All Things Mk5 => Modifications & Technical Area => Performance Modifications => Topic started by: SL03 JOE on January 22, 2012, 11:55:25 pm
Title: Hidden trick to going low on static?
Post by: SL03 JOE on January 22, 2012, 11:55:25 pm
Hi there, I'm just wondering wether there is a way to go real low on a static drop that doesn't rub the front tyres out when turning?
I have the KW V3 set up and I'm wondering how I could adjust the front to stop rubbing some times and go lower and how to drop the back more?
Thanks, Joe.
Title: Re: Hidden trick to going low on static?
Post by: rich83 on January 23, 2012, 01:07:57 am
You've got kw v3 and you want to go really low?? You bought the wrong coilovers.
Post by: SL03 JOE on January 23, 2012, 06:46:07 am
I'm looking to go lower but not silly low!
I know the KW V3 do go pretty low, but on lowest they can rub on when turning under power. I've been thinking front camber to hopefully stop this?
Joe.
Post by: brady88 on January 23, 2012, 10:52:08 am
Rolled arches...but would cost a bomb!
Camber and some extremely stretched tyres  :grin:
Post by: SL03 JOE on January 28, 2012, 01:00:16 pm
well rears are factory rolled and been quoted £100 for front from www.archenemy.co.uk and they come out to you and do it all for the same price.
Joe.
Post by: brady88 on January 28, 2012, 01:52:20 pm
Joe.
£100 seems a very reasonable price...well worth it  :happy2:
But if the paint cracks, which it normally does, then it's a re-spray on both wings  :sad1:
Post by: Top Cat on January 28, 2012, 07:11:56 pm
There is nothing to roll on the front arches, about 2 or 3 mil.  :chicken:
Post by: E30Dom on January 29, 2012, 09:00:34 am
Have you done the arch liner screw mod? Mine never rubbed on my r32 and it was very low
Post by: big al on January 29, 2012, 01:32:52 pm
Be careful rolling the front arches as the roller can pull the metal and spoil the line where the front panel meets the front door.
Speak to Greg Howells, he charges £60 per arch and rolls it without using an arch roller. Though as said you will probably have to spray the panels again.
Failing that there are H&R ultralows that Si Sweetland sells, wider arches and stretched tyres to prevent rubbing,
Post by: SL03 JOE on February 01, 2012, 07:02:24 pm
yeah well i think im going to be flaring all the archs soon and do it properly and get spaces to make it sit right.
but can't decide between Rotiform Nue or 3SDM  :confused:
joe.
