All Things Mk5 => Mk5 General Area => Topic started by: vRS Carl on November 25, 2011, 08:45:01 am
Taken from the new MOT regs which come in to force in January.
The Full PDF is here and Section 1.7 refers to HID Lamps
http://www.dft.gov.uk/vosa/repository/MOT%20Inspection%20Manual.pdf
- Vehicles equipped with High Intensity Discharge (HID) or LED dipped beam headlamps may be fitted with headlamp washers and a suspension or headlamp self levelling system.
- Where such systems are fitted, they must work; however, it is accepted that it may not be possible to readily determine the functioning of self levelling systems. In such cases, the benefit of the doubt must be given.
- Headlamp washers may work in conjunction with the windscreen washers (when the dipped beam headlamps are switched on) or by a separate switch.
So in essence were the current MOT regs state that you MUST have Washers and Self levelling suspension. Now they just say that if they are fitted they must work.
Should put a few minds at ease :happy2:
But they'll still look sh*te! :signLOL:
Very interesting Carl, although the wording doesn't say as much I think it is still referring to factory fit equipment. However, with the wording as it is, having an aftermarket HID kit fitted will be an easy argument to win. FTW! :happy2:
Fitted in a reflector headlight maybe, but fitted in a vehicle equipped with projector lamps and correctly aligned I would defy anyone to tell the difference. :popcornsoda:
I think all cars with factory fitted ones have to have the Suspension/washers etc as it's part of the C&U regs. But as you say they will make the argument easier to win.
Apart from the missing headlamp washers :P (I know you have a work around)
Sssshhh!
I was actually referring to the general look of the light...... :innocent:
Why you telling me to shush. What's wrong with people knowing you strap one of your kids to the bonnet with a bottle of soapy water and a sponge :grin: :grin:
All lies, (they use the 2BM by the way!)
I admit I stick my FAT missus in the boot for self leveling......... :ashamed:
OMG you better hope she doesn't read this :popcornsoda:
I can confirm she has absolutely NO access to this board (I think) :ashamed:
However facebollox has caused one or two issues in recent weeks! :sad1:
Lee you do realise ANYONE can read this board.
I also have a screen shot of the offending post. Now then what could i do with that :evilgrin: :evilgrin:
If she knew where to look.......:P
Bribery eh? That's the last pair of gloves I send you! :fighting2:
