => Mk5 General Area => Topic started by: berg on July 18, 2011, 04:39:46 pm
Title: 50mm or 55mm front damper diameter?
Post by: berg on July 18, 2011, 04:39:46 pm
Hi guys, I need to find out which one is on my 57 08 plate ED30 before can order correct b12 kit?
Can you tell by chassis number or do you actually have to measure the damper with a tape measure?
Thanks.
Title: Re: 50mm or 55mm front damper diameter?
Post by: big al on July 18, 2011, 05:42:05 pm
Believe GTI's will be 55mm.
 :smiley:
Not 100% sure though
Post by: ali6n2 on July 18, 2011, 06:12:41 pm
yep, they should be 55mm on an ed30
Post by: berg on July 18, 2011, 06:31:13 pm
thanks chaps, the forum speaks volumes once more
