All Things Mk5 => Modifications & Technical Area => Performance Modifications => Topic started by: E30Dom on August 15, 2011, 05:40:55 pm
Are They a good upgrade notice a big difference?
Dom
Yes.
:confused: thought you had an r32 once :confused:
I did, and the GTi brakes are shocking compared, but that would have had bigger rear brakes and four wheel engine braking, but is heavier, so trying to imagine... trying to decideed whether to keep and fit or sell... :signLOL:
Keeeeeep iiiiiiiiiT ! :signLOL:
and yeah they make a big difference
Yes.
X2
Just had a look at your r32 thread, very very nice !
Ive test driven a cupra before and the brakes are pretty good when paired to the 2.0tfsi cars, plenty power but youl aready know that having came from an r32,
Brakes have got to be one of the first mods on the gti they are feckin horrible !
so what's the deal with the standard gti brakes? apart from some grabbiness, i think theyre pretty good for the power the car packs.
What 290bhp? :signLOL:
Standard brakes are weak. The r32 setup is much much better suited to the power, and potential power of the GTI.
:ashamed: you might have a point :wink:.
considering my last car was a mental 300bhp impreza sti, i still think the standard gti brakes, for the standard power output arent that bad to be honest. mind you i havent used them in anger yet, but they do the job.
Do it well worth it!
well worth doing :happy2:
I just think there is very little power in them even for a standard GTI, yea sure i can lock them up but the effort you need to put in is far to much if you are caught unaware, also because you need to apply so much pressure to the pedal on the standard setup this takes away quite a bit of feel and i think it makes for quite loose and unpredictable braking, the bigger S3, r32, cupra set up is pretty powerful and didnt really loose anything power wise to the 4 pot APs i had, although the stroke and progressive pedal feel of the APs were perfect,
might have to use them in anger and see then. thanks for your insight.
Cheers guys...
Does anyone know what the big rubber donut type things on the back are for?
Dom
