All Things Mk5 => Modifications & Technical Area => Sat Nav and Car Audio => Topic started by: ripmateyy on November 21, 2011, 09:07:00 am
Title: Can I retrofit the mk5 R32 speakers to my Mk5 fsi match?
Post by: ripmateyy on November 21, 2011, 09:07:00 am
I know someone selling the 3 way front door speakers from a Mk5 R32. Was wondering is one it could be easily done and two if it would be worth doing?!
Jack
Title: Re: Can I retrofit the mk5 R32 speakers to my Mk5 fsi match?
Post by: Eddie-NL on November 22, 2011, 06:44:00 am
Hi
I did this for someone not long ago
You will need to change the wiring and add the crossover units to each front door
Post by: daveangel on November 24, 2011, 07:34:59 pm
you will ned to remove the outer door skins to change the door wiring loom.  its not bad to do though.
Post by: ripmateyy on November 27, 2011, 12:51:50 pm
Cheers guys, he sold them now so can't do it anyway, are they any good or would I be better off buying some focal or
JL 3 ways!
Post by: daveangel on November 27, 2011, 01:07:36 pm
the only thing the factory loom gives you is the crossover and mid cabling.  i would say its far easier to rewire the door speakers with the crossover that will comw with whatever you decide to buy.  i did what you suggested and now im building a patch cable to interface the rainbow crossovers to the door wiring.  i would have neeb easier to go with rainbow first.  that and factory speakers are sh*teeeee
