All Things Mk5 => Mk5 General Area => Topic started by: crashdesk on August 23, 2011, 07:46:00 pm
Title: How to change display info
Post by: crashdesk on August 23, 2011, 07:46:00 pm
Just gotncar back and the high line display is now showing the number of minutes I have driven whereas before it was how many miles I had left form the fuel in my tank. How do I go about changing that back? Also how would I get average mpg display?
Title: Re: How to change display info
Post by: stealthwolf on August 23, 2011, 07:50:33 pm
Button on right hand lever. Toggles up and down.
Post by: crashdesk on August 23, 2011, 09:00:36 pm
Will check that out now. Ta
Post by: LouCyffer on August 23, 2011, 09:33:06 pm
I'm not being sarcastic, but have you got an owners manual with your car? All the fiddly info about info screens & so on (and there's a lot of it) is in the 'controls' section.
If you havent got one, I'd seriously recommend picking one up & having a skim through. I learn something else each time I read it :signLOL:
Post by: Frenzy on August 24, 2011, 11:22:53 pm
Ha ha, absolutely. Took me weeks to work out how to use the windscreen wipers properly and the day i got my motor home i read the manual and found out the correct procedure for starting the car...  :rolleye:
Post by: griff439 on August 25, 2011, 12:04:24 pm
Correct procidure for starting the car?!! Whatttt?    :scared:
Post by: Frenzy on August 25, 2011, 12:38:46 pm
technically:
Switch key to first position - engages electrics, everything lights up on dash - give it a moment (i put my seatbelt on at this point) - now fully depress the clutch and turn the key all the way as you normally do and hold there only for as long as it takes the engine to start (which should just be a fraction of a second).
This method of starting the engine puts the least wear on the car because you are only asking the starter motor to turn over the engine and nothing else - its on page 112 of the 3.1 handbook  :happy2:
Post by: Johnny_tro on August 25, 2011, 12:49:11 pm
Staring the car? using the wipers correctly?  :surprised:
Maybe I should read up  :scared: I just start the car, put the wipers on and drive.
Post by: vRS_Pagey on August 26, 2011, 09:01:22 pm
I am ashamed to admit, I haven't got the measure of the auto wipers yet, either that or they're broken...... :laugh:
