General => Shows, Events and Meets => Topic started by: Shins on November 13, 2011, 04:06:44 pm
Thanks again to RAF Marham's invitation, I’m very pleased to confirm the next 30-130 event will be held on Sunday 18th March 2012.
If you haven't heard of “30-130” before, it's probably the best opportunity for you to understand the REAL performance of your car. Taken from a rolling start below 30mph you have approx 1.5miles of Marham's straight ultra smooth tarmac to pass 130mph - and carry on for a top speed run if you wish.
There's no running order so you can run when you want (subject to the queue which we get through as quickly as possible!) The average number of timed runs is approx 5 or 6, but we've seen some drivers do 15+! You’re welcome to do a run without a VBox (or use your own if you have one) to bypass the queue and go straight out, but only data from the MLR's calibrated VBoxes being used on the day will be used in the results.
The current 30-130 record is held by RossW in his Evo6 in a time of 5.84s
Please read ALL the following info carefully, paying particular attention to the Security Clearance requirements further below
Main Event Details:
Full 1.5mile runway
VBox data recorded for all cars
Cars can be corner weighted
Limited to a maximum of 60 cars
Starts at 9am, finishes at 4pm
£99 per car & driver
Additional drivers £59
Passengers £10
Main drivers must have full UK driving licence
ALL cars must have a fire extinguisher fitted within reach of the driver
ALL drivers and passengers must bring photographic ID on the day to be allowed into the venue (no photo ID = no entry)
ALL spectators must come in the same car as the driver booked for the event
Event Timetable:
07:30 - Gates open. (DO NOT stop at the Guard room as before - please go straight through to the first checkpoint. You MUST show your Photo ID on the day)
07:45 - Driver and Passenger Registration / Car number and wristband collection
08:30 - Drivers briefing (mandatory)
09:00 – Sighting lap
09:30 – Event start
12:30 – Lunchbreak
13:00 – Event restart
16:00 – Event close
30-130:
We’ll use the full length of the 1.5 mile / 60m wide runway of super smooth tarmac
All cars will be fitted with a Racelogic V-Box in order as they appear in front of the MLR control point, which will record your car's performance
Cars will run one at a time and must start their run within the designated coned area for that run to count
Having completed a “30-130 run” all drivers will be able to go on to complete a top speed run if they want. This is not compulsory but you may not have a better, safer and legal way to find out your car’s top speed
The next car will be released when car #1 has passed the halfway mark on the runway
You must brake at the braking markers to ensure you don’t overrun the end of the runway and risk damaging the airfield infrastructure (as happened last year!)
Once the car has returned to the Paddock and the VBox has been removed, your 30-130 time and Top Speed result (if applicable) will be displayed at the MLR unit as soon as Dave has downloaded the data from your runs
***VERY IMPORTANT: SECURITY CLEARANCE!***
ALL DRIVERS, SPECTATORS & RESERVES MUST HAVE SECURITY CLEARANCE BEFORE BEING ALLOWED ON SITE
I MUST HAVE EVERYONE’S DETAILS BY 29th FEBRUARY 2012 to give the RAF Police enough time to get your security clearance before the day.
IF YOU MISS THIS DEADLINE YOU WILL NOT BE ABLE TO ATTEND AS YOU WILL NOT GET SECURITY CLEARANCE
I need to record ALL names & details regardless of whether you have been security cleared for previous events, or have clearance to work on this station, are serving RAF personnel etc, so please send me your info asap
Please PM or email me with ALL the following details ASAP for security vetting:
Full Name
Address
Nationality
Place of Birth
Date of Birth
Passport number
Car make, model and registration being driven into RAF Marham; ie: the tow car if the vehicle you’re using at the event is being towed
ADDITIONAL INFO:
Corner Weighting:
We will have our corner weights at the event as usual, so if you want to corner weigh your car you can do so anytime during the day. This will be managed the service and direct you onto the ramps and the scales. Readings will be recorded and can be taken with and without the driver
Marshals & Emergency Cover:
The event will be fully marshalled and include Medical and Fire Cover
Helmets:
Helmets must be worn by all occupants- drivers and front seat passengers
Fire Extinguishers:
ALL cars must have a fire extinguisher fitted - preferably in an easy to reach place, eg: in front of the passenger seat. This will be checked on the day and any cars without extinguishers will not be allowed to run
Noise Limit:
Noise from motorsport has now become an issue for RAF Marham. Although it’s understood that running a single car at 30-130 is not the same as running numerous cars together at a trackday, noise monitoring will take place on the day if required but they will be as lenient as possible. We are not allowed unsilenced exhaust systems. The static noise limit is 105dBA (measured at ½ metre, 45 deg, ¾ revs)
Rear Spoilers:
For reasons of safety, cars must retain their rear spoilers and blade, unless fitted with a carbon bootlid or similar which does not allow for a rear spoiler
Vortex Generators and Trim:
Debris of ANY type on the runway is the single biggest concern at RAF Marham. Aftermarket VGs and other trim have a tendency to come off when travelling at over 130mph, so all VGs will need to be taped front and back to ensure they stay on the car. If it’s not done when you come to collect your VBox we will do it for you!
Towing Eyes:
It is your responsibility to have a towing eye or strap fitted and/or accessible on the day in case you need to be recovered. The RAF recovery crew are experienced and will treat your car like their own, but they have to be able to return your car to the paddock, so please make their life as easy as possible whilst also removing the risk of damage to your car
Passengers:
Only front seat passengers are allowed and must be 16 years old or over. There is a small charge of £10 for passengers, but they must complete an indemnity form and wear a wristband
Refreshments:
Food & drink (burgers, bacon rolls, coffee etc) will be managed by the RAF who'll be based in the ’30-130 paddock’
Litter:
It is ABSOLUTELY IMPERATIVE that no litter or cigarette ends are dropped anywhere other than a bin. Failure to observe this very simple rule seriously jeopardises us being invited back, so please use the bins provided (or your pockets!)
Spectators:
All spectators must come with drivers already booked in as we are only allowed a maximum of 60 cars onsite during the day. You need to be security cleared to be allowed on site, so please send me your details (see above) for Security clearance - and bring PHOTO ID on the day. No Photo ID = No Entry
Volunteers:
We need a handful of people to help with putting the V-Boxes in the cars and changing over memory cards throughout the day, so please contact me or Mechell if you’re interested in helping
Video Cameras:
All video cameras must be securely mounted internally via suction mount or bolted to a rollcage. No hand held cameras are allowed. All footage must be for personal use only – eg: not uploaded to YouTube, forums etc
Photography:
Due to the extremely sensitive nature of the venue, cameras are only permitted for personal use, eg: photos cannot be posted on forum or websites. No professional or commercial photography is allowed
Rides:
30-130 wouldn’t happen without the help of the RAF volunteers who marshal and support the event– all of whom are petrolheads and would sell their sister (or brother) for the chance to own the cars attending the day. If you’re happy to give them a ride we will give you a sticker for your windscreen so the guys know they can jump in with you sometime during the day. Thanks in advance from me- it's good to be able to give something back
HOW TO BOOK:
Bookings:
Places can be booked by calling us direct on 08451 25 26 23
Price per car/driver: £99 (MLR members only)
Additional drivers in the same car: £59 (booked via phone 08451 25 26 23)
Passengers: £10 Pay on the day
Reserves:
If places sell out a reserve list will be started. All reserves should still PM me their details for security vetting before 29 Feb 2012 in case you are able to get a place
Cancellations:
Please tell me if you cannot attend for any reason. Please DO NOT post on the Forum offering your place to someone else as we need to manage the entry list for security purposes, and offer your place to the first person on the reserve list. Please be aware of the MLR's Cancellation Policy
Last but not least:
A huge thankyou to Paul, George and the RAF Marham Station Commander and staff who continue to make this unique event possible. :thumbsup:
In... :happy2:
Seriously thinking about this :evilgrin:
Get yourself there Mike, it's a cracking day and you see some serious bits of kit too.. :drool: Plus we need some VAG representation seeing as I won't be in the Ed30 anymore and have to relinquish my FWD crown.. :sad1:
And get humiliated even after ploughing £££££ into my ride :ashamed:
Have to make sure enough money is left after moving to England next month. will be a mint day if I can make it like.
You don't go there with any intention of beating 1000bhp Evo's mate.. :grin: What you do do is put yourself up against the other Hot Hatch/FWD brigade as a comparison and let the big boys fight each other..
I can assure you you won't get humiliated. The VAGs have taken top honours for Hot Hatch/FWD cars on every year we've attended.. As each year goes by though, more and more people attend and there should be some even nicer bits of kit for the next one.. :smiley:
I would love to do this if my car was ready in time. Another quality meet that is 8hrs away for me! Scotland needs to pull its finger out! Stevie.
What's the old girl having done Stevie? Be good if you could make it.. :happy2:
Basically the v-band woa kit 76r. Forged ie rods and je pistons uprated bearings with steel pins, intank pump and arp head bolts. Realistic finish would be mid feb. Dubtek are "massively" messing me around "hugely" delaying things. Think i will be asking for my money back tomorrow and having a chat with Alex see what he can do for me manifold side. Stevie.
Just a tweak then mate.. :wink: :signLOL: Sounds rather :drool: and hope you get sorted asap..
I'm itching for the BSH tb pipe but I haven't got money to give to dubtek to not hear anything for weeks.
Heard a few stories like that now :confused:
Hope you get it sorted mate, will be amazing when done
Might see if Wilko wants to join me in the MK4 of stupidity.
One of the better sites showing good interest! :happy2:
Cheers Mike. Its poor show, just go direct mate. See how i get on tomorrow. Just dont want to cancel my order then Alex cant help. Wait and see. Stevie.
I'd like to find out my ed30 top speed :popcornsoda:
Yea, fingers crossed. I have a few bits I can be getting on with any way
Convoy then mike is it. this is just before i go on holiday to the middle east, so sounds like a plan for me.
Will talk nick into it if I can (bam MkII)
Do you know if 521 have any 'holidays' booked?
You wont get humiliated if i turn up in my little golf cart. Ill most certainly get my ass kicked :grin: Mines not designed for this, but its worth a laugh
No such things as holidays here Mike, its not like normal places. You get time off when theres space in the schedule for time off, otherwise, your away working
That's the impression I have.
I meant exercises/ tours but I'm guessing there will be Lots on.
Falklands for 6 months in spring was mentioned for my trade.
Silly question. Does the days price include more than one run? This will tempt me even more to get a remap done before the day. :driver:
Will be an ideal way to easy myself into the uk track day scene it's not 1/4 mile so a bit friendlier on the clutch too :)
Yes mate, you can run as many times as the queues allow! :happy2:
And the queues are very short as it's very laid back. You certainly won't feel like you haven't got your money's worth...
