All Things Mk5 => How to Guides / Troubleshooting => Topic started by: the bruce on August 29, 2011, 03:59:09 pm
Found this:
1K0963235E Heizelement 305,83€
1K1998250 Leitungssatz für PTC 51,11€
1K1819349E Abdeckung 8,45€
1K0972704C Flachkontaktgehäuse 0,32€
000979009E Einzelleitung (can-bus) 2,32€
N10118105 Bundmutter M5 0,64€
1K0919625 Bundschraube 0,13€
N10525506 Sicherung 100A 2,14€
GTIs should have the same 140 A alternator as the TDI models.
So not an issue at all. Required labour is two to three hours.
If you like it warm in the winter time. :wink:
care of Golfmkv website
http://www.golfmkv.com/forums/showthread.php?t=113468
a full DIY
Is this for 1 cable or a set, ie 2 cables.
As 1Q0 971 478 A/B is the wiring harness for this heater, I guess its HIGH Amp cable. at twice the price of the above.
I was looking into doing this on my Tdi, but then read reports that there was also a fire issue, due to a bad earth, which caused over heating.
I pulled all the drivers side trims off looking on where this is to be fitted, couldn't find the slot in the HVAC. Couldn't make sense of the diagram. :sad1:
What's this?
What's this?
its an electric heater which is a nice feature in the winter. Starts giving of heat after 30 seconds. All soot chuckers have them
Everything in the 1st link above needed? A pricey mod. Will get another remap and wear an extra T -shirt :grin:
Loving all the retro fits and oem upgrades on this site though, sensible purposeful modifying :happy2:
You know this forum is expensive !! :laugh:
Tell me about it! :fighting:
:signLOL:
What's this?
Mine don't :sad1:
What's this?
Mine don't :sad1:
AFAIK, this option was only usually available / fitted in cold climate countries i.e. Sweden, Norway, Finland, etc.
Every TDi that I have scanned with my Vag-com in the UK has had one
7D - Auxilary PTC-Heater
The rarer one is Address 18 - Auxilary Heating (Webasto Heater)
Mine don't :booty: its even unchecked in VCDS, followed that link where the guy retro fitted the heater, I don't have the fuse either. Hence the reason I went looking for it.
Any other checks would be welcome.
weird,
is your car a UK supplied car?
if it is what year is it?
Yup, UK supplied.
Registered July 07
Yup, UK supplied.
Registered July 07
who else hasn't got one fitted.
newest TDI I have scanned is an 06 and it has one
Passat 11 plate doesn't have one
Friend of mines GT TDI doesn't have it and thats a 57
The German TDI as well. Mk.V from the beginning (2003).
Mk.IV I don't know exactly, but I guess around 2000 they had this (the older 'water heat' version).
so hoooold upp...
assuming my car hasn't got this fitted which I dont think it has,
all thats required for this is the heater element, a positive power feed, earth and a pair of can bus splices and I can have warm air in my golf within 30seconds in the winter?....
Yes.
First have a look if you have a 140 A alternator or at least a 120 A type.
All TDI and all GTI I've looked at had the 140 A.
