All Things Mk5 => Mk5 General Area => Topic started by: Usual Suspect on November 26, 2011, 12:11:19 am
Title: Lumbar support retrofit and heated seats retrofit on MK5 Golf Help Please
Post by: Usual Suspect on November 26, 2011, 12:11:19 am
Hi everyone I've just fitted r32 leather interior in my 2007 golf
The seats came out of a 2006 golf and one side of the seat plug has more wires than the other
I need to get both working but for now what I need to do is power the lumbar support of the seat so I can adjust the lumbar support as it is set in a really bad position
Does anyone have a wiring diagram that could help me temporarly make a loom to adjust the lumbar.
I will get a loom from kufatec eventually when I have sourced a heated seat panel but for now I just need the lumbar to work
Many thanks
Title: Re: Lumbar support retrofit and heated seats retrofit on MK5 Golf Help Please
Post by: mortygttdi on November 26, 2011, 12:46:41 am
The lumber is only a power and a ground, just ground 1 wire and stick the other to a ignition live on the fuse box :happy2:
Post by: Usual Suspect on November 26, 2011, 01:56:40 am
Thanks for the fast reply. What colour wire is the earth and power?
Many thanks
Post by: skard on November 26, 2011, 04:06:37 pm
What kind of control panel do you have at the minute? Is it the digital one?
There's a couple on eBay of the non-digital/climatic type.
I will be doing this myself later in the week when my seats come  :happy2:
Post by: Usual Suspect on November 26, 2011, 04:33:57 pm
Thanks for the info
I've got a normal one non digital
I did look on eBay but could not see them
Please can u post me the item number
Many thanks
Post by: skard on November 26, 2011, 04:36:04 pm
You'll hate me as I just bought one you'd be after.
Does your says ECON or AC? There's both available will get listings for you, loads on ebay.de as well but work out £50+
Post by: skard on November 26, 2011, 04:39:51 pm
eBay items 140568707380 , 230562672826 , 160686658097 (he sends to the UK as I recently bought from him)
EDIT: 150707931345 just got listed.
Post by: Usual Suspect on November 26, 2011, 09:47:43 pm
Thanks pal u got any info for this mod in terms Of wirin and what wires for lumbar and which one for heating etc?
Many thanks :happy2:
Post by: skard on November 26, 2011, 10:18:23 pm
No problems buddy.
I bought some seats on a whim this week, not coming until Tuesday (all going well). Then I'll have to double check what wiring they have before ordering the correct Kufatec loom, so it'll be at least 10 days before I will be on it.
I'm sure I've read some handy posts on here, and also the MK5 section of uk-mkiv's  :happy2:
Such as this one - http://www.mk5golfgti.co.uk/forum/index.php/topic,8427.15.html (http://www.mk5golfgti.co.uk/forum/index.php/topic,8427.15.html)
Post by: mortygttdi on November 27, 2011, 12:26:40 am
Wiring  1 wire will be brown the other will be red and white.
Darren
Post by: Usual Suspect on November 27, 2011, 11:33:09 am
Darren
Thanks for that pal. Do I jus need to run in to the fuse box to power it up?
Do I need to loop both seats together to get the lumbar to work or individually wire them? Many thanks
Post by: skard on December 08, 2011, 10:22:15 pm
Well I have fitted my heated seats - was a bit of a pain in the backside in respect to the wiring but thanks to various posts on these magnificent forums, got there fairly smoothly as I knew what to expect.
Usual Suspect - As your seats are 2006, you probably need a 2007+ loom - my seats are stamped 03/2006 and I ordered a 2006 loom but have the newer wiring (one control box under passenger seat).
Basically, the plugs needed chopped and swapped over as one has more wires than the other, and this one must go to the passenger side of a RHD car - using the redundant five wires and the addition of three others of similar gauge to extend the loom, it then just needs run in.
I used fuse sockets 34, 37 and 8 (the last one I'll have to check as the recommended 4 and 7 is in use and don't want to start splicing factory wiring if it can be avoided - but for now it works the system and is only 5A).
I didn't have to swap any pins between plugs under the seats, and the pinouts for the climate control panel worked as per Kufatec instructions.
Anyhow, I'm going to see what Kufatec say about not letting buyers specify RHD or LHD.
Post by: jason_rmh on April 09, 2012, 09:58:08 pm
Sorry to drag up an old thread, but Im in the process of wiring up my heated seats and looking for some more info.
Ive got the diagram from the funkmania page:
heated seats diagram (http://furmanka.blogspot.co.uk/2009/01/mk5-podgrzewane-siedzienia-heated-seats.html)
Ive read the post from Darren regarding pins, which I will cross check with mine:
Heated seats (topic 9516) (http://www.mk5golfgti.co.uk/forum/index.php/topic,9516.0.html)
Under Driver’s Seat Connector
Pin 1 – Thin white wire.
Pin 2 – Thin blue and yellow wire.
Pin 3 - Thick red and white wire.
Pin 4 – Thin grey wire.
Pin 5 – Thick brown wire.
Pin 6 – Empty
Pin 7 – Empty
Pin 8 – Thin grey wire which is a direct link to pin 9 on same connector.
Pin 9 – Thin grey wire which is the link to pin 8 and a thick grey wire in as well.
Pin 10 – Empty
Under Passenger’s Seat Connector
Pin 2 – Thin blue and red wire.
Pin 6 – Empty
Pin 7 – Empty
Pin 10 – Empty
Behind Climatic unit
This has three wires going to it: This is different with lumber support
Thin Blue and yellow wire – going to pin 15 of the 20 pin connector.
Thin blue and red wire – going to pin 11 of the 20 pin connector.
Thin grey – going to pin 16 of the 20 pin connector.
I have connected this myself as said by the kufatec instructions.
Ground
Thick brown wire – connected to earth point on drivers side at bottom of a pillar.
Wires I have left to connect to fuse box and Central electrics module
Thick red and white wire. Red/Yellow SC37 fuse box
Thick grey wire. S44 central electrics its number 1 relay at the front?
Thin grey wire. SC34 fuse box
Double black wire connected together with one crimp. im not right sure with this
Double white wire connected together with one crimp. C-1 central electrics
Are the above wire colours for the seat connections from the seat side or the car side of the loom?
My seats are the same as Skard, with only one control box under the passenger seat.
The Kufatec loom is 2006, but same as Skard, looks like the driver and passenger parts of the loom need swapping over. Kufatec instructons are dreadful!
Just wanted some clarification on what to do next.
I need to extend the short part of the loom so it will reach the passenger seat and shorten the drivers side part of the loom so it will fit nicely to the Drivers seat.
Then there are the other wires.
Skard, do you have any wiring tables / pin outs / locations to help?
Which diagram from funkmania should I follow? the 1st or second?
I will take what I have so far and try to piece it all together, but any further info appreciated.
My final issue is that the guy who had the seats before me has chopped the connector off the drivers seat!! Hopefully I can order the connector and repair wires from VW and then I can carry on!
Jason
Post by: skard on April 09, 2012, 10:04:49 pm
The best way to do this is what Ed suggested...
Swap over the 'under seat' looms on your front seats, and use the Kufatec loom as it is (i.e., your control box now sits under the drivers seat). Then when putting the pins into the heater panel, swap them over too. It saves cutting up the loom.
I chopped the loom and it works fine but would do it this way next time.
As for your chopped plug predicament, I've seen looms for sale on eBay, but VW will be able to order in the repair wires/plug.
Title: Re: Re: Re: Lumbar support retrofit and heated seats retrofit on MK5 Golf Help Please
Post by: jason_rmh on April 09, 2012, 10:20:52 pm
Hey Skard, thanks for quick reply!
Swapping the seat looms! Great suggestion! OK, I'll check the info for where all the other wires go and post up if I get stuck.
I will take pics and maybe do a how to guide to help others, as the kufatec instructions are pants.
Jas :-)
EDIT: Ive compared my seat wiring to the pin descriptions that Darren has given and the wiring colours do not match, on either the seat or the kufatec loom. I've got the part number for the the seat connector and repair wires so will get them ordered and swap the seat looms over (inc control module) and  go from there.
Skard, do you have a list of pin outs / wire colours for your car? Ours are a similar year build and so may be the same?
Jas
Title: Re: Re: Lumbar support retrofit and heated seats retrofit on MK5 Golf Help Please
Post by: jason_rmh on April 10, 2012, 12:28:21 am
OK, think I've figured it all out now.
Darren's pin outs look to be pre 2006 type. Mine and Skards the later type.
I know what needs to go where.
Just gotta figure the correct pin positions to repair drivers seat connector then I'm ready to give it a bash.
Apologies for speaking to myself lol, but may be useful for someone reading in the future, as the thread has been helpful for me.
Once I've checked and confirmed it all, I'll post up the results.
Jas
Post by: skard on April 10, 2012, 10:19:01 am
Jason
I just took some pics of my drivers side plugs in the hope they are what you need. I didn't have to adapt any pins in regard to hooking up the Kufatec loom, it was all plug and play.
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fi278.photobucket.com%2Falbums%2Fkk99%2Fonlinephoties%2F055039e3.jpg&hash=973e19e927a8e3085226742cfb4cc754f9d3591f)
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fi278.photobucket.com%2Falbums%2Fkk99%2Fonlinephoties%2Fc99f49d5.jpg&hash=a8abfbcfbf5d0218d47c1058237f40e6ff1a712d)
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fi278.photobucket.com%2Falbums%2Fkk99%2Fonlinephoties%2Fe1ec8c96.jpg&hash=e41e92356d856c0d4581f632f6ddd43a49c4ca83)
Cheers,
David
Post by: jason_rmh on April 10, 2012, 12:24:33 pm
That's a big help. Thanks for taking the time to do that.
Looks like I'm all set for a wiring session ;-)
Jas
Edit: from the pic, looks like the following, can you confirm:
1 empty
2 empty
3 empty
4 blue / black (thin wire)
5 brown (thick wire)
6 empty
7 empty
8 red / black (thin wire)
9 empty
10 purple / blue (thick wire)
Ive check by loom and the colours / tickness match. Ive ordered the repair wires and connector block.
Will repait the connector next week and then get the seats wired up.... just in time for summer! LOL.
Post by: JoeDarKa on October 01, 2012, 09:47:41 pm
Does anyone know what the little plug with the brown and purple wires is for? Im also trying to work out what the red / black wire in 8 is used for?
Post by: Eddie-NL on October 02, 2012, 10:24:41 am
That is for the seat occupied sensor for the seat belt warning
Post by: jason_rmh on December 29, 2012, 11:30:23 pm
Only a year since buying the Kufatec loom, I decided to attempt wiring in the heated seats today!
I repaired the connector on the drivers seat which was chopped off by previous owner.
Wiring is in the car, routed to the general area. My seats are the later type, with only one heated seat control module under the passenger seat. I have electric lumbar adjustment and digital climate control.
I extended the loom to reach the passenger seat rather than swapping the seat looms over.
Based on the instructions from Kufatec and info from the forum and other sources I have the following wiring:
Earth Wires
Brown wires (with ring connectors)Earth point by bonnet release handle
Climate control panel
blue/redClimate control panel (pin 11)
blueClimate control panel (pin 10)
greyClimate control panel (pin 12)
Fuse Box
Red / white (thick wire)fuse box, 37, 30A
Grey (thin wire)fuse box, 8, 5A. 4 and 7 are already in use)
White (thin wire)CECM, Connector C, Pin 1
CECM
Grey (thick wire)CECM L2??? Fuse Box???
Im stumped on the thick grey wire. Im not sure if this goes to the fuse box or to the CECM?
If to the fuse box, which socket should it use?
If to the CECM, which connector / pin?
Kufatec says fuse box. But ive seen Central Electrics S44 mentioned in this thread. What does S44 relate to?
Finally, if I out one of these wires in the wrong place, how do I release them without damaging them? I know they have little tabs on, is there a tool used to get them out?
Jas
Post by: Eddie-NL on December 30, 2012, 09:59:57 am
there is only one wire to the CECM
The grey wire is for the fuse box (i'm sure that is the power for lumber)
Post by: jason_rmh on December 30, 2012, 11:29:00 am
Thanks Eddie!
Any pointers on which fuse location to use and what rating.  Its just as thick a wire as the red / white wire.
On another thread you said you had used 20A and it was a permanent live.
Do you know which fuse location to use for lumbar?
Post by: Eddie-NL on December 30, 2012, 11:34:53 am
I think it is 15A
any permanent live will be ok
Post by: jason_rmh on December 30, 2012, 12:12:06 pm
Great,  ill get it finished today.
If I need to move a wire after ive fitted it, how do you get them out without damaging them?
How do you press the tabs in as theyre quite small.
Post by: Eddie-NL on December 30, 2012, 05:16:15 pm
i use a special tool
but you can use 2 small screwdrivers
Post by: jason_rmh on December 30, 2012, 10:27:33 pm
All fitted and working!  :laugh:
Couldn't have done it without the help from this forum. I will do a proper write up for the how to section!
Jas
Post by: foru2justnv on March 30, 2026, 06:14:00 pm
Hi all
My seats are 2007 onwards as i only have one regulator. I have today swapped the looms over between passenger and driver seat (UK). The only plug now not connected is the blue connector 2 wire which i presume is seat occupancy sensor.
My real Question is I can see the brown wires on both the plugs but ive got different coloured wires. I just want to power up lumbar support for now directly to a fuse shunt. So i need to know which is the power wire on both seats if the brown is the ground.
(https://i.postimg.cc/J4dkK6D8/IMG-3117.jpg) (https://postimg.cc/jLP2Sh43)
(https://i.postimg.cc/RZ6nY7fj/IMG-3118.jpg) (https://postimg.cc/5XJ0YFs3)
(https://i.postimg.cc/Qd9WzQ1L/IMG-3119.jpg) (https://postimg.cc/9D2MRqL1)
(https://i.postimg.cc/t4ZVc3Wj/IMG-3120.jpg) (https://postimg.cc/dhF1kT5H)