Those who've been before what kinda top speeds were you managing? Curious what mine would manage if i fully opened it up after what i've had done to it :party:
'TOP SPEED' is a little misleading. It's more a case of what is the maximum speed you can reach on the 1.6 mile runway before you have to drop the anchors, rather than what the car will do totally maxed out..
Last year I only did 1 top speed run in my Stage 2+ ED30, due to the fact it only had OEM cooler and I was more interested in the 30-130mph time. IIRC my official GPS speed was about 157mph, with the speedo reading over 170mph. If I had done a few more runs and braked later, I dare say I could of got a little closer to 160mph, but not much more unless I wanted to end up in the back garden of a Marham resident.. :driver:
Good fun trying though.. :laugh:
i would be up for this.. sounds like good day :happy2:
Hmm, I may
steal borrow Steve Jr's car for this event.
He keeps telling me how fast it is to 150mph :evilgrin:
If the new plans for my Mk5 are complete by then I would be well up for this as well :driver: :driver:
Going to be a busy day if everyone makes it! :smiley:
Suppose it would be rude not to :grin:
New plans Steve? :jumping:
can any make of car run
Yes mate :happy2:
You coming Rob? :jumpmove:
I wonder how fast a 300bhp Polo on R888's weighing 1100kg would do? :innocent:
Yes mate hopefully be able to make it :happy2:
Doubt you'd need r888s for a 30 roll John.
Maybe not but I'll be rolling on them by March anyway. :happy2:
Should be interesting John. It's the 100-130 bit that the little 1.4 may struggle with.. Only one way to find out though... :jumping:
I don't think its a may, but more of a will struggle, they're not geared for it. And lightweight doesn't count for much over 100mph, its where big power takes over.
Ill be no where near 300hp in mine lol. Prob around 220-230hp
:sad1:
Still, I think 130mph is possible in the distance :happy2:
:sad1:
I reckonit can do it as well, but not sure what would be a good time for one though. You expecting to have a hybrid by then
Just imagine if you didn't make it to 130mph :ashamed: I think I would just drive off. You could always get a Tornado to give you a pull :evilgrin: :grin:
Water meth might see John to 300hp with aggressive settings.
65hp gain from water meth if only that was likely, it would be awesome.
I thought he was at 270hp..... My bad :rolleye:
Ok well it might see him to 250 then.
He probably will be soon :driver:
I have a few plans on the go :wink:
Same old :grin: :happy2:
Too right! :P
Hurdys changing his plans more times than he changes his underwear :xmassmiley:
This time in January he'll be aiming for 450hp with nitrous :driver: :driver: :wink:
This is his inspiration :laugh:
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fwww.fotothing.com%2Fphotos%2F569%2F56920fd4d2cda9fcda025fb455e17ca8.jpg&hash=bc5cfb0cbff1511e4238f659c5b7d8a70cab9ac3)
No...........the turbo's too small and it has a washing machine on the LHS. :xmassmiley:
And it appears to be driven by a banana. :xmassmiley:
:signLOL:
Looks similar to the ridiculously fast civic that was at the awesome Gti bash in Aug, that needed a parachute because the terminal speed was too fast by 1/4 mile. Fastest FWD in Europe or did I make that bit up?
Used to go to this when I was part of the MLR
Great day and some of the EVO's are :drool:
Remember doing a 20 second run in my sisters 360bhp Tommi Mak and then seeing the Norris Designs car doing a 6.4 LOL :laugh:
So am I right in thinking that we are not going to have any representation from a Mk5 this year then? :sad1: We need to retain the FWD crown guys, come on :party:
Any Stage 2+ DSG ED30 owners going to step forward for the team.. :jumping:
Me and hurdy will be there
In Mk5's? :confused: :signLOL:
i will be there :santa:
What you running James?
Edit * Just realised that you're the fella who bought most of my mods :happy2: So my old car will be there in some shape or form... :signLOL:
Be good to meet you anyway.. :smiley: You got a build thread mate?
Golf mk5 GTI with a k04 n water meth.
Your in safe hands :grin:
If you guys remember the mad green Fiesta from the Pod a year or so ago.
I'm trying to get him to come to this. :party:
I'm trying to talk Steve Jr at Statllers to go. He has stage 2+ edition 30 DSG, with a Wavetrac diff, hybrid turbo and water/meth and running a tasty REVO race map. 440bhp and 440lbft. He won the mk5 class at inters this year with a 12.7 run and that was 2 up before the race map and water/meth. If he can't come then I may be able to bring his car anyway :evilgrin:
PS. He won't let me bring his mapped 997 Turbo though :sad1:
PPS. He has asked me to put his details down along with mine for both his 997 and his ED 30. :evilgrin:
I'm in as well, just trying to get the next phase of power mods booked for early jan :xmaspresent:
It's all coming together nicely now.. :xmassmiley:
I get the feeling I'm gonna turn up with a knife to a gunfight!! :scared:
I get the feeling I'm gonna turn up with a penknife to a gunfight!! :scared:
sorted that for you :signLOL:
:signLOL: :P :signLOL:
About right though :driver:
The car should have more mods by March, but I doubt that a lighter car (even if I'm at 300bhp by then) will make up for pure grunt from a 30mph roll.
Christ if your turning up with nearly 300hp potentially, and that's taking a penknife,
ill be around 70hp shy of that so I guess ill be turning with nail clippers to this gun fight lol
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Fkoolwhip3722%2Fsmileys%2Frofl.gif&hash=e575d734d5f546e2d1804c48f8fb6a8ec3197c54) (https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2FSmokeJumperFirearms%2FSMILEYS%2FROFLSMALL.gif&hash=9cd34fe7ca41b5a78d43959070175743b2604003) (https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Fkoolwhip3722%2Fsmileys%2Frofl.gif&hash=e575d734d5f546e2d1804c48f8fb6a8ec3197c54)
Looks interesting, are there still places for this?
Yes still places left! :happy2:
Sounds like a good turn out from you guys again, your not gonna get it all your own way this year though, we've got 2 FRS MK1 with over 500bhp coming and I've just had my little penknife live mapped to, so should be very interesting! :wink:
ok, will need to see if i can sort the car out first. But interested though...
Ah Dan, you 've been missing in action for a fair while. Is your car alive?
Just so you all know, I'm not taking names for this event, you need to phone the number in the first post and either Darin or Mechell will sort you out! :happy2:
Hello! Do I know you? I suspect youve changed your name?
Cars still going - just about, always something wrong with it though. Currently got an ECU checksum error causing the EPC ligh to stay on.. not sure of the solution yet.
It was fairly down on power at a recent RR day, so would like it back again for this 30-130 day :D
Will be booking tomorrow with another couple of exciting cars too.
JKM Skud and an old Capri coming along too then :happy2:
What sort of power is the skud running now then. I hear good things about it
350bhp & 387lb.ft on the JKM dyno, so lets say about 400bhp for forum talk :laugh:
jim
:signLOL:
And the Capri?
:signLOL:
And the Capri?
Yes the Capri!!! going to be a busy couple of months, loads of cars to do :smiley:
Caprighia Del boy style
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fwww.google.com%2Furl%3Fsource%3Dimglanding%26amp%3Bct%3Dimg%26amp%3Bq%3Dhttp%3A%2F%2Ffarm5.static.flickr.com%2F4150%2F4999242840_19c03b7787.jpg%26amp%3Bsa%3DX%26amp%3Bei%3D3vDxTpC9A8Wa8QOgyaGjAQ%26amp%3Bved%3D0CAwQ8wc%26amp%3Busg%3DAFQjCNG9rGuhlbJF0MThFkCuIZLK4_WQKA&hash=42da2e60ce04b790f8457f4116f8134601b82808)
No Sy.
:scared:
new spec will be 560bhp :happy2: :happy2: :happy2:
No Sy.
:scared:
Suddenly I feel a bit deflated :scared:
You'll be fine John. Size doesn't matter. Honest. :wink:
Holy sh!t sideways everywhere then :driver:
Will be a good day :party:
You could fit your car in the engine bay of a Capri. :laugh:
Statllers now are booked on this, with their 440bhp ED30 and a tuned Porker Turbo.
Here's hoping the FWD crown stays with VW. :evilgrin:
If Luca's Fiesta is running well that will be an interesting mix. :evilgrin:
All 3 cars booked :driver:
Is there a list of all the runners and riders somewhere? :party:
We can only hope Ian, it's at Bedford 3 weeks before this, so I best take it easy!!!
I will remember those words. :grin:
You could run slicks at the 30-130 day (if allowed that is) :driver:
Topspeed too!.. 160? 170? 180?
I for one hope you get the car there. I'd love to see the Focus RS guys faces when you put in a stonking good time in you Fiesta :happy2:
How many are attending from here or other VAG cars?
Dunno exactly. There's at least me :signLOL:
Yayyy.
You in the 135 Ben?
What power do you have now?
I reckon my 30-130 will be 20-25 seconds? ish :driver:
Yes mate, i'll be in the 1er.. Still only got the software and the rest is factory stock, so about 350-60bhp.
Will be interesting to see how she fairs to the Ed30, but doubt it will be as quick tbh. I would think it will be close though and the BM will certainly take the top speed.
Great :happy2: be great to see what the Beemer does. I was offered a nearly new one a bit back for a good price, but it was a manual.
Can you not drive a proper car then :signLOL: it takes skill to drive a proper box :signLOL:
:P
The wife can't, so I don't. :happy2:
DSG cars are faster anyway. :innocent:
:indifferent: and something is always faster than something else
And a lot is faster than my Polo GTI. :sad1:
With the setbacks of Revo unwilling to go any further on this engine i sence your getting cold feet. A manual 135i with Hurdy mods would have been epic though :driver: :evilgrin:
Great to see loads of FWD runners doing this :) I did this even in my old GTR and it was great fun, easily one of the best events i did in it.
Cant wait for this years one :)
Got a soft spot for the Mk5 i must admit so hopefully there will be some nice ones coming along :) Hopefully soon a list of the runner and riders will appear :) Im giong to run my A8 for a laugh as well to see what the old v8 diesel is like :D might even get that mapped too ;)
Watch out for an ordinary looking Scooby from Scotland.
Andy Forrest is bolting a couple of rather large turbos onto a flat 6 motor. It'll have circa 1000bhp, NOS to boot and aiming for 200mph. Hope the drivetrain holds up tho!
Im glad Andys going, i notice he'd kept quiet on 22b.....
hes definitely not the only one that will be shooting for the 200mph barrier, although something will be going very wrong if he doesnt make it, having done it before!!
He's giving out snippets as he goes along with his build. But I think he wants to give Ross W's EVO a run for the crown this time! Should be fun!
definitey, will be reat to watch. Are you going along?
