All Things Mk5 => Mk5 General Area => Topic started by: Mk5 GTian on January 29, 2012, 06:57:47 am
Title: CAR magazine Feb 2012 - Buying a MK5 GTi
Post by: Mk5 GTian on January 29, 2012, 06:57:47 am
I've just read the used hot hatch article in February's CAR. They have consulted Jabbasport and VAGTECH to comment on buying a used MK5 GTI. I'm sure there is nothing here that you guys don't already know about, but I thought it would be worth posting for those who are about to buy, or have recently bought a MK5 GTI. there are at least 2 additional things I have learnt that I'm getting checked at my cars major service on thursday. Main points are as follows:
1) The OEM turbo dump valve has a rubber diaphragm which can split, and lead to a loss of that turbocharger surge of power delivery at 2000rpm. Jabbasport replace this with a plastic piston from the S3, but if you are sticking with OEM, get it checked at service. DOES ANYONE KNOW IF THIS DIAPHRAGM CAN BE REPLACED ON ITS OWN?
2) More serious is the fuel pump follower, which is prone to early wear and tear, especially if the car has been on long-life servicing. GET THIS  CHECKED IF YOUR VEHICLE IS 40,000 MILES PLUS, AS FAILURE CAN RESULT  IN SERIOUS TOP-END DAMAGE. Jabbasport usually change them every 20,000 miles as a precaution, as they are only 28 quid a pop.
3) If the car is a DSG and lurches when you pull away, it's likely to be a failure of the Mechatronic ECU. Should be super-smooth when you pull away.
4) As it's direct injection, fuel goes straight into the cylinder, so therefore the back of the valves can get coked up leading to high oil consumption. However, VW says loss of 1Litre per 1k miles is normal, so check oil level regularly.
5) Check the inner wear on the rear tyres. The outsides can look fine, but the inner edge can be down to the canvas if the rear shocks are weakened. You should hear a droning noise similar to a shot wheel bearing if this has happened.
6) And finally, CAR recommend swerving the DSG and going for a basic spec with cloth seats and manual  for one of  the best hot hatches ever made!
Title: Re: CAR magazine Feb 2012 - Buying a MK5 GTi
Post by: danishmkvgti on January 29, 2012, 07:24:40 am
Nothing new  there, that info is all over this forum  :wink:
Post by: diesel junior on January 29, 2012, 07:26:26 am
Thanks for that ian, anyone any idea of the etka number for the fuel pump follower since my spanish doesn't stretch to that.....will be easier to head to the stealers in benidorm armed with the number!
Post by: edd666999 on January 29, 2012, 07:32:02 am
06D 109 309 C
Post by: Mk5 GTian on January 29, 2012, 07:32:41 am
As I said in the thread, I'm sure there is nothing new in this for you guys, but it's really useful for people like me who have just bought one, or are about to buy one, as it pulls all these things to look out for together. It's not directed at the experts like yourself Danish, but those of us who are new to ownership. For example, I didint even know a fuel pump follower existed, but now I know to get it checked and probably replaced.
Post by: sub39h on January 29, 2012, 07:41:02 am
generally the cam follower is a problem in the US where they use poorer quality fuel. that's why it's not so heard of here. that's not to say mine isn't being replaced next month when it gets serviced. they have been known to fail here too, but it's being replaced more as a precaution than genuine worry. be interested to see it's condition tho and it will be changed every service once i've gone Stage 2+
Post by: Mk5 GTian on January 29, 2012, 08:04:51 am
 Thanks for that, I can find no evidence of this being changed previously, so as I'm over 80k, I think it's a good idea to get it  changed, if only for peace of mind. I'll ask my garage to keep the old one and get some pics up. It would certainly be useful to see how it's worn on a car which has been serviced yearly.
Post by: danishmkvgti on January 29, 2012, 08:12:44 am
I'll post a link to my tread, where you'll see a cam follower that at the time of change had done 160.000km, surface should be all black due to the DLC  :happy2:
http://www.mk5golfgti.co.uk/forum/index.php/topic,7823.msg121569.html#msg121569 (http://www.mk5golfgti.co.uk/forum/index.php/topic,7823.msg121569.html#msg121569)
Post by: diesel junior on January 29, 2012, 10:02:31 am
And a very useful post for those of us that live abroad and can't get Car magazine half the time, shame as it's very good.....
Post by: bacillus on January 29, 2012, 10:03:45 am
Actually it would appear to be related to the type of oil used...
Post by: Mk5 GTian on January 29, 2012, 01:25:32 pm
Does anyone know about the dump valve rubber diaphragm? If this is split, is it a case of simply replacing the rubber?
Post by: sub39h on January 29, 2012, 01:28:20 pm
no VW released a replacement DV, called the "revision D" DV. my specialist has quoted me £85 fitted incl. VAT. probably not necessary unless you're planning to remap, but again for peace of mind might as well do it.
Post by: Mk5 GTian on January 29, 2012, 01:41:10 pm
Thanks for that, Have you seen whatthe faceof the cam follower looks like if it's worn thhrough? Is it missing completely?
Post by: Mk5 GTian on January 29, 2012, 01:44:30 pm
Thanks for that, can you see the rubber diaphragm to know if it's split, or is it internal within the dump valve?
Post by: danishmkvgti on January 29, 2012, 01:46:05 pm
You mean the cam right?  :wink:
It's in fine shape as it's the revision B dual metal cam, not the Revision A  mono metal cam.
Besides i have a Cupra engine in my GTI now wup wup  :driver:
Post by: Mk5 GTian on January 29, 2012, 01:57:35 pm
I mean this!:
http://uspmotorsports.com/product_info.php?products_id=542
Post by: danishmkvgti on January 29, 2012, 03:33:30 pm
I mean this!:
And in my link earlier if you scroll down to the appropriate picture you'll have answered your question  :fighting:  :wink:
I'll post the image here for your eyes only
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fi715.photobucket.com%2Falbums%2Fww160%2Fjakethemoss%2FIMG_4840.jpg&hash=b771dfd4f40b60d9d444ddd5d9dfaec51289046e)
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fi715.photobucket.com%2Falbums%2Fww160%2Fjakethemoss%2FIMG_4456.jpg&hash=e1ca0889dcf08731b574a109e8a7394e54fe7a0f)
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fi715.photobucket.com%2Falbums%2Fww160%2Fjakethemoss%2FIMG_4454.jpg&hash=ceb9196733fdad0b0e94b86fb2b3c8281512db22)
 :star:
Post by: Mk5 GTian on January 29, 2012, 04:08:05 pm
So is that a good one, a worn one, does it need replacing if it looks like this?
Post by: Saintsteve on January 29, 2012, 04:27:40 pm
6) And finally, CAR highly recommend the DSG and going for a basic spec with cloth seats, for one of  the best hot hatches ever made!
Amended Point 6 as there clearly was a spelling mistake made  :chicken:
Post by: danishmkvgti on January 29, 2012, 04:41:43 pm
Yup, good one, my bad one outside and inside. If it's reall bad the bottom of the cam follower will be inside the engine and you will be aware of it  :wink:
Post by: Fizman on January 29, 2012, 05:51:10 pm
Cam follower went on mine after 95k kms lads. Not a lot of fun, let me tell you. Had to get a new camshaft inlet and high pressure fuel pump. Replaced every 50k kms I'd recommend anyway, for peace of mind.
Post by: Mk5 GTian on January 29, 2012, 05:55:08 pm
:signLOL: Nope, I've just checked it again, it clearly says MANUAL  :signLOL:
Post by: Mk5 GTian on January 29, 2012, 05:58:36 pm
Cheers Fizman, just reinforces my decision to get it changed, whatever it looks like. Glad I read this article.
Post by: daz05 on January 29, 2012, 08:17:12 pm
I think point 5 is wrong too, didn't earlier cars come with a fair bit of negative camber on the rear, mine is running 1.5deg and I'm just going to have it adjusted.
Post by: Mk5 GTian on January 30, 2012, 05:47:29 am
I don't think it's wrong as such. Your point may be an additional reason for  the inner wear, but these points are based on the experience of Jabbasport and VAGtech, who have been working with these cars day in day out since 54 plate. They will have found a strong correlation between weakened rear shocks and inner rear tyre wear to have brought this one up.
