		All Things Mk5 => Modifications & Technical Area => Sat Nav and Car Audio => Topic started by: nc35 on August 23, 2011, 09:33:11 pm
				Hi All
 Does anyone have a guide for creating a poi database file to upload to my RNS510 from the SD card?
 I have FW3810 and 7.2 Maps the RNS is Rev C with the LED screen.
 Wishing to convert the speedcamera database from Pocket GPS.
 Googled and all I can find is ways of creating a new DVD from the original map DVD using POI inspector and the like  :confused:
				Well I have figured it out and it works really well...
 If anyone needs assistance just let me know  :happy2:
				I wouldn't mind info on updating via Sd. Pm me please
 +1 please  :happy2:
				OMG what have I started...
 The new POInspect0r works a treat.
 You need:
 The RNS510 Map DVD
 The speed camera POI file.  I used the one from PocketGPS
 POInespect0r (you will need to donate at lease €9 to "activate")
 A SD card to upload from...
 POInspect0r Ver 5.5 will even copy the new DB3 file to the SD card
 Darren's write up here gives you the basics, for Ver 5.2
 http://www.mk5golfgti.co.uk/forum/index.php/topic,26277.0.html
 Any more help just let me know
				Should add
 RNS510 needs to be rev C or D and FW 38xx to work...
 You also need 7.1 or 7.2 maps.
 As I understand it 38xx FW will run on older units but with an increased risk of bricking the unit or simply ending up with the battery drain issue again.
 I am running 3810 FW on a rev C unit.  The new FW puts three partitions on the hdd, music, maps & POI.  All existing data is lost...
 Hope this helps.
				useful information
				Hi
 thanks for the info here.
 I upgraded to fw 3810 .  (no idea what FW was previously)
 My existing 7.1 maqs and mp3's remained.  No poi's.
 Upgraded to 3896 and 7.2 maps.
 Existing VW poi's are there plus I can import a db3 file of POI's :)
 I am sure, however, that my hard drive has not been partitioned.
 7.1 maps stayed and when I add extra mp3's the total used GB and remaining space add up to very nearly 20GB ??
 The space should be only 15GB with 5 GB allowed for POI's!
 Not complaining, only foxed.
 Mine came with a new T5 in Feb 11.
 Any ideas?