Bl00dy hell!!
I'll be lucky if I hit 140mph!!!! :surprised: :sad1:
keep your foot in, and hold the f**k on!
the thing is, if you want to do a top speed run, just swing on to the runway at whatever speed you can manage. You can probably hit the runway at 80 or so anyway :)
Ah, I didn't know that, I thought you had to start at 30mph on the runway and go on past the 130mph to then do your top speed. I didn't know you could just tear onto the tarmac with the pedal down and go for the top speed.
In that case I may get to 145mph :signLOL:
But I'm hoping for 150mph+ as I will probably have about 260bhp to push my 1.4 down the strip if I haven't got an upgrade turbo on by then!
nope, you can just tell them youre gonna do a top speed run and then you dont even have to go through the cones (didnt what i was there in 09 anyway). Then just let her rip :)
The stupid thing is though that even at 150 it looks like youre doing about half that because the runways so bloody wide!!
150 would be a great effort from the 1.4 polo though!
Whats the gearing like on the polo? How many MPH per 1000 RPM in top gear?
It is around 30mph/1000rpm in 7th. I'll check later. :happy2:
Checked on way home.
5th - 1.4krpm = 27mph
6th - 1.4krpm = 35mph
7th - 1.4krpm = 40mph
That means 7th would get me 200mph at 7krpm!?! :confused:
Game on then John. :driver:
Your mission, should you choose to accept it............... :evilgrin:
now that would be a sight to see :) !!!
No excuses now :-)
A 300 shot of nitrous and a blatant disregard for human life oughta do it.....
Don't mean to burst your bubble John, but 150+ would be near impossible from the Polo IMO. That is of course unless Hurricane Rita makes a re-appearance of the coast of Norfolk :signLOL:
Stage 2+ TFSI's only just tipped 155+ last year (showing 170+ on the speedo) as there's just not enough room (1.6 miles) to hit the cars 'top end'. Saying that, I never entered the runway with a run up when I did my top speed run, but IMO that won't make a huge difference anyway (maybe 2mph extra). It just doesn't work out like that..
youre most likely right with that, although no harm in trying :)
what sort of speed were you hitting the runway at last year on your top speed runs?
is was your golf that hit 16.5 wasnt it? i think that record will be going this time round :) I think we should pose the suggestion to the MLR to have a little FWD trophy :) always good to spice things up a bit eh?
LOL, like I said, the target is 150mph, but I'll be lucky to get to 145mph. Anything over 140mph would be acceptable.............this year! :evilgrin:
MLR have their sprint series as well. Id love something like that for VAG.
Yes mate it was mine that got the 16.5 and 158mph IIRC. I only did the one top speed run (on my first run) so entered the runway @ about 20mph. TBH I wasn't that arsed about the top speed runs, as it just wasn't suited for that anyway. Plus my car (although Stage 2+) still had the wanky OEM FMIC, so didn't like high speed runs.
The FWD record will defo go this year after seeing what's attending (4/5 500+bhp fwd cars for a start). But with a stock/full weight Ed30 with just TBE, Intake, HPFP and software, it's no great shame IMO :smiley:
Well I looked at last years runs and there was a Renaultsport R26 with stock power (230bhp) that did the run in 35.9 so that is my target to beat for starters.
It was a 16.63 run for you Ben and I'll get nowhere near that! :laugh:
Not run in one of these before what kind of times would the 16.63 (Ben) run up the 1/4 mile and the speed??
May be able to see what my car would achieve then
high 12's and around 112-116mph on a good run :happy2:
Blimey that R26 driver must have been asleep by 130mph.... 35secs :surprised: :indifferent:
youre best up the 1/4 is 11.7 isnt it? @ 128? (sorry that sounds really stalkerish but i just watched a couple of vids on youtube!)
so based on that, you should be doing it in the 10 sec range id say :)
game on :D
game on :D
10's maybe even 9's deppending which way the winds blowing :rolleye:
Oh thats cool, thank you for that.
game on :D
Ha ha ha thats fine, thats what they're for!
Yes my very best is 11.7 @ 128mph which was run on my milder map.
Last visit before the transmission let go we saw a 12.0 @ 134mph
I'd like to think a high9-low11 would be on the cards :driver:
what tyres were you running? good terminal!! are you building a stronger box for it now?
It was the stronger box :signLOL: severe wheel tramp caused the casing to crack which in turn mashed the s/cut gears.
New box is going in Jan and a few mods to halt the tramp!
I run on Yoko AO48Rs
Do you have a build thread for the "trolley" Luca would be an interesting read :popcornsoda:
I do but its rather a long read! (skip through)
However some classic banter throughout
http://passionford.com/forum/restorations-rebuilds-and-projects/96301-m4drst-the-trolley-new-wheel-how-exciting.html
WTF page 1 and i see the picture of your car having a bath!!!!!!!!
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Fe373%2FM4DRST%2FIMG_1244.jpg&hash=4bfa476656182ae215d6ed41cc1340d16be13db4)
:surprised: :surprised: :surprised: :surprised: :surprised: :surprised:
Luca, with a good drive you should piss 9's with a 134mph terminal.. It does get harder to take time off the lower you get, but I expect good things from you my friend :happy2: Just want to hope that Specky doesn't roll up in the Tigra :scared:
As a reference, my best 1/4 was a 12.7 @ 114mph on road tyres (PS2's)..
Interesting reading this :laugh:
I didn't realise you could just do top speed runs as well which I'd be interested in.
Are there still spaces available? :party:
Should be plenty, spaces will fill up quicker come January though!
What's the s3 going to be running?
S3 is currently stage 2+ :innocent:
I will see if I can get off my shift for that day, never realised I was working :sick:
Eeeeek! Lets stick with 11 seconds :signLOL: I hate pressure! :laugh:
Specky is awesome - Id love for him to come, great bunch of lads too.
Haha, I made Specky swear at me when I was up at RS Tuning.
He was sorting his wiring loom out for the car and I had the ED30 on nitrous on the dyno.
If I remember right his exact words were.
"F**k me, you've got more torque than my Tigra!!!"
:signLOL:
:signLOL: yeah did say that I remember
I will be making a return. Same power level, but 100kg lighter.
My mate in his 600BHP gtr will be along aswell as a 470bhp mk2 frs!
Possibly two 996 turbos, 700hp brabus and 750hp evo.
For the benefit of me....what does stage 2+ actually mean? I never work in the "stages" concept as there are so many variables, seems impossible to categorise them.
Map, exhaust, HPFP at minium. Ideally it would also have a uprated intercooler and intake.
gotcha, what sort of power/torque does that yeild on a typical setup?
350hp/ 340lbft
Will come if I'm not working :smiley:
350hp/ 340lbft
Mine was around those figures on it's 1st rolling road, but hopefully will be a bit higher after the ECU has time to adjust. :jumpmove:
Mine has all those plus an ITG CAI, the intercooler was being fitted but they discovered that Forge's twintercooler doesn't fit the new facelift S3 :sad1:
So I'll be investing in a THS intercooler early next yeaar.
The THS is nice, but so is the forge. The forge might ultimately give slighty better performance though but both are proven solutions.
Last years table.
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Fss270%2FPaulHemsley%2Fother30-130.gif&hash=93e201efdc02bf6f3c0da86757adb1ef9c415f0a)
would be good to see a top speed one of those too. Makes an interesting read. I would still have come 2nd in my old GTR :D :signLOL:
There's a few mis-prints on that table by the way guys (VXR being one of them) But most is correct.. :wink:
Jussa: looking forward to seeing the S3 run mate. Be good to see what she can do, as there aren't a lot of S2+ S3's about that I have seen run at any event.
im sure he woudl try to claim it though ;)
Just booked this :laugh:
time to blow the cobwebs off the car..
the 750bhp evo has been confirmed. His BT scooby brother also. I think my mate matt has also, will be coming either in his 600hp porka or 550bhp mk2 frs.
A 750bhp s2000 says hes gonna book it now aswell.
Whats an FRS?
focus RS, the ones that attended last year where fookin slow, but this one is revo tuned
ahh I see
Do people normally go in road trim or strip out as much as possible?
Woudlnt the evo be going on the evo day? sounds like some tasty stuff now then :) whose is the S2000? i havent heard of any high powered ones in the UK....
ahh I see
Its whatever you want to do mate, some people take anything and everything out, some just prefer to run it as pure as.
Most run in their everyday spec so that they know how quick it is in real terms.
The s2000 is owned by a guy who had a 700hp r34 gtr which saw its death at trax in 2009. The s2000 should be done in January as long as there are no hiccups. The Saturday is only for gtroc and mlr paid up members. Plus he wants to be with thee rest of his buddies.
Hybrid TTRS and jonnys BT TTRS should be in attendance also!
Nice one, do you know whos building it? would love to see the spec of it :)
cant wait for this already :D
There are quite a few Revo/JWR FRS MK2 going to this now, hoping I can make it to give the ickle FRS MK1 another shot! :party:
Looks like I'll have to pull forward my plans for upgrading the little Polo. :smiley:
do it man, just dont go for too much as it will invariably be delayed!
Im looking forward to a passenger ride :D
S2000 progress
1.96bar boost and it made 924whp @ 512ft lb tq :scared: :scared: :scared:
needs a new gearbox now lol
was watching a vid of one a while ago with over 900bhp and it was stupid :surprised: :scared:
S2000 progress
Sounds awesome :) isit likely to make an appearance at this??
WTF!!! :surprised:
What reactor engine is in that Jas? Jeeeeesus!!! :scared:
an s2000 engine just with a bug turbo and uprated internals i would think
900 bhp
this one has 701 bhp
that first one doesnt count, anyone can throw a 2Jz in a car and make 900hp. Second one is better. Glad to hear of someone doing a high power one in the UK though, would be interested to know whos tuning it.
WTF!!! :surprised:
Just a built s2000 lump with alot of custom drivetrain parts, oh and sunco race fuel. On V power they expect 750whp.
Cant remember what turbo its using, its by the same makers as the one TEFF is using in his golf R though
WTF!!! :surprised:
You actually booked up now fella? :)
Yeah, are you?
Please add your name on the list if you are coming. The list so far is people from audisrs and vagoc.
Ben H - B5 S4
Clive H- B6 S4
Sam H - S2 Coupe
Toot - TTS
Jamie - R32
DW - B5 S4
DK - R8 V8
NudeNut - R8 V10
Graemep - B5 RS4
Mattyb - evo8
Adamgt - C6 RS6
Rich - TTRS
TTRS_500 - TTRS
JONNYC - TTRS
ROBJ - TTRS
ISHRS - TTRS
My mate - s2000 turbo
my mate - evo 8
my mate - scooby
Ben H - B5 S4
Clive H- B6 S4
Sam H - S2 Coupe
Toot - TTS
Jamie - R32
DW - B5 S4
DK - R8 V8
NudeNut - R8 V10
Graemep - B5 RS4
Mattyb - evo8
Adamgt - C6 RS6
Rich - TTRS
TTRS_500 - TTRS
JONNYC - TTRS
ROBJ - TTRS
ISHRS - TTRS
my mate - evo 8
my mate - scooby
DanGB - Leon sport
Ben H - B5 S4
Clive H- B6 S4
Sam H - S2 Coupe
Toot - TTS
Jamie - R32
DW - B5 S4
DK - R8 V8
NudeNut - R8 V10
Graemep - B5 RS4
Mattyb - evo8
Adamgt - C6 RS6
Rich - TTRS
TTRS_500 - TTRS
JONNYC - TTRS
ROBJ - TTRS
ISHRS - TTRS
my mate - evo 8
my mate - scooby
DanGB - Leon sport
JKM - Jim - Octavia VRS
JKM - Nick - Cosworth Capri
JKM - Luca1 - Fiesta RS
Ben H - B5 S4
Clive H- B6 S4
Sam H - S2 Coupe
Toot - TTS
Jamie - R32
DW - B5 S4
DK - R8 V8
NudeNut - R8 V10
Graemep - B5 RS4
Mattyb - evo8
Adamgt - C6 RS6
Rich - TTRS
TTRS_500 - TTRS
JONNYC - TTRS
ROBJ - TTRS
ISHRS - TTRS
my mate - evo 8
my mate - scooby
DanGB - Leon sport - I can see a few people seeing this on the list and being in for a shock Dan.. :laugh:
Sunglasses Ron - Edition 30 disguised as a 135i
- " - (mate) - Stage 2+ S3
- " - (mate) - P1 (400bhp)
i should imagine there will be a few cars that will do that on the day ;)
Ben H - B5 S4
Clive H- B6 S4
Sam H - S2 Coupe
Toot - TTS
Jamie - R32
DW - B5 S4
DK - R8 V8
NudeNut - R8 V10
Graemep - B5 RS4
Mattyb - evo8
Adamgt - C6 RS6
Rich - TTRS
TTRS_500 - TTRS
JONNYC - TTRS
ROBJ - TTRS
ISHRS - TTRS
my mate - evo 8
my mate - scooby
Listerofsmeg D3 A8 TDI & ??
Do we know if there is a maximum amount of cars on the Sunday?
its normally betwen about 50 and 60 IIRC.
60
Excellent so halfway there.... :driver:
there are other forums with lists though ;) i know of another one with 10 on as well :)
This is near enough full now guys. I spoke to Mechel last week and they were about 3/4 of the way there. My 2 mates got booked on yesterday and apparently they had there busiest day of bookings. So can't be many left now..
I canny wait man.. :party:
Not looking like I can make this :sad1:, gutted but there will be a few Focus RS MK1's and 2's that'll make the Ford contingent stand out, hope you all have good fun! :happy2:
:sad1: :sad1:
Tell me about it Ben, I had new found power to test too! :sad:
Do you know the specs of the mk2 FRS guys
There are 1 or 2 standard MK2's going and I'm pretty sure some Mountune and Revo cars also not sure of bhp though, there are also a few MK1's going and 1 of them is 500+bhp!
Should be great :) shame you can't make it though. Is anyone up for a private fwd shootout?
There always is to be honest between the Hot Hatches that turn up, it really is good fun and all done in good spirit too! :happy2:
hehe cool, hopeully there are a good few fwd runners, as that list on the other page there were about 2!
Just hope it doesnt rain :) (someone had to say it....)
There will be plenty of fwd cars attending, Seats, Golfs, astra/vectra VXR's, Focus RS MK1 & 2's and others!
As for weather, hit and miss really, it could be glorious sunshine, rain, wind, I've been 3 times and encountered all 3! :grin:
Rod, is this just another excuse to try and avoid the humiliation of not beating a motability Golf's time again? :booty: :signLOL:
Listerofsmeg - What you rocking up in mate? FWD class will be seriously fierce this year and i'm glad I retired the Golf as a champ :laugh: as it would be knife to a gun fight time this year (many 500bhp+ stripped out monsters turning up). :scared:
If it does rain, it's not quite as bad as you might think. The runway as Marham is quite a spectacular piece of civil engineering. Due to it's importance and Tornado Jet Fighters taking off and landing constantly (not on this day you'll be pleased to know :scared: :grin:) it has to be able to drain water off and out of sight near enough instantly.
If it does rain, there will be no puddles or standing water at all and it's amazingly quick at drying. So long as it doesn't rain all day, you should be fine (unless you are running a 1000bhp through the front wheels and on slicks :laugh:).
well ill be running my A8, although thats my towcar ;)
my main car for this is a honda delsol turbo (nobody seems to have considered anything japanese for the fwd bit it seems!! :))
:lol: I'm pretty sure my now 380bhp FRS could put in a very good time indeed!
Absolutely not mate.. I use to have a CTR and know of the Jap crowd's potential for sure. Just a shame none of them never seen to show up (been invited in the past) :sad1:
What is she packing mate, any links to build thread, spec, 1/4 mile times etc?
That would of been interesting mate.. Shame neither that or the Ed30 are going to be there.. :sad1: What she had done now, bigger blower?
No mate, live mapped, uprated pump and bigger injectors!
That's why I'm gutted, massive change from before! :sad1:
what power was your ed30 running for your quickest run last year? 400+?
I have a huge build thread over on civiclife.net but essentially its an old B18 engine with a hooooj turbo attached to it. Hoping to get a proper map on it soon as i want to give it a shakedown at the pod in feb. I did run it last year but it was never really "right", smaller turbo and a few other bits then too. Should be much improved this year. Its even got carpets and everything ;)
Eddie was only running 355bhp mate, so nowt special.
So what sort of power figures will the Delsol producing on the day and what you hoping for @ Pod realistically?
Ive got figures in mind but its impossible to back that up with printouts. At the moment we are having trouble controlling boost (a problem carried over from last year too). I am hoping that when i go back up tomorrow that will be sorted though (engine timing was massively retarded, which is now fixed). Assuming thats done then we can wind it on significantly. I want it to run solidly at wastegate pressure before turning it up.
Previous best at the pod on the old setup and half a tune was 11.4, some of the guys in the states that have the same (or very similar) spec are running high 8s though..... :scared:
Sadly, it think my talent would have run out waaaaay before that. Its an absolute missile though.
Sounds like you will be running with the big boys on the 18th then mate :surprised:. It's the complete other end of the scale to my old Golf. In fact my Ed30 was more related to your A8 by the sounds of things. :grin:
I use to do 30k a year in it for work (Sales Manager) and then take it to the odd event like this and Pod without changing a thing (maybe the odd bottle of octane booster here and there for what difference that made if any). It was my daily that would take me round the UK Monday to Friday kicking out 36+mpg, but still do a 12.7 @ 114mph at Pod at the weekends with minimal mods (intake, Exhaust, map and fuel pump) and without doing a thing to it.. That's why I miss it so much from time to time, ticked all the boxes for me. The BM does the same job, just not such a sleeper.
Would love a proper track weapon/project at some point though. It's just knowing where to stop.. :signLOL:
i know exactly what you mean mate, i rarely find the place to stop.....at least ive got the A8 to cruise around with though, and it tows great too :D just need to get it mapped ;)
Mapped V8 diesel = Win :drinking:
Are you Neil? Ex WRX/Skyline owner??
that'll be me matey :) youre everywhere!!!
If you are on civiclife you will know the owner of this mental s2000!
Well that's the thing I still don't! I'll have a looksee at the projects section again :)
Ben H - B5 S4
Clive H- B6 S4
Sam H - S2 Coupe
Toot - TTS
Jamie - R32
DW - B5 S4
DK - R8 V8
NudeNut - R8 V10
Graemep - B5 RS4
Mattyb - evo8
Adamgt - C6 RS6
Rich - TTRS
TTRS_500 - TTRS
JONNYC - TTRS
ROBJ - TTRS
ISHRS - TTRS
my mate - evo 8
my mate - scooby
Hurdy - 6R Polo GTI (think I'm gonna get a spanking here!) :signLOL:
Ben H - B5 S4
Clive H- B6 S4
Sam H - S2 Coupe
Toot - TTS
Jamie - R32
DW - B5 S4
DK - R8 V8
NudeNut - R8 V10
Graemep - B5 RS4
Mattyb - evo8
Adamgt - C6 RS6
Rich - TTRS s tronic
TTRS_500 - TTRS
JONNYC - TTRS
ROBJ - TTRS
ISHRS - TTRS
my mate - evo 8
my mate - scooby
Hurdy - 6R Polo GTI
ttrs/mrdemon - ttrs
players - ttrs s-tronic
Must be about booked up now. There's nearly 30 in that list and it's only 2 forums. There's boat loads of others.. :surprised:
10 spaces left! :happy2:
I think that'll include the ones that haven't confirmed details yet too, so don't be surprised if they go very quickly..
Just noticed there is a V8 R8 running :party: That's my target and i'm locked on.. :fighting: :laugh:
Lol Ben you bully.
I want the v10!
9 spaces left!
ill go after that S2k then ;)
Still havent figured out who it is though....
He's the owner/admin of civiclife, or used to be anyway.
I believe my mate with the sl brabus has finally signed up. He wants to go Audi RS hunting lol.
So, I wonder how a ***whp tuned Porsche Turbo would fare and who he'd have to home in on? :innocent:
There will be plenty of fast scoobies to scalp the Porsche, loads of very, very quick cars on the day, F40 turned up one year and I still believe Darin is trying to get a Veyron to attend this event! :wink:
Also heard Speckys Tigra is attending too!
Does Andy Forrest attend in his buru?
Yes!
I reckon you'd definitely be on his radar John. :wink:
Be great to Specky there :congrats:
his rear facing radar lol
andy Fs going for the record i can tell you that much, a couple more 700+ imprezas i know of that are attending.
Its getting better and better. If specky rocks up that will be great. See if i can get close :)
No that's you in the Homomobile. :pomppomp: :pomppomp:
Ben H - B5 S4
Clive H- B6 S4
Sam H - S2 Coupe
Toot - TTS
Jamie - R32
DW - B5 S4
DK - R8 V8
NudeNut - R8 V10
Graemep - B5 RS4
Mattyb - evo8
Adamgt - C6 RS6
Rich - TTRS
TTRS_500/poverty - TTRS
JONNYC - TTRS
ROBJ - TTRS
ISHRS - TTRS
povs - s2000 turbo
povs mate - evo 8
povs mate - scooby
DanGB - Leon sport
Hurdy - 6R Polo GTI
my mate 1 - K04 hybrid ED30 DSG on w/m
my mate 2 - Porsche Turbo 997
P10YRS - TTRS S-Tronic
Povs mate - sl brabus k8 670bhp or suttin like that
Povs mate - 996 turbo - 650hp
ttrs/mrdemon - ttrs
Hockeynomad - Focus RS MK1 - 540ish bhp
Spoons - Vectra VXR - 400bhp
bsgmatt - Astra VXR - GT30.......
Andy400R - C63 AMG estate - 530bhp
povs mate - charged 350zed
Ben H - B5 S4
Clive H- B6 S4
Sam H - S2 Coupe
Toot - TTS
Jamie - R32
DW - B5 S4
DK - R8 V8
NudeNut - R8 V10
Graemep - B5 RS4
Mattyb - evo8
Adamgt - C6 RS6
Rich - TTRS
JONNYC - TTRS
ROBJ - TTRS
ISHRS - TTRS
povs - s2000 turbo
povs mate - evo 8
povs mate - scooby
DanGB - Leon sport
Hurdy - 6R Polo GTI
ttrs/mrdemon - ttrs
jamie p - supra
sleepersy - Paid - Ford Sierra
Robertio - Paid - RX7 (borrowed)
WRX_2003_Neil - Paid - CRX/Towcar
Clive - Drag car
Duncan - paid - Hawkeye
Steven - paid - Banana
Little Paul - Type r
Simon - Type r
spd(john) - Paid - 22B RA
Andy Forrest - paid - old 95 WRX
Ben H - B5 S4
Clive H- B6 S4
Sam H - S2 Coupe
Toot - TTS
Jamie - R32
DW - B5 S4
DK - R8 V8
NudeNut - R8 V10
Graemep - B5 RS4
Mattyb - evo8
Adamgt - C6 RS6
Rich - TTRS
JONNYC - TTRS
ROBJ - TTRS
ISHRS - TTRS
povs - s2000 turbo
povs mate - evo 8
povs mate - scooby
DanGB - Leon sport
Hurdy - 6R Polo GTI
ttrs/mrdemon - ttrs
jamie p - supra
Clive - Drag car
Simon - Type r
- " - (mate) - 135i
Not seeing many of these MK2 RS' on there Rod (only 1 Mk1 too :surprised:). Have they bottled it yet again? :confused:
I thought Poverty said his 2 mates were coming with Revo kit?
There is defo a standard MK2 going and I'm sure there are a few more Revo's I remember seeing and yes I think there may be more MK1's going, still none of these super fast Renaults though! :grin:
Yeah my mate did say he was gonna go either in his Revo mk2 frs or if it's not ready in time a 911 turbo but havent heard from him lately. Will drop him a call see if he's still comIng
Edit
Says he's signing up tomorrow at the latest
is anyone else booked in to the ely travelodge? would be cool to have a couple of beers before hand i reckon, get a bit of banter going :D
:surprised:
:confused:
:driver:
:signLOL:
:surprised:
:confused:
:driver:
:signLOL:
"Obviously" the night before :P :signLOL:
Is there a final list of entrants yet?
Not yet as I think there is still a couple of spaces left :)
Just been out in Steve Jr's 997 turbo and it is "slightly" fast :driver:
Currently he has bigger coolers, zorst and a Revo map. By the day he will have twin hybrid turbo's, water/meth (with map to suit) and larger throttlebody. Already gets from 0-100mph in what seems like no time at all!
Can't wait to see what time he lays down. :jumping:
thats gonna be quick!
Yep, quick already, so no idea how fast it will be on the day!
Probably somewhere between...
F**K me!
I've Sh*t myself :scared:
Check what happens when you put those simples mods on a PDK car.. :surprised:
How it looks is how it feels too!
0-130mph in 10.5 with pdk. Steve's is manual, so may be a second slow than that now, but with the hybrids I'd expect it to be an easy 10 second car.
even more nice cars then :) only 6 weeks to wait! id better get my car back soon..... :mad:
scratch that, gettingit back on tuesday. STILL no boost control :( more work for me then. Wastegate pressure for now......boo.
Just realised tonight that this day is on Mothers Day - that should cause a few heated discussions for those hadn't realised either! :signLOL:
What a launch on that porker! That is nuts! Love it. Stevie.
Ok, this day is now provisionally sold out!
I think Darin/Mechell are waiting on 3 people to pay and they have until the end of the week before their places get given to someone else!:thumbsup:
Looking forward to seeing the list :congrats:
sweet :) let the banter begin!!
My mate was the took the last spot yesterday afternoon.. :party: He'll be adding another modded 911 Turbo into the mix..
Some direct competition for Steve Jr then. :happy2:
What mods on the 911 and is it pdk?
can anyone come to watch or do they have 2 turn up in sum1's car doin the shootout ???
got my car back today, may have even solved the boost control issue. Now ive got to get it to another dyno to max it out before the day :D
cant wait!
Check the instructions out in the first post Dawain. :wink:
Not entirely sure to be honest John. It's a 996 manual (not 997) and I believe it's between 550-600bhp, so don't think it'll be as quick as Steve's by the sounds of it.
It'll still be fast though, and much faster than mine! :driver:
One for yaz to battle then!
Is this just a glorified willy waving competition, :scared: or do peeps also turn up genuinely for the criac? :drinking:
To me, it looks just like Santa Pod, but without the chavs - someone please tell me I am wrong - because I'm not too far away from Marham, and wouldn't mind turning up just to spectate and meet up with fellow forumites again . . . :sad1:
its essentially just a chance for people who have nicely/heavily modified cars to really stretch their legs in a fixed test that is common to all. Its a great day, lots of banter if you want it, or you can just get on with it...its up to you.
for me personally it is the one event of the year that i will be hopefully able to max my car out.
If you wanted to come along as a spectator you still have to give your security details over to the MLR and jump in wth someone thats signed up i believe.
Ahhh, OK, thanks. :happy2:
30-130mph day is a day that allows lovers of their expensive/standard/modifed cars see what their cars can do in as close to real world situation as possible and IMO thee only event that gives a real world feeling (bar top speed) as to how your car compares to others (be that hot hatches or supercars)!
Properly organised, great/like minded people enjoying the same thing...................POWER!!!!!!!! without the dreaded blue lights :laugh: :happy2:
cant wait!
I'm sure Charlie @ SRR would happily max out your car or you! :signLOL:
im sure he would :) got that sorted though, and a little bit closer to me too. Should see some decent results outof it finally though :)
Fuel on order!
Managed to get a full list of runners from Mechell this morning.. Now it's not exactly filled with details on power etc, but it's better than nowt.. :wink:
Seat Cupra
Evo 6 TME
Ford Focus RS
Audi A8
Subaru Impreza
Audi RS4
BMW 135i
Audi TTRS
Ford Focus RS
Ford Focus RS
Audi TTRS
Audi Quattro
Subaru Impreza
BMW 330d
Skyline GTS
VW Polo GTI
Mercedes / Subaru
SUBARU IMPREZA
911
GOLF GTI
Skoda Octavia
Ford Capri
Ford Fiesta
Evo 8
Sabaru
Seat Leon sport
Toyota Supra
AUDI TTS
AUDI RS6
AUDI TTRS
AUDI RS6
AUDI R8
AUDI S4
AUDI S4
AUDI S4
AUDI S2
Evo 8
Audi R8
GOLF R32
BMW 135i
TTRS
AUDI TTRS
AUDI S3
SUBARU IMPREZA
HONDA S2000
PORSCHE 911
SL55 AMG
FORD FOCUS RS
PORSCHE 911
IMPREZA
NISSAN GTR
PORSCHE 911 Turbo
Subaru Impreza
AUDI RS4
VAUXHALL VXR
Not 60 there I know, but there maybe a couple still to pay/confirm I suppose..
The list on VAGOC has a few extras for power listed on it
Looks like Steve Jr is the only MKV Golf GTI going!
Ben H - B5 S4 500PS K04'ed
Clive H- B6 S4 360PS
Sam H - S2 Coupe RS2 spec, c.360PS
Toot - TTS going S2+ this weekend, hopefully c.360PS lol
Jamie - R32 stock
DW - B5 S4
DK - R8 V8
NudeNut - R8 V10
Graemep - B5 RS4
Mattyb - evo8
Adamgt - C6 RS6
Rich - TTRS 410PS
JONNYC - TTRS
ROBJ - TTRS
ISHRS - TTRS
povs - s2000 turbo
povs mate - evo 8
povs mate - scooby
DanGB - Leon sport
Hurdy - 6R Polo GTI
ttrs/mrdemon - ttrs
jamie p - supra
Clive - Drag car
Simon - Type r
Nice to see I'm still on the listwith my towcar and not the actual car I'm running!!!
As I said, it's not the running list as such, more a list from the vehicles that have been given gate clearance (hence the tow car) :happy2:
the days are flying by! soon be :driver:
:confused: Just phoned to book on as a passenger as I only found out today that I could go, and was told the deadline was the 27th? How come you said it was the 29th Shins? Really wanted to go :sad1:
Gutting. I thought it was end of feb too.
Although gutting I'm sure, it's a bit risky leaving it that late mate.. :confused:
Because I'd be going down with Hurdy and he only told me on the 29th what he was doing as he wasn't sure if he was going down in the morning or the night before and sleeping down there
It wasn't me who said it, it's the rules set by the MLR, sorry!
list of all regsitered runners nabbed from the MLR....not much FWD action...marked them with ** only 7 by my count....
SUNDAY:
DOE - AUDI QUATTRO
KOULAKIS - AUDI R8
THORNE - AUDI R8
AWAN - AUDI RS4
PENMAN - AUDI RS4
PEACH - AUDI RS6
STOKES - AUDI RS6
HARPER - AUDI S2
MARRIOTT - AUDI S3
HARPER - AUDI S4
HARPER - AUDI S4
WISE - AUDI S4
C0CKER - AUDI TTRS
JENNINGS - AUDI TTRS
LOMAS - AUDI TTRS
MCGHIE - AUDI TTRS
NOBLE - AUDI TTRS
WILSON - AUDI TTRS
CRECRAFT - AUDI TTS
RYAN - BMW
STILING - BMW 135I
GRIFFITHS - EVO 8
HO - EVO 8
ANYWL - FORD CAPRI
**LEUILLETTE - FORD FIESTA
**MARTIN - FORD FOCUS RS
**WEST - FORD FOCUS RS
**KIRCKLAND - GOLF GTI
DAY - GOLF R32
**WRENN - HONDA CRX
WONG - HONDA S2000
RHODE - IMPREZA
FULCHER - IMPREZA
ROE - IMPREZA
DARLEY - IMPREZA
DAVIES - IMPREZA
FORREST - IMPREZA
FULBROOK - IMPREZA
GRAHAM - IMPREZA
HO - IMPREZA
SHAW - IMPREZA
WALTON - IMPREZA
ABTHORPE - IMPREZA
ESPIN - IMPREZA
FLETT - IMPREZA
RAINFORD - NISSAN GTR
IQBAL - PORSCHE 911
PINSON - PORSCHE 911
WARD - PORSCHE 911
MAROT - PORSCHE 911 TURBO
PHILLIPS - PORSCHE 966 TURBO
SEWELL - SEAT LEON SPORT
NORTH - SIERRA V8
MEW - SKODA OCTAVIA
SAUNDERC0CK - SKYLINE GTS
RICHARDSON - SL55 AMG
PAUL - TOYOTA SUPRA
**STRAKER - VAUXHALL VXR
**HURDITCH - VW POLO GTI
You missed one.
MEW - SKODA OCTAVIA
FWD. :happy2:
i couldnt remember if VRs' were 4wd? werent the old ones? (or some of them....) oh well 8!
None of the vRS's were 4WD. On the Mk1 the 4WD ones were just 1.8T not vRS badged. :ashamed:
ahh ok in that case definitely 8 contenders!
7!
I doubt mine is a contender :laugh: for the fastest FWD!
Doubtful if the turbo modes will even be on by then now :sad1:
who cares, it will be interesting to see what it can do anyway :) you might surprise yourself.
Not worried too much, it is for the experience on the day and a good bit of banter between the guys I know who are going :smiley:
I make 8 FWD.. You missed - SEWELL - SEAT LEON SPORT :wink:
you mean 9 then......
There, much better....
DOE - AUDI QUATTRO
KOULAKIS - AUDI R8
THORNE - AUDI R8
AWAN - AUDI RS4
PENMAN - AUDI RS4
PEACH - AUDI RS6
STOKES - AUDI RS6
HARPER - AUDI S2
MARRIOTT - AUDI S3
HARPER - AUDI S4
HARPER - AUDI S4
WISE - AUDI S4
C0CKER - AUDI TTRS
LOMAS - AUDI TTRS
MCGHIE - AUDI TTRS
NOBLE - AUDI TTRS
WILSON - AUDI TTRS
CRECRAFT - AUDI TTS
RYAN - BMW
STILING - BMW 135I
GRIFFITHS - EVO 8
HO - EVO 8
ANYWL - FORD CAPRI
DAY - GOLF R32
**WRENN - HONDA CRX
WONG - HONDA S2000
RHODE - IMPREZA
FULCHER - IMPREZA
ROE - IMPREZA
DARLEY - IMPREZA
DAVIES - IMPREZA
FORREST - IMPREZA
FULBROOK - IMPREZA
GRAHAM - IMPREZA
HO - IMPREZA
SHAW - IMPREZA
WALTON - IMPREZA
ABTHORPE - IMPREZA
ESPIN - IMPREZA
FLETT - IMPREZA
IQBAL - PORSCHE 911
WARD - PORSCHE 911
**SEWELL - SEAT LEON SPORT
NORTH - SIERRA V8
**MEW - SKODA OCTAVIA
PAUL - TOYOTA SUPRA
Alot of imprezas are gonna get gapped, and or two imprezas will be doing alot of gapping :signLOL:
I think the Ford Capri and Ford Fiesta will be an interesting leftfield watch. :wink:
would be interesting to see the rough specs of all the runners before hand.
Then we can have a sweepstake ;)
I think Luca put a link to the build thread of the Fiesta on here somewhere. :smiley:
true but i just mean a summary, im not going to read a whole build thread for each car :P
just simple stuff like basic engine, turbo, management etc
Ford 2 litre engine turbocharged
6 speed gearbox
Lightened shell
Nervous driver :jumping:
Currently minus gearbox :signLOL:
Bless. :happy2:
Me then
Honda B18 Turbo
Long gearbox (mix and match of parts) - shooting for top speed too
Bits hacked out all over the place
Fat driver, hopeully balls the size of grapefruits.
Me then
Honda B18 Turbo
What power are you running?
I dont know yet, i probably wont get the car back until the day before the event :indifferent:
The usual schenanigans. A fair bit though :)
What are you expecting then?
300-4-500?
Im still awaiting on my gearbox to return otherwise I'm taking my push bike!.. :signLOL:
Im hoping for close to 650 on a conservative dyno. Unfortunately for me thats as far as we can probably go with a stock port head. Turbos good for a LOT more.
Anyone know the spec of those Focus RS's?
That will see a good topspeed then, what you geared for?
about 230mph @ 9000rpm, the idea was to try and crack 200. Either way a huge task, so whatever will be will be....
I havent had any time to do any aero work so there is a lot of further work i could do, but not for this time round.
i think one of the Focus' has ~540hp...no idea what the spec is to get it to that though but id guess on, just a build motor and a GT35, with supporting mods.
Err.....
Polo GTI
ITG intake
Decat Milltek TBE - Decat will only be done if the turbo turns up and goes on before the day.
Water methanol injection
Loba LO270 hybrid turbo - still hasn't turned up in the UK!
Pace intercooler and radiator - Still at manufacturing stage
Revo/APR map - APR most likely If I get chance to go down to Milton Keynes to put it on.
No Idea of the output, but probably 250-280bhp with the mods done - otherwise 230bhp. Weighs under 1200kg.
So, I guess I'm another one with his car still not complete! :scared:
Secret weapon - driver has elephant balls of adamantium! :driver:
Guestimate is 25-30 seconds for the 30-130 dash :ashamed: Any better than 25 seconds an I will be a really happy bunny :jumpmove:
I hope it all arrives, but surely you wont have enough time to get that lot all fitted any tuned will you??
Still cant wait for this all to go off, if the weather holds itll be a great day :) looking forward to taking apart some expensive metal :D
Im going to set myself some tough targets on 7.xx for the 30-130 and 190mph top end (should target 200 but im getting nervous now...)
It should all be done. The turbo has arrived so will go on with the decat tomorrow. The i/c and rad will be delivered next Monday and go on the car on Wednesday. If I can't get down to Milton Keynes I can use my local APR dealer 15 miles away. Fun times! :scared: :laugh:
7.XX would a superb time and I can only dream of 190mph at the moment.
The strip is 1.5miles isn't it? Is all that useable or is the last 1/4 mile for braking?
Its certainly gonna be a blast trying....just hope mines all present and correct to give it a really good go. Just a shame we couldnt max the turbo out but thats a job for later on :)
The runway itself is a little longer than 1.5miles, there are predefined braking advisory boards (should all be detailed in the email pack youll have got?)
Im not far from MK myself.
Is any one staying close to Marham the night before?
Also don't forget that the clocks go forward one hour on Saturday night, so if you don't change your clocks you'll be an hour late arriving! :happy2:
That's a very good point John and no doubt there will be a few late attendees due to this.. :sad1:
As for the runners, there is a lot of speculation going about that there will be a couple of 4 second cars this year.. :surprised: :rolleye:
Listerofsmeg : I had heard about your 200mph target and will keep everything crossed for you mate :party: The mere fact you are attempting to do that sort of speed in a lightened Civic is :laugh: :rolleye: :driver: But can't wait to see you try... :happy2: Not many have achieved this at Marham..
The Saturday is going to be very interesting too.. Apparently there is a MP4-12C running.. :drool:
They change on the 25th not the 18th :happy2:
Will be interesting to see what andys macca will run it in.
The s2000 is still being built also, if thats not ready in time he will take his civic. Jonnys car is touch and go also. Hope both will make it.
the supra will be quick.
not sure what the procedure would be with chopping and changing cars this late in the day, not sure its allowed :( due to the security issue...
i think he will be alright :wink:
was the S2000 George Wongs by the way?
Mines off ot APR next week for some work, all very last minute!
Hope you get it all sorted in time!! :drinking:
What are you having done?
New mapping and new low pressure fueling possibly.
Yes it is mate, chinglish from civic life! Seen some pictures of his project and it's immense!
right, with you.
Yeah that wont be done in time!!
Looks like your civic will have some competition then!
I cant remember what George has got civic wise.....so we'll see. :P
Well gearbox should arrive back tomorrow so fingers crossed this one works as intended.
Have to love a last minute rush :(
my box had only gone on yesterday too mate, supposedly being mapped today.....havent heard anything yet though! :rolleye:
Well my Turbo is on and running, the intercooler and radiator turned up today, so that will go on the car on Wednesday and then off to APR (hopefully) on Friday for some mapping.
Already knocked the 30-100mph down, so let's hope it does the same for the 100-130mph dash too. :happy2:
Good effort :D look forward to seeing it next sunday. Weathers looking pretty safe too in the forecast!
Are you able to time standing mile too at these events or is it only 30-130
You can do whatever you like. Just ask them on the day
You don't want to be doing anything from a standstill. Think new clutch/gearbox..... :surprised:
If you've got a weak clutch and gearbox yeah ;)
Its tempting though :party:
basically you can do whatever you like, standing mile, 1/4s anything, as they can just work it out from the Vbox data.
Luca, what stud pattern are your hubs? 4x100?
4x108 whys that?
was going to offer you a go with my slicks if they fitted was all, but theyre on 4x100 rims :( so looks like they wont.
Luca has some slicks. :wink:
Argh thanks mate not to worry.
Not looked into that for this......
Can you use slicks? I guessed it was road tyres only.
No limitation when I asked. I'll be taking mine anyway, as well as normal road tyres for top speed :) gotta nail the 30-130 tho !!
As a registered driver on the event am I also automatically registered to be a passenger in any car too?
And on the indemnity sheet do I need to tick the top boxes as both driver and passenger?
Nope, automatically ok as you'll have a wristband.
Yayyy!
In that case can I also drive anyone else's car? :innocent:
Quite probably, might want to ask them first ;)
I meant the owner of the car, before you nicked it a d drive off ;) I know you can drive others cars as I let a friend drive mine last time I was there.
Squeaky bum time for me, gearbox still isnt right, and is having to come off again. Car cant be mapped until thats right :scared:
Cant believe its got to this stage AGAIN. If i get it back on friday it will be a miracle. :sad1:
Mines stuck at APR with low pressure fueling issues, hopefully an easy fix with a new fuel filter or low pressure intank pump. Picking it up saturday.. talk about last minute :laugh:
Kudos to APR for putting the effort in to get it sorted. :happy2:
:sad1: :sad1: :sad1:
We'll keep everything crossed for you mate.. :happy2:
Is this yours by the way?
http://www.rwyb.co.uk/cc_results_photo_data2012.php?CCNumber=CC1751
Cheers, gearbox was hopefully sorted last night so hopefully today is the day..... :drinking:
Nope thats Yasir Dars EG civic, pretty much identical spec to mine, that ran 9.9 @ 152 the other weekend.
