General => Random Chat => Topic started by: stealthwolf on November 04, 2011, 11:29:57 pm
Title: SDS drills
Post by: stealthwolf on November 04, 2011, 11:29:57 pm
Stupid question but can I use an SDS drill for drilling into wood etc? I know they're designed to drill into masonry. Current drill is broken after 20 years of service. I've been advised to go for an SDS one.
Title: Re: SDS drills
Post by: andrewparker on November 05, 2011, 07:06:02 am
No, get a good combi drill. I have a Makita one which is excellent.
Post by: JPC on November 05, 2011, 08:32:47 am
As above. Screwfix were doing the Makita bhp451 I think? For 199 recently. That's a really really good price for a £400 drill. I got one 3 months ago and its awesome!
An sds drill would be useful if you were drilling right thru a wall with like 250ml long drill bit.
That Makita of mine flys thru wall too though
Post by: andrewparker on November 05, 2011, 08:51:20 am
Mine is still going strong after 4 years. I got it for a similar price but it came in a case with three batteries. They can run down pretty quickly with intensive use, though they do charge quickly. Haven't found a surface yet that it couldn't tackle.
Post by: stealthwolf on November 05, 2011, 09:48:50 am
Cool. TBH I need to do some wall drilling. Not much but it's a garage wall. Wanted to do it today hence heading to b&q.
Have masonry drill bits too.
Post by: andrewparker on November 05, 2011, 09:56:50 am
Seriously, a good combi drill will handle any masonry.
Post by: Eddie-NL on November 05, 2011, 10:13:42 am
you can if you use an sds+ adaptor with 13mm chuck
My Bosch Sds+ has quick change chucks :laugh:
Post by: RobH on November 05, 2011, 10:32:08 am
Combi drills for drilling into masonary doent make me laugh.
An sds drill with a setting for normal drilling is totaly fine and are more powerfull than a combi.
This drill would be fine for anything round the house you would just need a 13mm chuck for the wood bits.
http://www.screwfix.com/p/makita-hr2470-2-2kg-sds-plus-drill-240v/99908
http://www.screwfix.com/p/makita-keyless-chuck-13mm/38973
That sds would walk all over any combi in any situation aslong as you have mains there thats the only downside.
Post by: stealthwolf on November 05, 2011, 11:34:52 am
I was looking at the DeWalt D25013K
clicky (http://m.diy.com/mt/www.diy.com/diy/jsp/bq/nav.jsp?action=detail&fh_secondid=11537597&fh_location=//catalog01/en_GB/categories%3C%7B9372015%7D/categories%3C%7B9372047%7D/categories%3C%7B9372203%7D/categories%3C%7B9392094%7D/specificationsProductType=corded/specificationsSpecificProductType=sds_hammer_drills&un_jtt_redirect)
And one of these:
clicky (http://www.wickes.co.uk/invt/215712)
don't trust keyless chucks to be strong enough.
Any remarks on the dewalt?
Post by: RobH on November 05, 2011, 11:54:17 am
Dewalt has been going downhill for a while now regarding drills makita and milwaukee are better and thats what id go with.
Keyless chucks are good but if your unsure then get a key chuck personaly i just couldnt be bothered faffing about with one i have never had a problem with the makita keyless chucks tbh.
Post by: stealthwolf on November 05, 2011, 12:14:41 pm
I always though dewalt were the "pro" version of B&D, like the difference in blue and green Bosch tools?
Will go for the Makita then.
Post by: RobH on November 05, 2011, 02:51:31 pm
They are but their pro version compared to makita or milwaukee is inferior these days.
Post by: candy turbo on November 05, 2011, 05:57:17 pm
if using mains any sds is pretty much the same , cordless for the money makita are good but not the best the batteries have problems and the gear s are not too good , if you want the best cordless drills on the market look at panasonic
Post by: stealthwolf on November 05, 2011, 06:35:01 pm
I'm not a huge fan of cordless drills.
Either way, problem solved - borrowed my grandad's corded combi and he's also given me an 18V cordless one he's had laying around. Means I can delay the need for an SDS/combi for now. Given that I have a cordless, I reckon SDS should be able to tackle the heavy duty stuff.
Post by: Eddie-NL on November 06, 2011, 12:10:02 am
I find it depends on what tool you buy
Post by: damoegan on November 06, 2011, 06:04:59 pm
I've just killed the clutch set on the 18v cordless Makita at work last week and that was only driving screws onto wood (proper wood screws and also rilot drilled first)  :fighting:
