All Things Mk5 => Modifications & Technical Area => Sat Nav and Car Audio => Topic started by: jimk04 on November 09, 2011, 07:41:49 pm
I am totally new to this can bus thing - I dont even know what it is other than a PITA!
I am thinking of putting an RDC510 into my 2005 car with std rcd300? I think I am right in that I have a gen2 unit and the 510 is gen3 so I need a new canbus gateway version L or something?
What should I pay for the gateway - is it all plug and play or do I need VCDS?
Jim
PS - I did a search but as usual I can never find anything on a forum search!
Hi
If you put the RCD510 in your 2005 car you will need a newer gateway and an adaptor for the antenna
The Gateway will need coding to your car
I have some in the for sale section
Not clued up on the gateway, but this is the antenna adaptor you will need:
http://www.ebay.co.uk/itm/RNS510-MFD3-radio-antenna-adapter-VW-Fakra-RCD510-310-/330633137478?pt=UK_CE_GPS_Accessories_Software_ET&hash=item4cfb454d46#ht_500wt_1413
If you have a bee sting antenna on the roof that is the one you want
if you don't have the bee sting this is a better option
http://www.ebay.co.uk/itm/180662955007?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