9.9765 @ 153.17mph according to that.. :surprised:
haha yep, thats it....
this is mine.
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fwww.blackettphotography.com%2Fgallery%2FRWYB%25202012%2F20120219%2F1400-1415%2FJL4C0974.jpg&hash=d8d4aba0529af8de1e9348f1cb4927a184bc6be0)
this is mine.
Look what has just popped up on my Facebook wall.. :wink:
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fimg845.imageshack.us%2Fimg845%2F5790%2F41978032173867464912055.jpg&hash=c7e39c4cc47dba5ea4aa6476d9f35040b1608454) (http://imageshack.us/photo/my-images/845/41978032173867464912055.jpg/)
Belongs to a certain black Del Sol.. Yours by any chance? :laugh: I take it things are looking up now then? :party:
:driver: yup.....i hadnt imagined he would actually post it up but im very glad he did. Its got a great response so far. The only negative is now that i am genuinely scared!!! when i took it to them it was on wastegate pressure and not running great dynoed then at 360-365. So to get it back with 90% more power is certainly going to be interesting....
Romain wanted to carry on giving it more boost but Ben had to hold him back! I think that run was at 2.4bar. Ill have the graphs here shortly as the cars on its way back to me for me to do the last bits to. I think much more boost and the head would have started to lift. Turbos good for it but i think weve reached the limit of what a stock port head can do. Im not sure i can be bothered to change that though. Really want to see what it can do as is.
I fear for my driveshafts.
So who from here is going to be there sunday?
Me
Poverty
ListerofMeg
Hurdy
I shall be in attendance :happy2:
what are you driving sir? Are you on the track?
sweet, box on and ready to go?
Little green Fiesta
Yes, all set everything was tested yesterday on the dyno and the box works - for now :signLOL:
Me
Poverty
ListerofMeg
Hurdy
Moi :happy2:
Sounds like someone is going to be having some fun :driver: Especially given that rain in forecast too :scared:
Good news mate. :happy2:
Fingers crossed for SUNSHINE
The site I use says it'll be dry all day....I'll go with that. :smiley:
I'll go with you mate.. :smiley:
Me
Poverty
ListerofMeg
Hurdy
Moi :happy2:
whatcha driving?
Ben has a 135 :smiley:
Poverty? Thought he had done his TTRS engine?
I know there was a lot of procedure on Security & booking but does anyone know If I could turn up as a spectator with my Army ID card?
It allows me on any / most forces establishment.
:smiley:
if there is anyway you can contact the base directly i would say thats your best bet....i woudlnt go through the MLR asking as they will just say no.
Lucky for me (or unlucky lol) Ive just remembered its SWMBO's 1st mothers day :sad1:
I would be :fighting: :fighting: if I went to a meet :sad1:
:signLOL:
i'll be in a black seat leon, so come and say hello :driver:
:surprised: :confused: :surprised:
Not the engine, the gearbox.
Current live feed on today's EVO vs GTR battle
http://www.lancerregister.com/mlrsprint/30130results.php?eventid=20120317&last=5
217mph?!?!?! Holy smokes!!! :surprised:
The SVM guy has got balls!
Here's the Hulk - SVM R35 GTR
http://www.gtr.co.uk/forum/147385-r35-gtr-research-development-hulk.html
Hideous looking, but by god what a spec.. I was thinking that the times were pretty slow today, but it was wet from what I hear.. :sad1:
Looking at those times I'll be next to the bottom :signLOL:
Saturday is normally quicker than the Sunday John, so wouldn't worry to much just yet..
I see our local Evo is doing well - - the Wallace car is running just over 1000bhp at the moment :notworthy:
What sort of times are we expecting?
I have no idea what mine should do or how it would compare with say stage 1/2 and 2+ Ed30s, FRS's etc
Think id rather do this than the 1/4 mile tbh, i was cringing at the transmission groaning on launches :sick:
You going tomo Sy?
no mate, liz is in doncaster so ive got jasmine. I was just going to turn up. The joys of not having to worry about security clearance :innocent:
How do I convince Nat it's a great mothers day present lol.
Well you will find out come teatime mate, as John is running and I ran the ED30 last year.. :wink:
Leaving now, will report back this evening. :happy2:
Live stream for today:
http://www.lancerregister.com/mlrsprint/30130results.php?eventid=20120318
HURDY (23 - POLO GTI) 26.51 :happy2:
:popcornsoda: :popcornsoda:
Woah Luca's not hanging around blasting his lil Fiesta to over 180 mph
But here comes Andy F - 6.38 and 192 mph. Bet he's not even running full boost yet!
:driver: & Steve Jnr @ over 190mph :scared:
JKMs kO4 Octavia faster than dans GT28 Leon :surprised:
Do we have rough estimates on the power levels of these cars? For instance the ffocus rrs could be anywhere from 300-500hp. No idea ccomparatively.
The Focus RS MK1 is 460-480bhp, the VXR should be getting better times so not sure what's wrong there!
What about cars
61, 8, 32 and 19?
Errr, pass! :grin:
The other FRS is a standard MK2!
Been pissing it down most of the day and very wet guys. Starting to dry out now, so times should get better.
Had a a dry-ish patch first off then the heavens opened.
Focus Rs is the same car with 2 drivers.
There are three FRS though:33 58 61
No 2, Hockeynomad MK1 & father and son MK2 sharing so looks like 3!
Would of thought Steve Jnr ed30 would have been quicker and wheres poverty i thought he was going?
I hope someone took a camera with them.
Mission accomplished from me.142.9mph and 24.04seconds for the 30-130.38th out of 69 runners.
His car has a rather nasty hole in his gearbox apparently :innocent:
Santa pod casualty ...
Excellent time Hurdy, 4.5s faster than the MkII Focus RS that was there :happy2:.
Were there any 2.0T (K03 or K04) there for you to compare to?
Only JKM's 2.0TSI (K04 conversion) Octavia which was impressive (350bhp+ on their rollers). Also a Stage 2+ TTRS that went well..
Absolutely cracking day (especially towards the end). Just a shame the weather wrecked most of the day..
still the 135i looked like it performed well!! 16.6 that right? what did your ed 30 do last year?
Would you believe...... 16.6 :rolleye: :laugh:
Wasn't expecting to match the ED30 at all, so well chuffed tbh (especially for just a Stage 1 map).
Must be a good 150-200kgs heavier with same power, so was a bit shocked.. :surprised:
Well done Ben and hurdy :happy2:
Both were the same power though weren't they?
Did johnnyc run?
Hats off to John though. 142mph from a little 1.4 is fecking awesome!!! :notworthy:
...strong Easterly today Ben :signLOL:
that's one rapid Polo Mint.. :happy2:
What was your max speed last year Ben??
About 154 IIRC (got the results at home, but on phone ATM). If the weather had of dried out quicker there would of been no doubt that I would of been on the right side of 160. Just ran out of time and only got one run in the dry and braked way to early. Went straight in the queue for another run but they called it a day :sad1:
Yeah weather not been kind to the compo this year.
Hear JonnyC and some other TTRS peeps weren't allowed in due to Admin c0ck up! :surprised:
And last years winner RossW being ejected from Marham for exceeding pit speed limit :surprised:
Impressed with JKMs big Octy going over 160 tho.
:congrats:
Jeeze, that is good!
Oddly mine performs way higher than it should, the Golf had a much better power/weight & more torque, yet this will monster it.
Impressive ben, for what is effectively a standard car with a remap !
Not seen you out n about recently, car running well then :happy2: :smiley:
Is there potential for more of these events?
There's definitely something a bit strange about BMW's power/weight workings out Mike.. But I ceratinly ain't complaining.. :laugh:
Still as was Tom and always about. Was just saying to Sanj this morning that I hadn't seen much of you recently (apart from the other week).
That reminds me, I have a hideous chip in my screen, you busy over next few weeks?
I can squeeze you in pretty much anytime bud, gimme a ring when you around Lincoln and I'll sort it out for ya
Gimme a ring bud
Rich was also there in his TT RS. Even though Audi updated his car last time it was in and mucked up the map he still did over 170mph.
Several Japanese cars left bodily parts over the airstrip during the day including a door, window and wing mirror! :laugh:
Bens car ran well as did JKMs and Dans Seat.
Grip was most definitely at a premium. So much so that I had to start in third gear from under 30mph as second gear ended up as a scrabbling mess. Dry would have definitely given everyone better times and speeds.
Happens around this time evry year, as long as RAF Marham aren't busy! :happy2:
Good show everyone! :congrats:
Andy F's scooby lost the passenger door skin on his only run with his missus Lisa in the passenger seat! :driver:
On every March Sy. Get yourself sorted for the next one?
Pissed myself laughing when I heard that after seeinga bin liner over his passenger door window.. 192mph too :surprised:
Bet she ripped him a new one when they got back to the paddock..
Shame Ross didn't get a run in before hooning it on the out lap.. You should of heard it though.. Must of hit over a ton in a heartbeat. :surprised: Just a shame it was a strict 30 zone and his car isn't the most inconspicuous when on full chat :grin:
He can't of had any complaints though..
Yep, it was a real shame that Ross got banned although I can see why, I was behind him on the way down and he let rip at the worst part of the outroad.....just in front of the ancillary crew by the Fire engine area. That was one area that the sergeant specifically mentioned to be careful around in the morning brief!
I was surprised about the airstrip too, I thought it would be as flat as a pancake, but it turned out that the start area and first third was uphill, with the centre section being flat and then the last third being uphill again. Add the start incline with the wet conditions and you do tend to struggle - even Stve Jr in his 997 Porrsche had to set off in third to avoid breaking traction with all 4 ( normal road tyres ) wheels and that is basically 900rpm!
He has also promised to build something special next year to compete with the big boys and give some kudos back to the VAG guys. :party:
He was quite excited about said sprint car project last time I called in :party:
Good day, wasnt too interested in 30-130 times, as it was just too wet, didnt have any timed runs in the morning though, when it was fairly dry.
Quite happy with the 160mph top, but surprised at that Octavia, must have something special underneath, or just superb gear changes/DSG :happy2:
JKM's Octy has the APR K04 conversion on the new 2.0 TSI motor. And it's a manual. It goes rather well!
Yeah seems like the TSI motor is pretty awesome, APR rave how much better the head is on them, gaining much better power yields.
Impressed with jkms octy, although the oil starvation issues from trackdays and sticky tyres are a bit scary
Jims has done a few trackdays mainly Combe but a few others without missing a beat. I have driven it and been out in it and it is phenomenally quick just not as quick as Luca's Trolley. :wink:
I was absolutely blown away with the top speed of that thing.. To make a Fiesta go quick is easy, to make a brick fronted 1990's Fiesta do 180+mph over 1.5 mile is pure genious IMO :congrats:
What's the engine spec on that fiesta?
His build thread, or a link to it is on here. Luca1 is his name. :happy2:
Great day sadly ruined by the weather!! I want to also extend my congrats to Luca for the 184, major kudos!!! I did manage just under 181 but the story of my day was just extreme lack of traction. I had no grip until 5th gear so didn't give me enough room to pull through it. Still had another 1500rpm to go and was climbing at 3-4mph a second but I had to brake very early as they were shocking!!!
Was just about to have a crack at the 30-130 properly with the slicks but I lifted the Bonnet to find a driveshaft grease all over the bulkhead and a severely twisted shaft! Decided it wouldn't have taken another one and called it a day.
The video I took showed just how hard it was to put the power down, even at 45% throttle in 4th it broke traction at 120!!
Nuts.
Still enjoyed it as always! If I still have the car in a year I'll have another crack :)
Great effort by everyone!
Nuts.
Mate, the mere fact you did 181mph in that thing with the brake set up you had gets a major :congrats: from me.. I had 6 pot Brembo anchors on mine and braked well before the gates of death @ 160 due to my little kahunas. For you to hit 180+ with those milk bottle tops was pure :rolleye: :laugh:
Did feel for you big powered FWD guys though. Typical English weather to ruin a cracking day after being dry for weeks before hand. Only to then be mint the day after.... :fighting:
Sods law init, might go next year with more power and hopes for better weather, i'll still have FWD though!
Ben, did you have much wheel speed in third or second?
I didn't get any in 3rd, but did in 2nd (even with RWD).. Your's must of been a handful? :scared:
The Trolley build thread.
http://passionford.com/forum/restorations-rebuilds-and-projects/96301-m4drst-the-trolley-its-back.html
Bit more recent stuff here.
http://www.mk5golfgti.co.uk/forum/index.php/topic,13920.msg205291.html#msg205291
:rolleye:
well second gear was a complete waste of time, but 3rd wasnt too bad as the map was adjusted for smoothness last week - but still, not exactly grip city.
Thank you to everyone for a great day spoke to a few people briefly and enjoyed watching you all run. :congrats: :driver:
The weather was disappointing for me too, traction where were you???? :signLOL:
I was wheel spinning in 5th @155 then into 6th I was getting grip.
I would also like to take the opportunity to say THANK YOU to Jim, Kate, Keith,Sean and Greg from JKM PERFORMANCE
Without these people I wouldn't be able to drive/build what I (we all) have.
great car youve got there luca, i did want to come and have a chat with you but i couldnt figure out who you were!
Are you going to run it at TOTB? If so ours could be quite a good match for one another on a drier track :D
Likewise - we should wear name tags next time :signLOL:
TOTB is something I would like to run in but its sooooo far North and normally the same day as FordFair at Silverstone.
I shall have a look though at the dates, I'm easily persuaded :smiley:
Found this on t'other forum
Hey..
So, today I was supposed to be at the MLR 30-130 event at Marham.. Unfortunately my TT wasn't going to be ready in time but I was able to convince APR to let me borrow the now infamous APR Stage 2+ Golf R for the day as a stand in which would let me have some fun on the day..
So up at the crack of dawn and up to Marham to be told that my passenger details had been lost and so he wasn't on the list, meaning that there was absolutely no way he would be allowed in, so that was that.. Left the venue after a chat with the organisers and decided to give Bruntingthorpe a call to see if I could drive across there and do my own day!!! haha..
Which got me to here.. :)
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Fo304%2Fjonnnny28%2FIMG_1287.jpg&hash=bf30812f6d8f772d5c564136792e551ba6751918)
So basically thought that I may as well make the most of having the car and luckily we had a V-Box in the car too so was able to do my own testing under controlled conditions! All good..
Quick run down of the spec..
Golf R 2.0T FSI - DSG
APR Stage 2+ Software
APR HPFP
VWR Intake system
Milltek Sports-Cat Turbo back
Stock Intercooler
VWR Brakes
VWR Suspension & Bars
Team Dynamics Pro Race 1.2
Gen 4 Haldex Controller
Road tyres, Shell 99 and a wet track all day..
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Fo304%2Fjonnnny28%2FIMG_1285.jpg&hash=7958d9418e430cfade599e64264641be0370c958)
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Fo304%2Fjonnnny28%2FIMG_1286.jpg&hash=8eedce7a68ef7ac413d0dda43d85fe1379b1a09d)
So heres a little run down of the progress throughout the day!
The day was extremely wet from at the start, and my first run was to be expected..
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Fo304%2Fjonnnny28%2Fphoto-18.jpg&hash=a23750bb4207c786a954d2dd8a9d0da0142fb432)
Not great traction but still not a bad 0-60 time.. What I found interesting however was how slow much the surface water slowed down the car (there was A LOT though)
I waited a little longer and tried again as the rain was backing off..
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Fo304%2Fjonnnny28%2Fphoto-17.jpg&hash=472570d84d0147458880b828bbfcf5f88c1fa371)
Amazing how much difference a little less surface water made!
So then, I thought that there wasnt really much point trying again until it had stopped raining and once that had happened ran the next lot of runs.. The best of which being..
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Fo304%2Fjonnnny28%2FIMG_1276.jpg&hash=542db9f3743ad536e59f94304b201adbbd502300)
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Fo304%2Fjonnnny28%2FIMG_1277.jpg&hash=c2ade25b816b9f3d877fb2cfe79ca4155e73781b)
So a fair bit better but still a ton of wheel spin in first and second gear, so I knew there was more in it..
Waited as late as I possibly could before the next lot of rain came in, and although the track was still damp, no dry line at all, it was the most dry and grippiest that it had been all day.. Which resulted in the following!..
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Fo304%2Fjonnnny28%2FIMG_1280.jpg&hash=955bb00693b03635a2902d21baeeb3cf9d9574c4)
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Fo304%2Fjonnnny28%2FIMG_1282.jpg&hash=aecaa022469c30ff2b5ef51d157ba0f4b31906b9)
Launch felt just perfect, a little wheel spin in first gear due to track being wet and then hooked perfectly in second.. I think it actually helped a little as with the stock DSG software the car does bog on a grippy surface such as Santa Pod.. And also, almost no water on the track really so the car wasnt being held back in that sense..
So I was pretty pleased with that to say the least! Again, I can't stress that this is by far the fastest and most tractable 2.0T FSI that I have ever driven and these latest times show the performance pretty nicely!!..
Really a shame that I wasn't able to run the car at Marham today and have a direct comparison but maybe next time..
I think its important to note that these times are probably more representative of the true day-to-day performance of the car when compared to times at Santa Pod, due to the fact that I was able to make sure the car was nice and cool before each run, no queuing up and also on a non prepped surface meaning that the terminal speeds are not effected by excessive resistance.. (this if anything showed how much difference that makes)
All in all it ended up being a great day and just can't wait for the car to be installed with the APR Intercooler and RSC Exhaust which should open it up even more!.. When thats done I have nominated myself for a trip to Pod with the car to back things up and hopefully run an 11 second 1/4 mile on a stock K04 2.0T FSI.. (in the dry this time) haha..
Until soon..
Jc
Saw Jonny's blog on VAGOC and was good to see he had his own little 30-130 day after being let down by MLR.. :smiley:
The Golf certainly seems to shift, but unless it runs on the same strip as we all did it's pointless comparing the times IMO. As has already been said, Marham is uphill for the majority of the 30-130 run..
I was gutted to hear that he had the same problem getting in as one of my mates and that we wasn't going to see the Golf run. Would of been really interesting to see how the BM & Golf compared though considering they have identical terminal speeds at Pod.. :sad1:
Certainly wouldn't want to have a traffic light GP against it though :surprised: Really can't compete with 4WD + LC + S-Tronic in that environment, awesome figures :congrats:
I wouldnt care about what was faster if I had a 135i :love:
I certainly won't lose sleep over it mate, that is for sure.
I have always thought that the 1er was slightly slower than my old ED30 over that range and tbh I would normally have found myself climbing the walls to add more mods to make sure that wasn't the case. However, the way the car is at the minute and the power delivery that it now has post-software, for me has given the car a perfect set up. Yes it could do with a LSD and with a aftermarket exhaust etc would sound even nicer, but I haven't found myself craving the extra power as much as I originally thought.
I must be getting old.. :signLOL:
The fact it posted near identical times to what my Stage 2+ ED30 did last year (16.60 for 135i vs 16.67 Ed30) is just a bonus :smiley: I do miss the bonkers attitude my Eddie had though and it was much more underestimated. I certainly haven't ruled out getting another in the near future as a track car/toy.. :laugh:
Graph of best run from the day for the 1er (including my mate's runs too).
Mine - Red
Light Blue - Manual 135i (identical to mine including DMS map, but manual)
Green - 400bhp Scoob P1
Dark Blue - Stage 2+ S3
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fimg850.imageshack.us%2Fimg850%2F5695%2F301302012.gif&hash=6219aaeffc8aedfe28b554b59f0dba910977d885) (http://imageshack.us/photo/my-images/850/301302012.gif/)
Seeing as the 1er run a near identical time to my old Stage 2+ DSG ED30, I asked Dave from MLR is he could overlay last year's best run (Ed30) with this year's best run (135i) to see where the 2 cars may of gained/lost time. This was the result.... :surprised: :surprised: :surprised:
135i - Red
Ed30 - Blue
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fimg39.imageshack.us%2Fimg39%2F9770%2F135ivsgolf.gif&hash=89055efea2cfe1103b7e7288eda3830e727d177d) (http://imageshack.us/photo/my-images/39/135ivsgolf.gif/)
To say they are close is an understatement.. :laugh: :surprised:
Was it dry last year?
Yes mate.. My best run from this year was right at the end of the day though and although it was still very slightly damp, it did grip quite well and only suffered a tiny bit a wheel spin in 2nd..
Ben, über impressive for both of your cars, but the BMW, wow, when you take into account the modds you did on each, the BMW is impressive !!
When you have a comparison like that, I have a better understanding of why you done feel the need to rush down the route of further enhancements
Cheers Tom..
I would dearly love to add a cat-less DP and another 20-30 horses, but the risk of losing warranty and having to change tuners just isn't worth it IMO. Plus as I said before, if it ain't broke... :wink:
The Golf did have more mods, but was still far from highly modded when you think that all it had was an exhaust, intake, Fuel pump internals and map. Plus it was lacking in cc's and cylinders too.
To be honest, I never thought the BM would match the Golf's time and had predicted a 17-18sec run at best. Was really shocked after I did my first run and posted a 16.7 :surprised:
Cheers Tom..
Tbh, I completely agree.....leave it be, it's a great all round performer !!
And it looks great too :happy2:
