		All Things Mk5 => Modifications & Technical Area => Technical Workshop => Topic started by: G-Lader on August 04, 2011, 12:31:13 pm
				Hi,
 Looking to make some improvements to the standard 288mm brakes fitted to the wife's GT TDi......
 Does anyone know if the 312mm caliper carriers found on the Mk4 Golf / TT /S3 etc will fit onto the Mk5??
 Fingers crossed it's a yes as I plan to remove all of the mods on her Mk4 1.8T shortly so would just require new discs.
 Thanks!
 Des.
				I belive so, I had a spare set of s3 brakes for my A3 when i first bought my golf and the caliper and carriers looked exacty the same,
				That would work out spot on if they're the same.......
 I'll give them a try on the Mk5 when I remove them off the Mk4.
 Thanks.
