All Things Mk5 => Modifications & Technical Area => Sat Nav and Car Audio => Topic started by: RoMocop on August 07, 2011, 10:53:41 pm
Title: Bits I need to retrofit RNS
Post by: RoMocop on August 07, 2011, 10:53:41 pm
I am thinking of upgrading my basic rcd300 to the rns510 sat nav unit at some point. I was just wondering what other bits I will need apart from the unit. Will I need to buy a shark fin aerial or similar? Cheers.
Title: Re: Bits I need to retrofit RNS
Post by: stealthwolf on August 07, 2011, 11:11:10 pm
Nope. Just the gps antenna. Potentially the radio antenna adaptor but given the cost (£26 when I last looked a few years back), you go without this.
Might be worth getting some sticky pads to stick the antenna. Under the centre diffuser is the best place.
Post by: DamoP on August 07, 2011, 11:19:49 pm
the radio antenna adaptor is £15 on ebay . you may need a new can bus gate way depending on the year of your car
Post by: LouCyffer on August 08, 2011, 07:12:42 am
Part number for aeriel adaptor & guide to retrofitting here: http://www.mk5golfgti.co.uk/forum/index.php/topic,32067.msg396594.html#msg396594
