All Things Mk5 => How to Guides / Troubleshooting => Topic started by: ukdub on September 28, 2011, 08:48:47 pm
I had 3 warning light come on at the same time, twice now. The light were the ABS, traction control and tyre flat warning. Upon stoping the car the tyre and traction light go out with the ABS light going out after about 5 minutes of driving. Not had it on VCDS yet, just wondering if anyone else have experienced this problem.
I should add on both ocations the lights came on when doing motorway + speeds on a long sweeping corner.
Might be ABS sensor - I had something similar with all three lights yellow. Driving was fine. If I pulled over, turned the ignition off, turned it on, they would clear. Once I started driving, they'd light up.
Yeah all 3 lights come on when the computer loses vehicle speed information, as above could be a sensor, see if you have a stored fault and then if you can swap it with the other side and wait for the light to come back on, that will tell you if its the sensor or not. Probably not the issue, but check all your tyre sizes are the same.
