All Things Mk5 => Mk5 General Area => Topic started by: streetbeefGTI on November 17, 2011, 01:28:34 pm
Title: wynns direct injection cleaner spray
Post by: streetbeefGTI on November 17, 2011, 01:28:34 pm
hey guys i have found some wynns direct injection valve cleaner and it is in an aerosol spray, my question was do i take a pipe off the pcv and spray in through there with the engine running??  i have no idea where to spray it.  can anyone help me out?  thanks.
Title: Re: wynns direct injection cleaner spray
Post by: GrayMK5GTI on November 17, 2011, 01:36:57 pm
I'm thinking of trying this stuff.
I think (from what ive read) you will get a rough idle while the PCV is off but that looks like the best way to get it in to the inlet.
Let us know how you get on!  :happy2:
Post by: streetbeefGTI on November 17, 2011, 01:45:32 pm
thanks mate i can get it for £4 so if it works should be well worth it, if not its only cheap so no big loss, will let you know  :happy2:
Post by: Jaywoo-GTI on November 17, 2011, 02:42:59 pm
I did mine by taking the sensor out directly above the throttle body, should give equal distribution between all the vavles,
But i used redex rather than a spray as the link below shows.
http://www.mk5golfgti.co.uk/forum/index.php/topic,36154.msg436902.html#msg436902
Post by: RS6BRIT on November 17, 2011, 06:19:38 pm
they use something called seafoam in the states, seems a good idea, dont worry about a little reving, it takes quite a bit of load to create boost whilst not in gear. If i remember the redex can cause a bit of white smoke for a mile or 2, they used to say to put a teaspoon down the sparkplug hole to decoke the rings and crown.
