All Things Mk5 => Mk5 General Area => Topic started by: Robo on January 11, 2012, 12:59:30 pm
Title: DSG cost recommended/place for it?
Post by: Robo on January 11, 2012, 12:59:30 pm
As title really car is due it's dsg service in 900 miles and just wondered if anyone knew how much it is and any recommended places to have it done in barnsley/Doncaster/Sheffield area?
Cheers in advance
Title: Re: DSG cost recommended/place for it?
Post by: RENNTAG on January 11, 2012, 01:20:33 pm
I was quoted £205 the other day.
I would only take it to a vw dealers though.
Post by: Gladiator on January 11, 2012, 01:21:34 pm
Had mine done at my local VW, should have cost around £160 I believe but I managed to get a discount as they messed up a few things so owed me a favour or two!!
Post by: reflex11 on January 11, 2012, 02:12:18 pm
only work i'd reccommend the stealers is for the cambelt/waterpump job, otherwise shoddy workmanship as usual
Post by: Beddie on January 11, 2012, 03:09:43 pm
DSG service is fixed price @ £169 at my local dealer group  :happy2:
If done correctly the DSG service involves both special tooling and a set procedure to refill the box so I'm happy to leave it to the dealers and also keeps my warranty intact which can come in handy having a DSG car...
Post by: Viking on January 11, 2012, 03:39:41 pm
DSG service is basically remove the drain/overflow plug and drain the old oil out, remove and replace the filter, refit the overflow pipe, gravity fill the box with fresh oil until it overflows, run the engine to generate heat in the DSG box until the oil temperature is between 35° and 45° (from memory) on VCDS and any excess oil has overflowed, stop engine and refit the drain plug. This gives you the correct volume of oil in the gearbox.
If the oil is overfilled or underfilled then the gearbox will suffer, and if the filter isn't changed at the required interval then similar result. If VW are willing to do this at £169 then it's gotta be a worthwhile investment.
Post by: Robo on January 11, 2012, 05:01:20 pm
Thanks for all the feedback guys iv had two quotes one from Simon at Vagco and also Steve at statllers both highly recommended by others on the forum iv had nothing but bad experiences from dealers and would never let them work on my cars again.
Both quotes are slightly cheaper than dealer too  :smiley:
Post by: LouCyffer on January 11, 2012, 05:14:04 pm
TfsiMike rates Simon at Vagco highly...
http://www.mk5golfgti.co.uk/forum/index.php/topic,30880.0.html
Post by: StephenED30 on January 11, 2012, 05:36:15 pm
DSG service is now £179 at the dealers. :sad1:
http://www.volkswagen.co.uk/owners/servicing/fixed-price-servicing
