All Things Mk5 => Mk5 General Area => Topic started by: redgem on October 09, 2011, 02:12:25 pm
I have had cruise control stalk fitted and coded the green speedo symbol lights up in the dash but the speed does not hold and + - buttons just do nothing?Lookers VW of Teeside have checked it and changed the stalk coded it and it still does not work.They checked with VW technical department but they are now saying they need to open the ECU? Any ideas?
what year is it?
have you a scan of your car
Lookers Teeside hav'nt got a clue. I asked them to code my sat nav so it displays on the MFD and they told me they had to run a wire from the sat nav to the instrument cluster! :stupid: so i would'nt take any notice of them to be honest.
As Eddie says--get it scanned or get in contact with Darron who will sort it for you
I'm in Stockton with VCDS if that's any good. I can scan but not much else! :ashamed:
Regards,
John
George speak to John(Scousus Maximus) and get your car scanned then Ill have a look at the scan for you :happy2: I think John with my help could sort this easily enough
Darren
VW lookers said no faults where showing???The car is 2007 dsg gti.
We need to check if the engine module and steering module has been coded properly?
Darren
get a scan done by the member that is near you, and post it up here
I'm not sure if this is posting ok but here goes. Did a first scan and got the following.
Then cleared the faults and did a test run, still no good even after a scan with no faults showing.The "intermittent" at address 16 looks dodgy to my untrained eye.
Regards,
John
ps I know my VCDS is out of date but I didn't want to update it until I did this scan so I knew I was working with a proven version.
Monday,10,October,2011,18:02:14:18648
VCDS Version: Release 10.6.4 (x64)
Data version: 20110418
Chassis Type: 1K0
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 55 56 76
VIN: WVWZZZ1KZ7W Mileage: 40980km/25463miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
76-Park Assist -- Status: OK 0000
Address 01: Engine Labels: 06F-907-115-AXX.lbl
Part No SW: 1K0 907 115 J HW: 8P0 907 115 B
Component: 2.0l R4/4V TFSI 0030
Revision: 5BH16--- Serial number: VWZ7Z0G8113939
Coding: 040300031C070160
Shop #: WSC 78136 665 46858
VCID: 2D5AB2C1CD81
1 Fault Found:
005699 - Please check DTC Memory of Electric Load Controller
P1643 - 001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 0
Fault Frequency: 3
Mileage: 40831 km
Time Indication: 0
Date: 2000.00.00
Time: 09:39:09
Freeze Frame:
RPM: 1681 /min
Load: 25.9 %
Speed: 68.0 km/h
Temperature: 92.0°C
Temperature: 16.0°C
Absolute Pres.: 990.0 mbar
Voltage: 14.351 V
Readiness: 0000 0000
Address 02: Auto Trans Labels: 02E-300-0xx.lbl
Part No SW: 02E 300 043 Q HW: 02E 927 770 AE
Component: GSG DSG 082 1305
Revision: 09808020 Serial number: 00000803250852
Coding: 0000020
Shop #: WSC 00770 210 105474
VCID: 224051FD845F
No fault code found.
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Component: ESP FRONT MK60 0101
Revision: 00H11001
Coding: 0004738
Shop #: WSC 01279 785 00200
VCID: 73EE64B96B25
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No SW: 1K0 907 044 BM HW: 1K0 907 044 BM
Component: ClimatronicPQ35 110 1010
Revision: 00110021 Serial number: 00000000000000
Shop #: WSC 00000 000 00000
VCID: 73EE64B96B25
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 AE HW: 3C0 937 049 AE
Component: Bordnetz-SG H52 2002
Revision: 00H52000 Serial number: 00000006975209
Coding: E78F0F2700041500471400001400000000087F075C0001
Shop #: WSC 00000 785 00200
VCID: 6CDC7FC5361B
Part No: 1K2 955 119 E
Component: Wischer 190407 021 0501
Coding: 00038805
Shop #: WSC 00000
Part No: 1K0 955 559 AB
Component: RLS 200407 020 0105
Coding: 00208933
Shop #: WSC 00000
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 T HW: 1K0 909 605 T
Component: 38 AIRBAG VW8 020 2300
Revision: 05020000 Serial number: 0038PD165V28
Coding: 0013112
Shop #: WSC 01269 785 00200
VCID: 3D7A82811DE1
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 AQ HW: 1K0 953 549 AQ
Component: J0527 638 0071
Coding: 0012142
VCID: 8102BE71A199
Part No: XXXXXXXXXXX
Component: E0221 002 0010
1 Fault Found:
00895 - Cruise Control Switch (E45)
014 - Defective - Intermittent
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No SW: 1K6 920 973 HW: 1K6 920 973
Component: KOMBIINSTRUMENT VDD 1610
Revision: V0003000 Serial number: VWZ7Z0G8113939
Coding: 0007403
Shop #: WSC 00675 210 62469
VCID: F0E4EBB59A33
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 K HW: 1K0 907 951
Component: J533__Gateway H04 0021
Revision: H04 02 Serial number: 090407F1001038
Coding: 7F0F074007000001
VCID: 2F66A8C9C78D
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO VDD 1610
VCID: F0E4EBB59A33
Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX3.lbl
Part No SW: 1K0 959 701 N HW: 1K0 959 701 N
Component: Tuer-SG 005 0982
Coding: 0000566
VCID: 3972969109C9
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K2 909 144 L
Component: EPS_ZFLS Kl.074 H07 1806
Shop #: WSC 00675 210 86472
VCID: 356A9AA125D1
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0204
Revision: 00020000 Serial number: 00000000000000
Coding: 819002085103087F2D0484057008DAC690B800
VCID: 830EB479BB85
Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Part No: 1K0 951 178 A
Component: Neigungssensor 003 0203
Component: Innenraumueberw.003 0203
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX3.lbl
Part No SW: 1K0 959 702 N HW: 1K0 959 702 N
Coding: 0000822
VCID: 3A70899D0CCF
1 Fault Found:
00097 - Front Passengers Central Locking (Safe) Motor (V162)
012 - Electrical Fault in Circuit - Intermittent
Address 55: Xenon Range Labels: 1T0-907-357.lbl
Part No: 1T0 907 357
Component: Dynamische LWR 0003
Coding: 0000003
VCID: F4ECE7A5EE2B
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No SW: 1K0 035 186 T HW: 1K0 035 186 T
Component: Radio BVX 034 0046
Revision: 00034000 Serial number: VWZ1Z2G4736237
Coding: 0040400
VCID: 377690A93FDD
Address 76: Park Assist Labels: 1K0-919-283.lbl
Part No: 1K0 919 283 A
Component: 22 Einparkhilfe 0101
VCID: 2D5AB2C1CD81
The steering wheel is not coded for cruise control if you ask John to go into the steering wheel and change 0012142 to 0013142 then the faults in the engine and the steering controller will delete themselves and you will have cruise working :happy2:
Also the fault on the engine module is only there because of the fault that is in the steering module once that is sorted then the engine fault will go.
1 Fault Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 3
Mileage: 40831 km
Time Indication: 0
Date: 2000.00.00
Time: 09:39:09
Darren
Darren
Changing the 2 to a 3 will change the mute button to a voice control control button.
when I had a mk5 mfsw in my car I had 0002022 and my cruise worked
try and check the measuring blocks to see if the stalk is ok and the engine
Well this is the coding for the steering wheel
0xx?xxx: Steering Wheel
0 = Steering Wheel without Multifunction
1 = 3-Spoke Steering Wheel without Multifunction
2 = 3/4-Spoke Steering Wheel with Multifunction without Cruise & Voice Control
3 = 3/4-Spoke Steering Wheel with Multifunction with Cruise & Voice Control
George try it and see if it works if not then you've not lost anything?
Darren
I know it is strange but I think that part only relates to the button function.
apart from my car I have also done a cruise and paddle shift on a 2005 gti dsg. The cruise worked fine
Part No SW: 1K0 953 549 AK HW: 1K0 953 549 AK
Component: J0527 036 0070
Coding: 0012122
Shop #: WSC 12345 123 12345
when alan came round to try the gateway, I changed his coding as his mute button started the voice control.
This is a scan from a similar reg car
Chassis Type: 1K0
Scan: 01 02 03 08 09 15 16 17 19 25 37 42 44 46 52 55 56
VIN: WVWZZZ1KZ7W****** Mileage: 55210km/34305miles
01-Engine -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
37-Navigation -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
Part No SW: 1K0 907 115 L HW: 8P0 907 115 B
Revision: 5BH16--- Serial number: VWZ7Z0F8218059
Shop #: WSC 07097 500 00200
VCID: 2F67FD9CC238
Readiness: 0110 0101
Component: J0527 636 0070
Coding: 0013122
VCID: 8103EB24A42C
This is another
Part No SW: 1K0 907 115 J HW: 1K0 907 115 F
Revision: --H14--- Serial number: VWZ7Z0F3600246
Coding: 0403000318070160
Shop #: WSC 00191 264 15243
VCID: 2D5BE794CD63
Part No SW: 1K0 953 549 AG HW: 1K0 953 549 AG
Component: J0527 034 0070
Coding: 0003022
Shop #: WSC 00675 210 71777
VCID: 77F705FC7FBF
if you have an RNS510 with voice control then you will want it to work.
Tbh. i don't think it is down to the coding, so as you suggested they won't lose anything by trying it
the last few posts on problems with cruise retrofits on this forum all had AQ controllers
Latest update:
Tried all the codes as shown in thread, ie: 0013142, 0002022, 0012122, 0013122, 0003022 and still no good. I've reset it to first position, 0012142.
Just a bit more info on the car, it's got DSG with paddles and highline but not MFSW and no voice control.
Car is unavailable for two weeks now so time for the boffins to think.
All help gratefully received by George and myself.
Regards,
John
If that is right Ed then the only thing to do is swap out the steering controller, maybe like the BC version with the bug on the cruise??
Weird but possible not heard it on the AQ controller.
John can you send the scan across to Ross Tech and see what they think??
Darren
Hi Darren,
I'd do it if I knew how to! :laugh:
Will they accept it if I'm not the original purchaser of the cable? I thought they restricted support to new buyers only.
Give us a few clues mate and I'll give it a go.
Regards,
John
Not sure about ownership mate but as long has its a genuine cable Im sure they'll give you some advice?
You need to go into vcds and on the front screen there is an option that says debug press this and it will bring your emails up on the email just put in a breif description of the problem and either copy and paste the scan or attach/insert the text file.
Darren
Guys this was the exact same controller i had the problem with Ian's ED30 when fitting cruise control!!!
Component: J0527 638 0070
Coding: 0012112
VCID: 8127D643A199
scott :happy2:
Right,
Sent the log to Ross Tech and this is their response:
"The ECM and Steering Wheel Control Module are coded for cruise control. When you scan the ECM, go into Measuring Blocks group 066 and operate the cruise control buttons. Do any changes happen in field 4?
Just to confirm, the cruise control buttons are NOT on the steering wheel, correct? "
So, as I said earlier, the car isn't available for two weeks now so I'll wait and try this action and get back on here with the results.
Thanks for all the input so far, that's what's nice about this Forum! :wink:
Regards,
John
Is the long coding set correctly on the engine module.
My cruise control threw some faults up the other week, and to get rid of the fault code, I had to change the long coding on the engine module, and the coding on the steering wheel module also.
I live Seaham way if you need any help
Darren
Just for info, Ross Tech got back and told me that as a second buyer of the cable it's a $99 registration fee for support.
Hmmmmmmm.
Regards,
John
You'll get all the support you need on here John so don't be wasting your cash.
Darren
Looks like I'm going to be down in smogland tomorrow if you want me to bring my VCDS down with me, I'll be happy to have a look for you?
Thanks for the offer mate, I've got one thanks. It's making sense of what it's telling us that's the problem! :laugh:
Nice of you to offer though.
(I think you just got me above my first 100 posts too! :happy2:)
Regards,
John
Well I just read through the full thread again, and engine module fault was the same as mine, and the steering wheel fault was the same as mine, green light on dash, but not working properly.
I just finished fitting a new cruise control stalk, and all is now working fine with no error codes
they fitted 2 stalks, highly unlikely that 2 new ones would be faulty.
Also Golfman did a cruise install with the same controller and also tried 2 and both didn't work. In the end had to use a new steering controller
Picked this up again this morning and did the measuring blocks test as suggested by Ross Tech.
When the stalk switch is operated the binary code at Measuring blocks 066, field 4 responds so does that suggest that the Steering module is not responding? If that's the case then it looks like a new controller with a different part number will be required. Can anybody confirm please.
Regards.
John
My car came with cruise from the factory with the midline F module.
