All Things Mk5 => Mk5 General Area => Topic started by: savechip17 on April 06, 2009, 10:40:37 am
Title: what suspention with 19" alloys on a TDI
Post by: savechip17 on April 06, 2009, 10:40:37 am
im probably buying some 19" form markymark and was wanting to buy some eiback (however you spell them) springs to lower it.
 would there be a problem with this. ie too low, runbbing and looking totally stoopid.
Any suggestions for reasonable priced springs for 19" wheels on a tdi would be great
thanks
Title: Re: what suspention with 19" alloys on a TDI
Post by: T88OMM on April 06, 2009, 08:54:33 pm
There are two spring set up's that I have heard nothing but good things about. Eibach Sportlines and the H&R Ultra Low. You should have no issues with rubbing as im guessing the wheels you are purchasing are the Gallardo reps.
There is one small screw which can catch the tire with 19's in the arch liner which you can find by rubbing your hand along the inside of the arch. You just jave to take this out and tuck the flap under and then screw it back in if that make sense  :grin:
