All Things Mk5 => Modifications & Technical Area => Technical Workshop => Topic started by: Usual Suspect on November 20, 2011, 05:07:27 pm
Title: Coding MK5 Golf highline clocks to car with midline late 2007 model
Post by: Usual Suspect on November 20, 2011, 05:07:27 pm
Hi everyone
I am in the process of updating my midline clocks to highline clocks
I have purchased a highline cluster
The part number for my current midline cluster is:
1K0 920 973 B
The part number for the highline clocks is:
1K0 920 974 B
What program can I use to code this clock to my vehicle and what program if different can I use to change the mileage to match my original mileage?
Many thanks
Title: Re: Coding MK5 Golf highline clocks to car with midline late 2007 model
Post by: Phil Miller on November 26, 2011, 01:07:13 pm
you may well have problems coding the 974 cluster, when i had mine done i was told to get a 972 or 973 as they can be coded, speak to apollo13 he will give you more details mate
Post by: Eddie-NL on November 29, 2011, 06:23:03 pm
apollo and several others including myself can only do clock that end 0, 1 and 2
Kalu is the man that can do all types including the 974
