All Things Mk5 => Modifications & Technical Area => Performance Modifications => Topic started by: james on October 19, 2011, 02:03:02 pm
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fwww.myjunk.eclipse.co.uk%2Fnewcar%2Fbuild%2Fwaterm.jpg&hash=b91ee34e6037e2f6c1e5af2ec2e073f8ea8e8d69)
Stage 3 boost cooler
I will install this at the weekend, will be intresting to see how it goes. :drinking:
Will you ask your tuner to readjust your map to obtain the max performance from the water/meth kit?
:jumpmove: :jumpmove: Have you found a good source for Methanol yet :happy2:
yea i will do see rtech again :happy2:
been looking around, loads on ebuy but will try source locally
is methanol something you can fit yourself, or it is you need specialist skill/tools to do?
yea you can fit it yourself, just have to make a hole in inlet just before the throttle body.
Very interested in seeing how this turns out! :happy2:
How's the fitting progress going?
http://www.aaoil.co.uk/racing-R-racing-methanol
never got time to fit it :( other half wanted to use the car. think i am going to make a boot build anyway :party:
I'm itching to find out how your install went :popcornsoda: What do you make of the Sunoco methanol compared to the 99.99% meth on ebay which is a 60% cheaper, In theory they should both be identical with the ebay one being 99.99% pure or am I completely mistaken.
http://www.ebay.co.uk/itm/130543132674?ssPageName=STRK:MESINDXX:IT&_trksid=p3984.m1436.l2649#ht_2559wt_1023
You really need to install after the tb as the meth will kill the tb over time. USRT make a spacer plate iirc. If you do mount it after the tb then you need a valve to stop the meth being drawn into the inlet under vacuum.
Alex what are your thoughts on the above choices of methanol? :happy2:
what's this about needing to change the (plastic) throttle body for methanol injection for the metal RS3 one?
Nick at r-tech has it. he is going to install and setup. we will have to wait n see :popcornsoda:
I hope you don't bend any rods seeing that APR recommend installing uprated rods on the their 100 octane K04 file because of the possibility.
if it happens it happens. willing to take the risk.
Will just buy an ed30 engine if it does.
The idea is not to run any more cylinder pressures its all ready at 1.5-1.6 bar and -4cf at peak torque, The way to gain power would to be run a leaner AFR of around 12.5:1 from 4500rpm to 7000rpm and not 11.5:1 which is used to cool cylinder and exhaust temps, plus after a few logging sessions I shoukd find a safe window for 2-4deg advance, if I can get the current CFs down to zero. Looking forward to doing this tomorrow..... If I can find a spark plug combination to stop this bloody misfire.... :fighting:
