All Things Mk5 => Mk5 General Area => Topic started by: bacillus on August 07, 2011, 08:21:34 pm
http://forums.vwvortex.com/showthread.php?5390997-Proof-That-Rev-D-DV-Holds-Boost-Less-Effectively-on-06-GTI
Indeed, I must say from my point of view, even if the rev D is slightly less efficent, I wouldn't know, as my original DV had a sodding great split in the diaphragm.......... :smiley:
I'll be checking my past logs at some point :happy2:
Hmmm, and here I was, thinking that I had wasted my money on a Forge DV (although OEM Rev D wasn't out at the time).
I don't expect that VW are interested in whether performance modders care about their Rev D. VW will have designed it for the common market.
It may be slightly behind but as mentioned in the post it doesnt over boost, also interested to know how the guy did comparitive back to back runs and have different temps. Also surely there is an element of adaptation for the ECU when you change out the DV as it adapts the map?
