All Things Mk5 => Modifications & Technical Area => Technical Workshop => Topic started by: apples12 on December 05, 2011, 06:28:14 pm
Hi...
Going to be retrofitting Bi-xenon HID's to my Mk5 golf but because the housings i've got are mising bulbs/ballasts, i've got some cheaper D4S bulbs/ballasts that I want to wire in, but want to wire in correctly, could someone who has access to elsawin possibly post up the wiring pinout for the xenon headlight plug (the 12pin end), and also, if its possible, the part numbers to make up the 10pin to 12pin adapters with the leads to plugin to the CECM
thanks
Ive got a file on my laptop with all the different parts and part numbers for everything on the mk5, pm me your email and i will send it over if you want?
it might help
