		All Things Mk5 => Mk5 General Area => Topic started by: vRS_Pagey on December 28, 2011, 11:07:18 am
				................And I think I like them!  :party:
 (https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Fpagey1255%2FvRS%2FDSC04940.jpg&hash=3460feb3b7c3d6a35f0bd1c819d08ed98de9d51e)
 (https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Fpagey1255%2FvRS%2FDSC04943.jpg&hash=1538bc6ee9fcc27996b7ae93ba318d9e9e7b0833)
 (https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Fpagey1255%2FvRS%2FDSC04949.jpg&hash=313f0a8b7696f07e44769fb03e566b77f75257b0)
 Unfortunately I chipped a bit of paint on the clip when assembling them, nothing a bit of touch up can't solve though.  :happy2:
				Wish my new S3 calipers were like this right now  :sad1:
 Very nice though!  :happy2:
				Looks good Lee. :happy2:
 How much did that set you back?
				Yummy...
				Looks great!  :happy2:
 Although you may run into issues where they have gone a little coat happy and done the machined surfaces, best bet is to remove it before you fit them  :happy2:
				Is there anyway off showing us first time refurbers which surfaces not to get painted? if I take a pic of mine that are waiting for painting??
 Jase :happy2:
				Heres one...
 (https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Ffarm5.staticflickr.com%2F4130%2F5182202508_45c915b246_z.jpg&hash=74af6b888680b6ae0b971a2bb415ae07c1b1e35c)
				Very nice Rich and the pic is spot on :happy2:
 Who refurbed them for you? DaveB?
 There was a little over spray, but I have cleaned that all away, what other machined surfaces can you see that are coated???
 Cheers Carl, it was 40 quid to bead blast then powder coat in signal red.
 Ta... yes they are daves... they need doing again tho.
				Now looking for some advice, I want to fully assemble the calipers so they are ready to just fit to the car when the mechanic gets his hands on them.  Question is, is it possible to fit the pads etc, or will this have to be done when the brake is fitted to the car?  If I can do it, can anyone enlighten me on which side of the car is the pad wear sensor, and do the hoses leave the back of the brake pointing up (my OE hoses do) or pointing down?
 Cheers, Lee.
 Holy 3 question marks batman  :grin:
 Might be down to the picture angle but the only parts to watch are the pad gallery where the pad 'ears' sit on the carrier and the rear of the carrier to hub mounting surface  :smiley:
 It's possible to fit them with the pads already in and on mine both pipes lead off upwards  :happy2:
 :laugh:  It must be the picture as the pad gallery is clear of paint, thanks for your response regarding the hose orientation, can you confirm which side the pad wear sensor is?  I have it on good authority it is on the drivers side!
				Wear sensor goes on the passenger side caliper in the piston.
 Arrrrrrrrrrhhhhhhhhhhhhhhhhhhhhh!!!  Just fitted it to the drivers side, I wonder if it's different on the Skoda?
 Doubt it. make sure you've worked out which one is left and right too.  :wink:
 I based it on which way up the hoses go, hopefully I've got that the wrong way around, then the sensor will be on the correct side!
				Just jacked the car up to confirm, passenger side FTW!  Unfortunately I have assembled the brakes correctly so I've had too do it again, its not easy either!
				Looking really smart  :happy2: looks like i'm gonna have to sell on the set i got from DaveB as they won't fit under my wheels  :sad1:
 Dave
				The S3/R32 set up should fit behind 17", what size do you have?
				I got 18s but a really low offset of about 35 so it touches the caliper and would need silly spacers to make it work  :fighting: Think my old 17 monzas are about 51 or so.....
 Dave
				The Monza's would work, what width are your 18's?  With that offset, they should stick out further which means they will clear the caliper easy.
				Fronts are 8s but it a deep dish wheel with low offset so its either brakes go or new wheels and tires time which i can't justify so gotta make the hard decision  :sad1:
 Dave
 Dave
 Tbh, running stage 2+ I would be looking at bigger stoppers!  Perhaps a DaveB's nqsbbk is the way forward?
				Yeah thats another possibility but i'd need to check sizing and guarantee they fit before spending again  :ashamed: plus sell on these beauties first  :love:
 Dave
				At the right price I'm sure you will have a taker on here.  Good luck what ever you decide.
				Thanks mate  :happy2: look forward to seeing yours when they get fitted to the car  :drool:
 Dave
				Well, the brakes were fitted today and they look  :drool:  as the car was delivered back this evening I haven't bothered with pictures, but I will take a few tomorrow.  something I did notice though, the disc only shows signs that the pad is contacting with half of it, approximately the outer 50% in fact???  Is this normal for newly fitted brakes, bearing in mind that nothing is new!  One other question for any brake geeks out there, is there any reason why the front 312mm set up couldn't be fitted on the rear?
				No handbrake cable attachment
				The rear calipers have the handbrake built into them and you can't adapt the fronts to have a handbrake.
				Any ideas regarding the uneven wear?
				Are the pads seated properly? Take it out and give the brakes a good stamping. Can you see the back of the disc? If the same thing happening there? Could it be that the carriers are warped?
				I can't remember from when we were chatting but are the pads used or new?
				Where can you get the vRS clips? Do they fit the Cupra red calipers?
 I could get to the back of the disc, but I bloody hope the carriers aren't warped!!  It still stops on a sixpence, massive improvement over OE!  I will take it out and give it a proper run in the next few days.
 The clip is the original S3 one that came with the brakes, I have just sprayed it satin black, wrapped it in carbon film and a friend knocked up the vRS logo's for me.  :happy2:
 Anyway, here's a sneak preview.........
 (https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Fpagey1255%2FvRS%2F381436_10150520262116473_796276472_8598924_1627028389_n.jpg&hash=ab8012814365c1fcf03520aae02cc50f41de800a)
 The only problem now is the rears look small, and the calipers need powder coating to match the front!  But to do that they will need to come off, so I will need replacements....... :sad1:
				Really like the brakes, I've just purchased a set of R32 front and rears. Was wondering who DaveB and where is he located? i'd quite like him to refurb mine if he doesnt mind and powercoat red? Do you mind passing me his details?
				They look great, top job. Do you have full photos of the side of the car with the brakes fitted?
 Gary.
				Set of red S3 rears going in classifieds soon just after I've done Bergs       :notworthy:          which I've had weeks....but will be done this week
 Drop Dave a PM mate - http://www.mk5golfgti.co.uk/forum/index.php?action=profile;u=631 - he didn't do my brakes but does do a top job!
 Gary.
 Thanks mate, the missus drove it today and seeing the brakes behind the wheels rolling, especially when she booted it and slammed the ar5e end in to the floor looked..........  :drool:
 I will be taking a few more pictures once the car has had a spot of TLC, I need a new signature picture anyway!!!  :grin:
				(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Fpagey1255%2FvRS%2FIMAG0787.jpg&hash=161df41f56ef010f6a4d5c3f2f9c6eedcc53d8aa)
