All Things Mk5 => Modifications & Technical Area => Performance Modifications => Topic started by: ktlstar on December 23, 2011, 10:43:32 am
Title: HPFP install
Post by: ktlstar on December 23, 2011, 10:43:32 am
Morning,
When installing an autotech hpfp, Is it required to take apart the whole pump and clean in and outs ?
Could you not just undo the nut that holds the piston in, swap piston over etcetc ?
Just going by this video.
Title: Re: HPFP install
Post by: bacillus on December 23, 2011, 10:51:22 am
http://www.mk5golfgti.co.uk/forum/index.php/topic,10965.0.html
Post by: ktlstar on December 23, 2011, 10:31:52 pm
Why does it need to be stripped right down, if your only replacing the piston ?
Just wondering  :laugh:
Post by: JackG on December 24, 2011, 12:32:36 pm
To be honest if a cars done less than 45k I wouldn't bother  :popcornsoda:
Post by: 56OctyVRS on December 28, 2011, 08:35:56 am
Is there a specific torque setting the piston has to be tightened up to?
Post by: ktlstar on December 28, 2011, 08:39:34 am
I did mine tight - come off easily so wouldnt thought it was that tight in the first place. Make sure you do have a vice, makes things easy for yourself.
