All Things Mk5 => Mk5 General Area => Topic started by: rich83 on January 29, 2012, 09:16:00 am
Hi chaps.
What's the point of the DV feeding back into the intake, does it serve a purpose? What happens if you remove the rubber pipe and block the port on the intake, so venting the DV to atmosphere?
Ta
Rich
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fts4.mm.bing.net%2Fimages%2Fthumbnail.aspx%3Fq%3D1574424491443%26amp%3Bid%3D96e8a5c8f5f7cfdc71bad7045b16ab06%26amp%3Burl%3Dhttp%253a%252f%252fgooglesearchesfromsundayafternoon.com%252fwp-content%252fuploads%252f2010%252f12%252fexplosion-2.jpg&hash=d9e90f0954826685662fef7313e55ee036bc1230)
:grin:
And for the serious answers? :-p
It interferes with the running of the car as the ECU takes into account the extra air being recirculated and can lead to running problems such as stalling or a misfire. Just best left alone imo
Does it? WHy does the Forge spacer work then? :laugh:
It doesn't, revo took mine off when they developed the map, said I may aswel slash my boost pipes
:ashamed:
