All Things Mk5 => Mk5 General Area => Topic started by: m4t_lee on July 19, 2011, 02:06:17 pm
When sat at lights idle is fine but everso slightly 'bumpy' if that makes sense, any clues as to what i should check?
Cheers,
Mat
PCV valve has been know to cause symtoms like those when failing. If you remove it you should only be able to blow through in one direction and if both then it needs replacing. Would suggest if it is that getting a bsh revamp kit or a catch can system :happy2:
Thanks chap, where can I find the valve and what does it look like?
Follow the ribbed hose that attaches to the right side of the intake manifold (looking at the engine); at the other end is the plastic pcv...
mine has the pcv revamp kit on it.
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Fn28%2Fjonny_boy_01%2FP1070277-1.jpg&hash=caf9aa68345722c29fa50b4ab0cb000b965873f6)
Also heres a link to the place i bought mine from :happy2:
http://dubtek.co.uk/index.php?main_page=product_info&cPath=22_32_33&products_id=251
