All Things Mk5 => Modifications & Technical Area => Sat Nav and Car Audio => Topic started by: nadlad on January 29, 2012, 02:22:45 pm
Am undecided which to get both are around the same price which of the two is better.
I have mk6 mfsw, rns510c and full fis clocks. I def want display on the mfd
Ave been through so many searches etc but still not sure what's better in terms of connectivity sound etc etc
Pls help
Fiscon Basic Plus is a great bit of kit - i have one in mine and it works perfectly with the MFA and RNS for telephone functionality.
You also get the EMFA add on with it so you can tell proper coolant temp, oil temp, revs, voltage, fuel level (exact) and a few other bits too plus boost pressure if its a diesel
Also allows for A2DP audio streaming
So yeah, all round a great bit of kit.
Yeah ok sounds good I have seen them on eBay for 298 delivered.
Is it called fiscon basic or fiscon basic plus it's a bit confusing on the old eBay search.
Does anyone rate it better than the 729b kit? And where do u mount the module on the fiscon
i've got the fiscon basic,
theres only one difference between the fiscon basic and the fiscon basic plus, the basic plus allows dialing from the RNS/phonebook on the RNS
i'd go for the fiscon if i was you :happy2:
