All Things Mk5 => Modifications & Technical Area => Technical Workshop => Topic started by: DaveR77 on August 08, 2011, 07:08:35 pm
I've got the following fault. Googling the fault suggest that the system needed topping up but I've been to Kwik Fit who informed me it was almost full. Next step is to check the low pressure sensor, does anyone know where this is located?
Address 08: Auto HVAC
1 Fault Found:
00229 - Refrigerant Pressure
002 - Lower Limit Exceeded
bump
Only a guess but, on the pump?
Turned out to be the high pressure switch incase anybody else comes across this fault.
£45 fitted from VW Leeds, bargain :happy2:
