		All Things Mk5 => Mk5 General Area => Topic started by: Russ_leeds on August 09, 2011, 08:01:47 pm
				took the car out last night had 3 mates in the car. i noticed when at wot in 3rd and above the car was stuttering almost i could feel the power drop out then come back then drop out then come back.
 Any one got any ideas? coilpacks? sparkplugs?
 cheers
 Russ
				Could be soft limp mode!
 Suggest you do some logging with vcds  especially of fuel rail pressure requested vs actual and misfire count.
				snap fella noticed the same sort of story seems only over 60 or when pulling hard got mine booked in friday at vw one of my mates said may be something with the power boost vavle shall let u knoe how i get off lol hope it aint dear lol
				ok cheers. i took it out last night and it didnt seem as bad. anyone fancy doing some logging for me for some beer tokens?
 any other ideas?
 cheers
				Mine did this in all gears and turned out to be a duff plug.  Id get the car scanned and see what fault code appears.
				as was mine.....nackered plugs waaay before service due :ashamed:
 matsu
				cheers for the replies. i know this has been discussed before but is it worth putting uprated plugs in or just stick with the standard ones? how much should i be looking to pay?
 cheers
				standard plugs for a stock unchipped car.   :happy2:
				its stage 1 with an itg fitted mate
 Using standard plugs at this stage is recommended.
				Ok cheers
				I have had the recommendation to chnage my plugs every 10,000miles running at S2+ using OEM plugs.
				lol took vw 2 days at 80+ hour only to find out duff plug but did hav 4 new coils under recall cost just over 200 mark  also mine was well under due date 4 change not a happy chappy
				rite nasir is going to do some logging for me this weekend, which blocks do i need to log?
				anyone? im meeting him at about 4 so could do with knowing which blocks to log
 cheers
				log blocks:
 020  correctional factor on cylinders 1-4
 115  to monitor boost
 230  Fuel Rail Pressure
 015 and 016 Misfire counter
 Get him to do a fault scan before any logging.
				Cheers mate I'll post logs up as soon as I can
