All Things Mk5 => Mk5 General Area => Topic started by: am1w on January 08, 2012, 11:24:52 am
Title: Tyre Pressures
Post by: am1w on January 08, 2012, 11:24:52 am
Stupid question I am sure.
Must the car be on a level surface for an accurate  tyre pressure check or is it ok to check this when it's parked at an angle along a kerb?
Title: Re: Tyre Pressures
Post by: mad_pete on January 08, 2012, 12:13:46 pm
Should be fine assuming it hasn't somehow changed the volume of the tyre ?
Post by: sanj on January 08, 2012, 01:26:25 pm
Level surface and cold(first thing)as they will be wrong if you've driven about for a bit as this increases tyre pressure. :smiley:
Post by: am1w on January 08, 2012, 02:42:14 pm
Thanks.
Flat and cold it will be.
Knew about the cold and always checked on flat surface.
Confirmation appreciated.
Post by: mad_pete on January 08, 2012, 03:50:55 pm
The extra weight of the incline makes a difference ? So if I park one way on a hill take the pressures and then park the other I'm going to see a difference?
Thinking about it the spare is pumped up off the car (no weight) so I don't think the incline will matter much.
Post by: am1w on January 08, 2012, 05:00:27 pm
I'll pump and check tilted and non-tilted but definitely cold.
