All Things Mk5 => Modifications & Technical Area => Cosmetic/Interior Modifications => Topic started by: Jungle_Faced_Jake on August 05, 2011, 12:02:43 am
I want to do a reversed rear badge i.e. black logo on silver background. Am thinking of getting a new badge and respraying it silver then getting some black vinyl wrap for the logo and carefully cutting with a sharp craft knife around the logo to reveal the silver background. Has anyone else tried this and do you have any tips about best way of doing it? Would then spray with a few coats of matt or satin laquer to finish off. My other question is about removing the old badge. Is this easy to do without damaging the whole mechanism or is it a case of getting an entire new mechanism and modding that? If not what is the best way of sticking the new badge on to the existing mechanism once I've got the old one off?
Sounds like a good idea mate, I have just put black vinyl in the gaps which was quite tricky. As to removing the rear badge, it can be done but you risk breaking it, probably easier to remove the whole mechanism. :happy2:
It depends on which badge you have i think! Mine is a 3d one which came off with a trim tool pretty easily!
MMmmmm doing this myself soon.
The front badge pops off...easy, but I honestly thought the rear badge was in two parts - (background and VW stuck on top) and you could seperate easy enough?
Guess this is not the case?
Mine is the one with the VW badge and a background under. My brother wrapped my background whilst it was on my car!
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Fll78%2FRsam_2008%2FIMG_0525.jpg&hash=5ba8abede12b93b14709ed8e60477d0a439a3440)
The badge should hopefully just go over the top!
vw part just pops/clicks off?
It should do, depending on your badge. Flick the badge as if you were going to open ur boot, is there a little lip there? It should just prise off! Is your badge 3d or is the VW part flat against the background?
Mines 3d type. Used to have the flat one......i.e. all in one
here are the rest of the pics:
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Fll78%2FRsam_2008%2FGolf002.jpg&hash=088a6b3c9cd93312c084f65ea88caf7a48507a11)
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Fll78%2FRsam_2008%2FGolf003.jpg&hash=5353f25eb923e3de0012e87b643ddeeae267fe0e)
to get it off when you push the badge up you can see a little hole at the base you just need to be really careful and prise it off! its got a few clips holding it on on the VW section
Ooooh that is beautiful dude. I've now decided I want black on black like this after doing a mock up in photoshop. My badge is the flat type so I guess I need to get hold of a 3D one. Will that mean getting a complete new mechanism or can I pop the old badge off and stick a 3D one on?
I think it usually means a new badge, as the rear ones on ebay may well stick out too far off the background!