When I got the highline AQ module there was no problem with it working still, although I have a manual.
you might have a working AQ
Ross-tech lists that a BC can't have Cruise retrofitted
I have had 1 work and 1 not work
back on topic go for a BK controller
[ur
l] http://wiki.ross-tech.com/wiki/index.php/Steering_Wheel_Control_Module_Versions [/url]
Thanks again John for scanning my car.So I`v read the replies but still not sure if its suppose to work or not?Ross tech graph says the AQ module supports cruise control but it seems like some people have had to change their control module?Thanks for the replies. :confused:
It could have been damaged before or during installation. Could have a Bug in the controller.
Ross-tech lists a BC won't work with cruise. I had one which worked and another which didn't.
Was that mine that worked?
yes :happy2:
I think we have come to the end on this looks like I need a steering control module anyone any ideas where I might get one?.I`d just like to say a big thank you to everyone for their help.
George :happy2:
George :happy2:
Loads on ebay! Up to you to find a compatible one though, the link I posted to the ross-tech chart might help you with that.
http://www.ebay.co.uk/sch/i.html?_from=R40&_trksid=p4712.m570.l1313&_nkw=1K0-953-549&_sacat=See-All-Categories (http://www.ebay.co.uk/sch/i.html?_from=R40&_trksid=p4712.m570.l1313&_nkw=1K0-953-549&_sacat=See-All-Categories)
hi im having a similar problem if somebody can help this is my log
Thursday,14,November,2013,19:01:49:51843
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.0.0
Data version: 20130910
VIN: VSSZZZ1PZ6R086566 License Plate:
Mileage: 141030km-87631mi Repair Order: MO's 2006 Seat Leon 2.0TDI
Chassis Type: 1P (1K0)
Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 52 55 56
VIN: VSSZZZ1PZ6R086566 Mileage: 141030km/87631miles
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
55-Xenon Range -- Status: Cannot be reached 1100
Address 01: Engine Labels: 03G-906-016-BKD.lbl
Part No SW: 03G 906 021 LL HW: 03G 906 021 LL
Component: R4 2,0L EDC G000SG 9185
Revision: --H03--- Serial number: SEZ7Z0F3473219
Coding: 0050072
Shop #: WSC 12345 123 45678
VCID: 74E187231771ACBE80B-8021
2 Faults Found:
001384 - Cruise Control Switch (E45)
P0568 - 008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 141037 km
Time Indication: 0
Date: 2000.00.00
Time: 18:48:31
Freeze Frame:
RPM: 798 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.21 V
Bin. Bits: 11001100
Bin. Bits: 00000000
(no units): 0.0
005784 - Please Check DTC Memory of Steering Wheel Electronics
P1698 - 001 - - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 141037 km
Time Indication: 0
Date: 2000.00.00
Time: 18:48:31
Freeze Frame:
RPM: 798 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.21 V
Bin. Bits: 11001100
Bin. Bits: 00000000
(no units): 0.0
Readiness: 0 0 0 0 1
Address 03: ABS Brakes Labels: 1K0-907-379-MK70.lbl
Part No: 1K0 907 379 P
Component: ASR FRONT MK70 0105
Coding: 0000641
Shop #: WSC 06441 785 00200
VCID: 3F8B180F6EB73FE6AD9-806A
Address 08: Auto HVAC Labels: 1K0-820-047.lbl
Part No SW: 5P0 820 047 M HW: 5P0 820 047 M
Component: Climatic PQ35 014 0606
Revision: 00014014 Serial number: 00000000000000
VCID: 377B702F468707A6659-8062
2 Faults Found:
01296 - Sensor for Vent Temperature; Center (G191)
007 - Short to Ground
00229 - Refrigerant Pressure
002 - Lower Limit Exceeded
Part No SW: 3C0 937 049 E HW: 3C0 937 049 E
Component: Bordnetz-SG H37 1002
Revision: 00H37000 Serial number: 00000003969246
Coding: A1880F3F00041000001D00000000000000007F075C
Shop #: WSC 00008 210 45725
VCID: 2B535C5F8ACFB346111-807E
Subsystem 1 - Part No: 1P0 955 119 A Labels: 1KX-955-119.CLB
Component: Wischer SE350 012 0403
Coding: 00056272
Shop #: WSC 00008
2 Faults Found:
00978 - Lamp for Low Beam; Left (M29)
010 - Open or Short to Plus
Freeze Frame:
Fault Status: 01101010
Fault Priority: 1
Fault Frequency: 1
Reset counter: 6
Mileage: 141037 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 13.95 V
ON
ON
OFF
OFF
OFF
00979 - Lamp for Low Beam; Right (M31)
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 6
Mileage: 141037 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 13.95 V
ON
ON
OFF
OFF
OFF
Address 15: Airbags Labels: 3C0-909-605.lbl
Part No SW: 3C0 909 605 L HW: 3C0 909 605 L
Component: R4 AIRBAG VW8 030 2522
Revision: 12030000 Serial number: 003B0PDCNUPD
Coding: 0021044
Shop #: WSC 04941 785 00200
VCID: 2F6B484FBED7CF663D9-807A
Subsystem 1 - Serial number: 6332MSME0E405F49
Subsystem 2 - Serial number: 6342MSME0E340A72
Subsystem 3 - Serial number: 6351HTS64IKMM563
Subsystem 4 - Serial number: 6361HTS63IKAIAT2
Subsystem 5 - Serial number: 00000000000000000
Subsystem 6 - Serial number: 00000000000000000
1 Fault Found:
00654 - Seat Belt Tensioner Igniter; Driver Side (N153)
001 - Upper Limit Exceeded - MIL ON
Address 16: Steering wheel Labels: 1K0-953-549-MY9.lbl
Part No SW: 1K0 953 549 CH HW: 1K0 953 549 CH
Component: J0527 056 0111
Coding: 0000534
VCID: 7AFDA91B3515DACEDA7-802F
Subsystem 1 - Part No: 1P0 959 538 B
Component: E221__MFL-TAP H01 0100
Coding: 00000226
Shop #: WSC 00000
Part No: 1P0 920 941 A
Component: KOMBIINSTRUMENT VO3 0724
Coding: 0002401
Shop #: WSC 00046 476 88215
1 Fault Found:
01771 - Control Module for Headlight Range (J431)
004 - No Signal/Communication
Address 19: CAN Gateway Labels: 1K0-907-530-V1.clb
Part No SW: 1K0 907 530 F HW: 1K0 907 951
Component: Gateway H10 0120
Revision: H10 Serial number: 280010630681B3
Coding: 7D0F0348072203
VCID: 2A5D595B8535AA4EEA7-807F
1 Fault Found:
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 62
Reset counter: 6
Mileage: 140726 km
Time Indication: 0
Date: 2000.00.00
Time: 16:27:36
Component: IMMO VO3 0724
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 1T0 035 680 C HW: 1T0 035 680 B
Component: RNS-MID H11 1300
Revision: AB001001 Serial number: VWZ6Z7J8273164
Coding: 04000400040000120020
Shop #: WSC 00020 790 12345
VCID: 2E55554B79DDC66E36F-807B
2 Faults Found:
03138 - Input AUX IN
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 5
Fault Frequency: 1
Reset counter: 46
Mileage: 140726 km
Time Indication: 0
Date: 2000.00.00
Time: 16:27:51
01299 - Diagnostic Interface for Data Bus (J533)
Freeze Frame:
Fault Status: 01100000
Fault Priority: 5
Fault Frequency: 1
Reset counter: 252
Mileage: 140726 km
Time Indication: 0
Date: 2000.00.00
Time: 16:27:52
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN2.lbl
Part No: 1T0 959 701 B
Component: Tuer-SG 024 2352
Coding: 0000688
VCID: 36657D2B418DFEAE7EF-8063
Part No: 1K2 909 144 K
Component: EPS_ZFLS Kl.5 D06 1701
VCID: 3461472357F1ECBE40B-8061
1 Fault Found:
00778 - Steering Angle Sensor (G85)
000 - -
Address 46: Central Conv. Labels: 1K0-959-433-MIN.clb
Part No: 1K0 959 433 AK
Component: KSG 0401
Coding: 19C000BC09000505485B863004CC
VCID: 79FFB6173013D1D6D3D-802C
Subsystem 1 - Component: Sounder No Answer
Subsystem 2 - Component: NGS n.mounted
Subsystem 3 - Component: IRUE No Answer
2 Faults Found:
01135 - Interior Monitoring Sensors
01134 - Alarm Horn (H12)
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN2.lbl
Part No: 1T0 959 702 B
Coding: 0000688
Cannot be reached
Address 56: Radio (J0506) Labels: 1T0-035-680.clb
2 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 46
Mileage: 140726 km
Time Indication: 0
Date: 2000.00.00
Time: 16:27:51
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 252
Mileage: 140726 km
Time Indication: 0
Date: 2000.00.00
Time: 16:27:52
End ---------------------------------------------------------------------
