		All Things Mk5 => Modifications & Technical Area => Sat Nav and Car Audio => Topic started by: pazz on November 17, 2011, 01:50:19 pm
				This is a relatively new module with rSAP support and A2DP.
 Is anyone aware if this works with the MK5? I am aware it won't work on red DIS but not sure if like 7P6 module it will work with the car but just not show on DIS.
				i thought anything past a rev c only worked white mfd.  should work as a bluetooth though but not the mfd
 have a quick look http://www.myturbodiesel.com/1000q/a5/VW-bluetooth-FAQ.htm
				No these units need the highline to show you the PIN so you can establish the connection, has they don't work with the red display it cannot do this so you cannot get the info on the RNS510.
 Darren
				Thanks Darren!
