All Things Mk5 => Mk5 General Area => Topic started by: impuLz on October 22, 2011, 03:17:14 pm
Title: Lorinser D93 Alloys - do they fit ?
Post by: impuLz on October 22, 2011, 03:17:14 pm
Seen these online and am taken away with how nice they look, but before i get carried away wanted a double check if they would fit a mk5?
offset - 44
width - 8j
diameter - 17"
tyre - 235?? maybe more/less
any help is appreciated. thanks!
Title: Re: Lorinser D93 Alloys - do they fit ?
Post by: sub39h on October 22, 2011, 03:54:05 pm
http://www.1010tires.com/WheelOffsetCalculator.asp
Post by: impuLz on October 22, 2011, 04:12:28 pm
thanks,
Should be able to work something out with this  :happy2:
Post by: vRS_Pagey on October 22, 2011, 04:21:32 pm
They will fit perfect, sitting 12-13mm further out than OE wheels.  :happy2:
Post by: impuLz on October 22, 2011, 04:33:10 pm
cheers i was really starting to struggle, seeing as i only knew the offset&width of the wheels i was looking at and not the steelies sat on the car currently.
 worked out that it would be:    +1mm inside edge  and +13mm outside edge in contrast to an 18" monza
so i am guessing that they would just about fit- depending on tyres?
Post by: stevw1 on October 23, 2011, 09:09:51 pm
By my calculations you should have 9mm between rim and arch = PERFICK  :happy2:
Post by: dodds-gttdi on October 23, 2011, 09:26:30 pm
Here's some wheels with the same specs. Fronts only as the rears are 17x9. Think the tyres are 215/40/17 altho I think you really should have 225/45/17 to get the correct rolling radius for a golf.
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fi56.tinypic.com%2Fbdupes.jpg&hash=2c7841c732a5282c1ac3c3efae23e144459468c3)
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fsphotos.ak.fbcdn.net%2Fhphotos-ak-ash1%2Fhs543.ash1%2F31775_439113100238_659920238_6156385_1498588_n.jpg&hash=e03b5c4cd3e7a568577d7218ff489afc30f5f49a)
Another set, this time 17x7 ET 45. Tyres are 225/45/17
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Fq186%2FGTITROJAN%2FDSC_0005-1.jpg&hash=43d73e9a10c2de8088a7ccd9be8802f2b610356e)
